stm32 规则组和注入组程序
gujiamao 发布时间:2015-5-3 10:45
& ~/ D: @. ^. T
  D. J, b  N$ g) P9 V
第一种(DMA + 规则)% \# j; A' o* b2 z+ @' o
    RCC_ADCCLKConfig(RCC_PCLK2_Div6); /*72Mhz/6 = 12Mhz*/- E( w( ?. Y% x) T
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);$ Z% L0 f. v$ t, e2 P6 e/ r7 B
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
: A/ Z0 a( p. h+ \' Z: V: m    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1 | RCC_AHBPeriph_DMA2, ENABLE);* E1 T% j. q1 }9 M* }
    GPIO_InitTypeDef GPIO_InitStructure;$ ^7 {  o( e3 Q" o7 E* V
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
& U) E+ T$ w( C2 ^! J" h    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
& M" a3 B/ v% x: `: ^5 o    GPIO_Init(GPIOA, &GPIO_InitStructure);5 _: B8 f7 w3 e
    //DMA Config% ?' G$ S6 o. _
    DMA_InitTypeDef DMA_InitStructure;+ R! ]& e* ^7 v3 f$ B" B; @2 c
    DMA_DeInit(DMA1_Channel1);
+ c5 `. d' r" ?( [& i* b    DMA_InitStructure.DMA_PeripheralBaseAddr = 0x4001244C; //ADC1的DR地址, B$ T9 B; Q# T5 f
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)hwAdc_Converted_Value; //不加&应该也可以 数组名 代表地址7 E1 a- y! A0 u* Q8 L$ p  v
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;//外设向内存传数据. C, r8 ?$ h* Z' j$ @
    DMA_InitStructure.DMA_BufferSize = DMA_N * DMA_C; //DMA缓存大小 //64 * 46 t% b& N; [, M0 Y8 z4 @5 L; t
    DMA_InitStructure.DMA_PeripheralInc = DMA_MemoryInc_Disable;
' T3 u6 r+ X: ?( L) J    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //目标内存地址自动后移
& x' t3 i! c" \, N    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;! ?- e" e5 R) B; p. p. x
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;//DMA传送数据尺寸16位2 A. H8 ~9 W  R5 r# l4 }4 H6 V
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//常用循环缓存模式
0 M) q# c' o0 s7 Z, A. g$ v$ b    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
8 p' B! @6 l( ^  _    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;//禁止内存到内存模式7 `1 B# g3 i3 C* N
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
0 _& w. \/ E/ [& ~1 ~/ m    DMA_Cmd(DMA1_Channel1, ENABLE);" ^8 ]$ s; R" T
% o/ ]6 f# q! @! t
* l; j+ v/ _9 d5 U+ c8 e
    //ADC Config
! J) L; V- [- G( R     ADC_InitTypeDef ADC_InitStructure;
4 W8 w2 M, X4 K" ]' H     ADC_DeInit(ADC1);6 B( E# i+ U, \% v
     ADC_StructInit(&ADC_InitStructure);6 V/ g- z. }$ z/ g0 }
     ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
3 q2 Y  g/ q" {3 }     ADC_InitStructure.ADC_ScanConvMode = ENABLE; //!!
5 X2 |9 z" p$ _: ?3 q9 f* E     ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //!!
, R3 C4 j+ F' n3 m% ^! `& s     ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
$ ?3 [0 U8 y6 W5 p" R% M     ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
/ }1 G: e) [# |: @     ADC_InitStructure.ADC_NbrOfChannel = DMA_C; //41 ?0 h; ?$ _) y# {3 d9 p3 Z2 Y* f
     ADC_Init(ADC1, &ADC_InitStructure);
5 V# ^& x4 L7 F# e     ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5); //9Mhz/(239.5 + 12.5) = 35.7Khz. e+ v! W3 B/ \: l: b
     ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5); //9Mhz/(239.5 + 12.5) = 35.7Khz
. v7 O, c2 u* M% Q; V: n  ~     ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5); //9Mhz/(239.5 + 12.5) = 35.7Khz4 `# T. ?( @9 m$ i
     ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5); //9Mhz/(239.5 + 12.5) = 35.7Khz) w) i6 }8 w' d  v. Z( t
     ADC_DMACmd(ADC1,ENABLE);
: P0 H5 D$ Q) t7 H( S6 J  F8 a0 t     ADC_Cmd(ADC1, ENABLE);: N& E# t9 ^# |! H
     ADC_ResetCalibration(ADC1);
/ t8 {! v3 K- Z- o1 P6 D( `4 B     while(ADC_GetResetCalibrationStatus(ADC1));9 Z  X1 a+ U; _$ o: i
     ADC_StartCalibration(ADC1);
! p7 |8 e8 ?- h0 L' n1 h  @/ z0 R9 h     while(ADC_GetCalibrationStatus(ADC1));
, f- u5 ]( ]& c8 i9 y7 F! L     ADC_SoftwareStartConvCmd(ADC1, DISABLE);
