stm32 i2c中断接收,一直不能收到,配置如下,ST的FAE请帮助...
stary666 提问时间:2015-7-20 16:46 /
stm32 i2c中断接收,一直不能收到,配置如下,ST的FAE请帮助解答,谢谢!
各位大神,如有遇到类似问题,请提供解决方案,
我的配置如下:
void
I2C_Master_Receive_Config(I2C_DataStruct *st_RxData,
                          uint8_t         u8_MemAddr,
                          uint8_t        *pu8_Data,
                          uint16_t        u16_Size
    uint32_t u32_TimeOut;
    if (((uint8_t *)NULL == pu8_Data) || (0 == u16_Size))
        return;
    st_RxData->pu8_BuffPtr = pu8_Data;
    st_RxData->u16_Size    = u16_Size;
    //I2C_Master_Config(&gst_RxData,u8_MemAddr,st_RxData->u16_Size, I2C_GENERATE_START_READ,I2C_ISR_TC);
        u32_TimeOut = GET_SYSTEM_TICK_VALUE();
    while (__HAL_I2C_GET_FLAG(I2C_ISR_BUSY))
        if (GET_SYSTEM_TICK_ECLIPSE(u32_TimeOut) > CHECK_STATUS_TIMEROUT_TICK)
            break;
    /* 1: send 1 byte EEPROM start address  */
    I2C_TransferConfig(I2C1_SLAVE_ADDR, 1, I2C_CR2_AUTOEND, I2C_GENERATE_START_WRITE);
    while (!__HAL_I2C_GET_FLAG(I2C_ISR_TXIS))
            break;
    I2C_CHANNEL->TXDR = u8_MemAddr;
    /* Wait until TXE flag is set */
    while (!__HAL_I2C_GET_FLAG(I2C_ISR_TC))
            break;
        if (u16_Size > TXRX_DATA_MAX)
        st_RxData->u16_Count = TXRX_DATA_MAX;
    else
        st_RxData->u16_Count = u16_Size;
    if ((st_RxData->u16_Count == TXRX_DATA_MAX) && (st_RxData->u16_Count < u16_Size))
        I2C_TransferConfig(I2C1_SLAVE_ADDR, st_RxData->u16_Count, I2C_CR2_RELOAD, I2C_GENERATE_START_READ);
    else
        I2C_TransferConfig(I2C1_SLAVE_ADDR, st_RxData->u16_Count, I2C_CR2_AUTOEND, I2C_GENERATE_START_READ);
    I2C_CHANNEL->CR1  |= I2C_CR1_NACKIE | I2C_CR1_RXIE | I2C_CR1_TCIE;// | I2C_CR1_STOPIE;
赞 收藏 评论1 发布时间:2015-7-20 16:46
你好我好大家好! 回答时间:2015-7-21 10:08:11
好的
