请大师帮忙看看这I2C读写PCF8563怎么不对?这是stms单片机在stvd环境下进行编程? _Bool I2C_SDA @PC_ODR:1;//SDA管脚定义定义 _Bool I2C_SDAM @PC_IDR:1;//SDA管脚定义定义 _Bool I2C_SCL @PC_ODR:2;//SCL管脚定义 #define SET_SCL_OUT() {PC_DDR|=0X04; PE_CR1 |= 0X04;} #define SET_SDA_OUT() {PC_DDR|=0X02; PE_CR1 |= 0X02;} #define SET_SDA_IN() {PC_DDR&=0XFD; PE_CR1 |= 0X02;} //US带参数延时函数 void delayus(unsigned int us) { while(us--);//for(;;){;}// } void Delay_5us(void) { unsigned int i; for(i=10;i>0;i--); } /* void Delay_5us(void) { uchar i; //fcpu 8MHz 时 for (i=30; i>0; i--); }*/ //ms延时函数 void delay_ms(unsigned int ms) { unsigned int i,j; for(i=ms;i>0;i--) for(j=880;j>0;j--); } //串口定义 /*void USAT_k(voiv) { UART2_DDR1=0x08; UART2_DDR2=0x09; UART2_DDR3=0xaa; }*/ //I2C初始化 void I2C_Init(void) { // PC_DDR|=0x06;//0000 0110 // PC_IDR|=0X06;//0000 0110 SET_SDA_OUT(); SET_SCL_OUT(); I2C_SCL=HIGH; // I2C_SDA=HIGH;//SDA高电平 Delay_5us();//delay();//delayus(4);//延时2us I2C_SDA=HIGH;//SDA高电平 // I2C_SCL=HIGH;//SCL高电平 Delay_5us();//delay();//delayus(4);//延时2us } //-------------------------------------------------------------- // Prototype : void I2C_Start(void) // Calls : Delay_5us() // Description : Start Singnal //-------------------------------------------------------------- void I2C_Start(void) { // SDA 1->0 while SCL High SET_SDA_OUT(); SET_SCL_OUT(); I2C_SDA=HIGH; Delay_5us(); I2C_SCL=HIGH; Delay_5us(); I2C_SDA=LOW; Delay_5us(); } //-------------------------------------------------------------- // Prototype : void I2C_Stop(void) // Calls : Delay_5us() // Description : Stop Singnal //-------------------------------------------------------------- void I2C_Stop(void) { // SDA 0->1 while SCL High SET_SDA_OUT(); SET_SCL_OUT(); I2C_SCL=LOW; I2C_SDA=LOW;/*STOP:when CLK is high DATA change form low to high*/ Delay_5us(); I2C_SCL=HIGH; // Delay_5us(); I2C_SDA=HIGH; Delay_5us(); } //-------------------------------------------------------------- // Prototype : void I2C_SendACK(uchar ack); // Calls : Delay_5us() // Parameters : bit ack:1-noack, 0-ack // Description : Master device send ACK to slave device. //-------------------------------------------------------------- void I2C_SendACK(uchar ack) { uchar i=0; SET_SCL_OUT(); I2C_SCL=HIGH; Delay_5us(); SET_SDA_IN(); while((I2C_SDAM==1)&&(i<255)) i++; I2C_SCL=LOW; Delay_5us(); } //等待应答信号到来 //返回值:1,接收应答失败 // 0,接收应答成功 uchar IIC_Wait_Ack(void) { uchar ucErrTime=0; I2C_SDA=HIGH;Delay_5us(); I2C_SCL=HIGH;Delay_5us(); SET_SDA_IN(); while(I2C_SDAM) { ucErrTime++; if(ucErrTime>250) { I2C_Stop(); return 1; } } I2C_SCL=LOW; return 0; } //产生ACK应答 void IIC_Ack(void) { I2C_SCL=LOW; SET_SDA_OUT(); I2C_SDA=LOW; Delay_5us(); I2C_SCL=HIGH; Delay_5us(); I2C_SCL=LOW; } //不产生ACK应答 void IIC_NAck(void) { I2C_SCL=LOW; SET_SDA_OUT(); I2C_SDA=HIGH; Delay_5us(); I2C_SCL=HIGH; Delay_5us(); I2C_SCL=LOW; } //IIC发送一个字节 //返回从机有无应答 //1,有应答 //0,无应答 void IIC_Send_Byte(unsigned char txd) { unsigned char t; SET_SDA_OUT(); I2C_SCL=LOW;//拉低时钟开始数据传输 for(t=0;t<8;t++) { I2C_SDA=(txd&0x80)>>7; txd<<1; Delay_5us(); I2C_SCL=HIGH; Delay_5us(); I2C_SCL=LOW; Delay_5us(); } } //读1个字节,ack=1时,发送ACK,ack=0,发送nACK unsigned char IIC_Read_Byte(unsigned char ack) { unsigned char i,receive=0; SET_SDA_IN();//SDA设置为输入 for(i=0;i<8;i++) { I2C_SCL=LOW; Delay_5us(); I2C_SCL=HIGH; receive<<=1; if(I2C_SDAM)receive++; Delay_5us(); } if(!ack) IIC_NAck();//发送NACK else IIC_Ack();//发送ACK return receive; } //PCF8563写函数 //address:地址 //dat:参数 void write_Data(unsigned char address,unsigned char dat) { I2C_Start(); IIC_Send_Byte(0xa2); IIC_Wait_Ack(); IIC_Send_Byte(address);//发送地址 IIC_Wait_Ack(); IIC_Send_Byte(dat);//发送字节 IIC_Wait_Ack(); I2C_Stop();//产生一个停止条件 } //PCF8563读函数 //有返回值 //带入参数 unsigned char receive_Data(unsigned char regadd) { unsigned char temp=0; I2C_Start(); IIC_Send_Byte(0xa2);//发送写命令 IIC_Wait_Ack(); IIC_Send_Byte(regadd); IIC_Wait_Ack(); I2C_Start(); IIC_Send_Byte(0xa3);//进入接收模式 IIC_Wait_Ack(); temp=IIC_Read_Byte(0); I2C_Stop();//产生一个停止条件 return temp; } |
