求助:帮忙看下我的串口程序
二宽 提问时间:2015-5-14 12:42 /
#include "stm32f30x.h"
#define uint unsigned int
int main()
                RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);//enable clk
          RCC_APB2PeriphResetCmd(RCC_APB2Periph_USART1, ENABLE);
                GPIO_DeInit(GPIOA);
          USART_DeInit(USART1);
          GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;//RX
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
          GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_9;//TX
                GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
                GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
          GPIO_InitStructure.GPIO_Pin=GPIO_Pin_5;//LED
                USART_InitStructure.USART_BaudRate = 115200;//UART
                USART_InitStructure.USART_Parity = USART_Parity_No ;
                USART_Init(USART1, &USART_InitStructure);
                USART_Cmd(USART1, ENABLE);//EN UART
                USART_SendData(USART1, 0X55);
                while(USART_GetFlagStatus(USART1, USART_FLAG_TC)==1)
                GPIO_SetBits(GPIOA, GPIO_Pin_5);
赞 收藏 评论19 发布时间:2015-5-14 12:42
19个回答
二宽 回答时间:2015-5-15 15:26:43
结贴
        uint i,j,k;
void Delay(i)
                for(j=0;j<=i;j++)
int main()
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
                GPIO_DeInit(GPIOA);
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
          GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_7);
          GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_7);
                USART_ClearFlag(USART1,USART_FLAG_TC);
                while(1)
                Delay(500);
                GPIO_ResetBits(GPIOA, GPIO_Pin_5);
                        Delay(500);
二宽 回答时间:2015-5-14 14:58:18
int main()
                GPIO_DeInit(GPIOA);
          GPIO_PinAFConfig(GPIOA, GPIO_Pin_10, GPIO_AF_7);
          GPIO_PinAFConfig(GPIOA, GPIO_Pin_9, GPIO_AF_7);
                USART_InitStructure.USART_BaudRate = 9600;//UART
                USART_SendData(USART1, 0X0055);
修改后还是不行,主芯片是STM32F334R8
二宽 回答时间:2015-5-14 14:59:41
小蚂蚁快溜跑 发表于 2015-5-14 14:08
void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF)
缺少端口复用的 ...
不行呀 ,  你有串口代码吗? 给我看一下呗 ,谢谢啦
二宽 回答时间:2015-5-14 12:43:29
串口助手收到的都是000000~
Winddddd 回答时间:2015-5-14 14:04:57
引脚配置不同功能,每一个引脚都要调用一次GPIO_Init(),你这样写相当于只配置了最后一个引脚PA5,还有要调用GPIO_PinAFConfig()配置复用功能
小蚂蚁快溜跑 回答时间:2015-5-14 14:08:27
缺少端口复用的吧,你试试
lkl0305 回答时间:2015-5-14 14:19:15
端口复用吧?
废鱼 回答时间:2015-5-14 14:46:32
三楼说的正确,GPIO配置不对,A9 A10默认是串口不用映射,如果是B6 B7需要映射。
二宽 回答时间:2015-5-14 14:58:57
还是不行,你有代码?能给参考一下吗?谢谢了
二宽 回答时间:2015-5-14 14:59:13
Winddddd 发表于 2015-5-14 14:04
引脚配置不同功能,每一个引脚都要调用一次GPIO_Init(),你这样写相当于只配置了最后一个引脚PA5,还有要调 ...
还是不行,
二宽 回答时间:2015-5-14 15:35:01
我感觉是没有发出数据来,我的发送数据有问题吗?
Winddddd 回答时间:2015-5-14 15:53:45
可以看看我前段时间弄串口时写的笔记
http://blog.sina.com.cn/s/blog_d2edb6010102vewi.html
为什么是EEFOCUS小白 回答时间:2015-5-14 16:47:13
不懂帮顶
lkl0305 回答时间:2015-5-14 16:54:45
不知道你用的是哪个库,里面官网应该提供有实例,你可以参考下
二宽 回答时间:2015-5-15 15:25:17
我改好了  帅哥,谢谢了
12下一页
