stm32定时器输入捕获的问题
你好我好大家好! 提问时间:2015-7-1 18:12 /
现在用定时器做pwm捕获,计算pwm的频率,但是不知道为什么:引脚连接上固定频率的pwm信号后,捕获值为什么变化特别大:从0x00000080到0x0000D788,有么有大婶们遇到过这种情况啊,求指点?现贴代码如下:
       static void TIM_Config(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
  TIM_ICInitTypeDef  TIM_ICInitStructure;
  /* TIM1 ,TIM2 clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
  /* GPIOA clock enable*/
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
/*************************************** 配置TIM1产生固定频率的PWM*************************************/
   /* TIM1 channel 1 pin  configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
  /* Connect TIM pins to AF2*/
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_2);
  /* Time Base configuration */
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period = 0x9999;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 1000;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  /* TIM enable counter */
  TIM_Cmd(TIM1, ENABLE);
  /* TIM1 Main Output Enable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
/**********************************配置TIM2捕获TIM1发出固定的PWM信号***************************************/
   /* TIM2 channel 1 pin (PE.11) configuration */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_15;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  /* Connect TIM pins to AF2 */
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource15, GPIO_AF_2);
    TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
    TIM_TimeBaseStructure.TIM_Period = 65535;    // Set full 16-bit working range
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;
  TIM_ICInit(TIM2, &TIM_ICInitStructure);
  TIM_Cmd(TIM2, ENABLE);
  /* Enable the CC1 Interrupt Request */
  TIM_ITConfig(TIM2, TIM_IT_CC1, ENABLE);
  /* Enable the TIM1 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
赞 收藏 评论1 发布时间:2015-7-1 18:12
五哥1 回答时间:2018-5-2 19:13:23
芯片是啥?硬件有无干扰?板子是公版吗?再其他板子上测过程序吗?
