stm32芯片的IO STRUCTURE TTa是什么意思
yeluox 提问时间:2015-4-10 14:14 /
stm32f030 系列手册 IO structure  功能显示  TTa  FTf是什么意思?
赞 收藏 评论3 发布时间:2015-4-10 14:14
3个回答
wamcncn 回答时间:2015-4-10 15:07:56
手册上有说明
zhangdaijin 回答时间:2015-4-11 23:39:04
学习一下
漂亮的方 回答时间:2021-1-29 11:53:53
Name Abbreviation Definition
Pin name Unless otherwise specified in brackets below the pin name, the pin function during and
after reset is the same as the actual pin name
Pin type
S Supply pin
I Input only pin
I/O Input / output pin
I/O structure
FT 5 V tolerant I/O
FTf 5 V tolerant I/O, FM+ capable
TTa 3.3 V tolerant I/O directly connected to ADC
TC Standard 3.3 V I/O
B Dedicated BOOT0 pin
RST Bidirectional reset pin with embedded weak pull-up resistor
Notes Unless otherwise specified by a note, all I/Os are set as floating inputs during and after
reset.
Pin
functions
Alternate
functions Functions selected through GPIOx_AFR registers
Additional
functions Functions directly selected/enabled through peripheral registers