1 H3 J9 m$ \. L第二种(注入组); Q. k' z0 G' C5 t4 K1 Y  Q
. H4 w( p0 E9 D+ U    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  X3 b5 N1 I+ r    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
, y4 h( z; I  E) Y    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1 | RCC_AHBPeriph_DMA2, ENABLE);6 V7 Q2 Z# ^3 `: N' K/ `" j) }. ~
- O1 ^2 Z# \- t: l  x    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;    3 W8 m8 x8 \+ C/ [2 ^- o
  v: i$ q" A/ {/ e* g9 a    GPIO_Init(GPIOA, &GPIO_InitStructure);
- \% f1 I2 m( W; W) L' K) T+ X    //ADC INIT, ADC1 INJECTED CH, CONT SCAN MODE
6 b0 r: i4 }5 u0 m/ M4 R& f    ADC_InitTypeDef ADC_InitStructure;+ M; y. k& Y* u" l  X4 @2 U9 @
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);* f$ y; l9 q; w, j+ h
    RCC_ADCCLKConfig(RCC_PCLK2_Div6); /*72Mhz/6 = 12Mhz, note: 14MHz at most*/7 Q& w  ^1 L' _8 P3 y
    ADC_DeInit(ADC1);
$ c6 ]3 k$ J  e0 o    ADC_StructInit(&ADC_InitStructure);
, d% H5 X3 W) F+ M+ C9 w+ F% o6 G    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;+ z0 y4 e5 l# Z3 ^8 K) S. B
6 m6 A* b& e0 j) I    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
7 I9 {2 [) g* `) Q  t* n5 p; @    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;3 Z" l: @5 m  |4 n, F& m- P( X
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Left;
! D0 Y0 ?0 T8 T; G    ADC_InitStructure.ADC_NbrOfChannel = 0;0 H* ^3 Z* G% ]; M
3 u& d6 l( G$ b/ |% m: m: v    ADC_InjectedSequencerLengthConfig(ADC1, 4); //!!!length must be configured at first
/ k0 m- o: Q2 I1 U/ r    ADC_InjectedChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5); //12Mhz / (12.5 + 239.5) = 47Khz( t/ L7 N) ~. z1 A
    ADC_InjectedChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5);" o) }' V/ R- G, N# q( V" F. v4 y
    ADC_InjectedChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5);
3 O9 P$ `% b/ ^    ADC_InjectedChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5);0 O1 @9 y1 E* i6 J& e9 u$ F
    ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_None);# }' y- X) \* _6 w1 F. B
    ADC_AutoInjectedConvCmd(ADC1, ENABLE); //!!!must be set because inject channel do not support CONT mode independently
7 T( F' I0 Q6 m9 W, M8 `% \    ADC_Cmd(ADC1, ENABLE);
! }) g" }3 N' S7 u, o2 l+ _) }    ADC_ResetCalibration(ADC1);
1 w  ?+ r0 q$ ^7 u$ G: n8 ~! T    while(ADC_GetResetCalibrationStatus(ADC1));
; F% P# W9 t; e- ?    ADC_StartCalibration(ADC1);
  L4 O/ N5 J6 ?4 I    while(ADC_GetCalibrationStatus(ADC1)); //WARNNING: DEAD LOOP!!!
( c% M( J( e! W# }; P! \( g' s    ADC_SoftwareStartConvCmd(ADC1, DISABLE);3 g. y& e* J9 k: e/ K, B5 G4 a1 g
3 O; b: z# `' E2 y+ G3 z
赞 收藏 评论11 发布时间:2015-5-3 10:45
11个回答
gujiamao 回答时间:2015-5-3 10:46:03
都是四个通道,感觉注入组更方便点。
stary666 回答时间:2015-5-3 15:11:43
都很好,如果是寄存器版就更好
moyanming2013 回答时间:2015-5-4 14:12:19
不明白这是什么意思呢?: x" n; A8 O# q
gujiamao 回答时间:2015-5-4 14:18:58
moyanming2013 发表于 2015-5-4 14:12- \" c7 y; Y/ R0 K1 L* h' x0 }' C6 ^
不明白这是什么意思呢?
3 g* ]- W2 i  W1 {: C! F9 k' |
比如你用到ADC1的四个通道,怎么知道此时采样的是哪个通道呢?: a# F! P9 X. ^% Y/ R0 ^, Z
1.用DMA方式;
$ V6 ]/ j0 t2 `2.用注入组
ROCK0525 回答时间:2015-5-4 14:31:20
不明白这是什么意思呢?
那就地方 回答时间:2015-5-4 22:00:46
谢谢楼主分享,学习了
alisa123 回答时间:2015-5-4 22:12:34
这个在那个类型的芯片上的,stm32f10x,还是stm32f20x,还是stm32f30x?请问这个针对ADC+DMA方式采样顺序采样多个通道,上述三个类型的CPU有没有什么不同?谢谢
gujiamao 回答时间:2015-5-5 14:26:58
alisa123 发表于 2015-5-4 22:122 o8 U0 ~* Q# S  N0 A+ f) @
这个在那个类型的芯片上的,stm32f10x,还是stm32f20x,还是stm32f30x?请问这个针对ADC+DMA方式采样顺序采 ...
6 E2 Y* ~6 s7 l. T: G9 t) |+ s我用的是10X。其他两款没用过
qscvhu 回答时间:2015-5-5 15:21:29
两种有什么不同?
为什么是EEFOCUS小白 回答时间:2015-5-5 17:02:00
谢谢楼主分享!
gujiamao 回答时间:2015-5-6 19:57:01
qscvhu 发表于 2015-5-5 15:21
5 M) L! r5 |) o6 L7 ]两种有什么不同?
+ Q2 u3 e, }: }
规则组必须按着事先说好的采样顺序采样;/ K' j# b. D1 C8 f8 E+ t
注入组则不用。
