stm32f030c8 读pcf8563
songwei2030 提问时间:2015-7-22 09:08 /
用stm32f030c8硬件iic 读pcf8563 实时时钟,在初步调试的时候就出现了问题,每次过8s就会week month数据就变了,很有规律,没找出什么原因,求助啊
下面是程序,希望大家给予指正,谢谢。
Function   : InitializeI2cGpio
Description: 初始化i2c的GPIO
Input      : 无
Output     : 无
Return     : 无
Others     :
static bool InitializeI2cGpio ( unsigned char type )
    GPIO_InitTypeDef  GPIO_InitStructure;
    if( type >= I2Cn )
        return false;
    /* Enable SCK and SDA GPIO clocks */
    RCC_AHBPeriphClockCmd(ST_I2C_CLK_GPIO_CLK_TABLE[type] | ST_I2C_SDA_GPIO_CLK_TABLE[type] , ENABLE);
    GPIO_PinAFConfig(ST_I2C_CLK_GPIO_PORT_TABLE[type], ST_I2C_CLK_SOURCE_TABLE[type], ST_I2C_CLK_AF_TABLE[type]);
    GPIO_PinAFConfig(ST_I2C_SDA_GPIO_PORT_TABLE[type], ST_I2C_SDA_SOURCE_TABLE[type], ST_I2C_SDA_AF_TABLE[type]);
    GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;//开漏
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;//sw
   // GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
    /* I2C SCK pin configuration */
    GPIO_InitStructure.GPIO_Pin = ST_I2C_CLK_PIN_TABLE[type];
    GPIO_Init(ST_I2C_CLK_GPIO_PORT_TABLE[type], &GPIO_InitStructure);
    /* I2C SDA pin configuration */
    GPIO_InitStructure.GPIO_Pin = ST_I2C_SDA_PIN_TABLE[type];
    GPIO_Init(ST_I2C_SDA_GPIO_PORT_TABLE[type], &GPIO_InitStructure);
    return true;
Function   : InitializeI2cConfig
Description: 初始化硬件I2C配置
Input      : clock = true 8M_400k false 8M_100k
Output     : 无
Return     : 无
Others     :
static bool InitializeI2cConfig ( unsigned char type ,bool clock )
    I2C_InitTypeDef   I2C_InitStructure;
    if( type >= I2Cn )
        return false;
   /* Enable the I2C periph source*/
   // RCC_I2CCLKConfig(RCC_I2C1CLK_HSI);
    RCC_I2CCLKConfig(RCC_I2C1CLK_SYSCLK);//48MHZSW
    RCC_APB1PeriphClockCmd(ST_I2C_CLK_TABLE[type], ENABLE); //Enable I2C1 Clock
    //初始I2C时钟 SW
    I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
    I2C_InitStructure.I2C_AnalogFilter = I2C_AnalogFilter_Enable;
    I2C_InitStructure.I2C_DigitalFilter = 0x00;
    I2C_InitStructure.I2C_OwnAddress1 = 0x00;
    I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
    I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
    if( clock )
       // I2C_InitStructure.I2C_Timing = EE_I2C_8MHZ_400KHZ_TIMING;//晶振修改为8MHZ sw
          I2C_InitStructure.I2C_Timing =  0x30E32E44;//0x00A0184D;//48M-400K
    else
        I2C_InitStructure.I2C_Timing = EE_I2C_8MHZ_100KHZ_TIMING;
    I2C_Init(ST_I2C_TABLE[type], &I2C_InitStructure);
    I2C_Cmd(ST_I2C_TABLE[type], ENABLE);
    return true;
Description: 初始化i2c
Input      : 无
Output     : 无
Return     : 无
Others     :
void  InitializeI2c ( bool clock )
    for(unsigned char i=0;i<I2Cn;i++)
       InitializeI2cGpio(i);
       InitializeI2cConfig(i , clock );
上面是初始化硬件IIC,剩下的会在下面跟上
收藏 评论6 发布时间:2015-7-22 09:08
6个回答
songwei2030 回答时间:2015-7-22 09:09:00
Function   : I2CDeviceRecv
Description: I2C主机接收数据
Input      : 无
Output     : 无
Return     : 无
Others     :
unsigned char I2CDeviceRecv( struct t_iic_device *p_device )
    uint32_t timeout = 0;
    uint32_t data_num;
    unsigned char  data;
    I2C_LOSE_POWE_HANDLE();
    if (( p_device->reg_len == 0) || ( p_device->data_len == 0))
        return I2C_OPERATE_FAIL ;
    if ( p_device->reg_len > 4 )
    add_index  = p_device->reg_len;
    data_index = 0;
    /* Test on BUSY Flag */
    timeout = E2PROM_LONG_TIMEOUT;
    while( I2C_GetFlagStatus(p_device->iic_base, I2C_ISR_BUSY) != RESET )
        //操作前先喂狗
        FeedIWDG();
        FeedOSWDG();
        if((timeout--) == 0)
            return I2C_OPERATE_FAIL;
    /* Configure slave address, nbytes, reload and generate start */
    I2C_TransferHandling(p_device->iic_base, p_device->dev_addr, p_device->reg_len, I2C_SoftEnd_Mode, I2C_Generate_Start_Write);
    /* Wait until TXIS flag is set */
    while(I2C_GetFlagStatus(p_device->iic_base, I2C_ISR_TXIS) == RESET)
        //操作前先喂狗
        FeedIWDG();
        FeedOSWDG();
    /* Send memory address */
    while( add_index )
        I2C_SendData( p_device->iic_base , p_device->p_reg_addr[add_index-1] );
        add_index--;
        if( add_index == 0 )
            /* Wait until TC flag is set */
            while(I2C_GetFlagStatus(p_device->iic_base, I2C_ISR_TC) == RESET)
                //操作前先喂狗
                FeedIWDG();
                FeedOSWDG();
        else
                //操作前先喂狗
                FeedIWDG();
                FeedOSWDG();
    data_num   = (p_device->data_len)/255;
    data = (p_device->data_len)%255;
    while( data_num )
        data_index = 255;
        /* Configure slave address, nbytes, reload, end mode and start or stop generation */
        I2C_TransferHandling(p_device->iic_base, p_device->dev_addr, data_index, I2C_AutoEnd_Mode, I2C_Generate_Start_Read);
        /* Wait until all data are received */
        while ( data_index )
            /* Wait until RXNE flag is set */
            while(I2C_GetFlagStatus(p_device->iic_base, I2C_ISR_RXNE) == RESET)
                //操作前先喂狗
                FeedIWDG();
                FeedOSWDG();
            /* Read data from RXDR */
            *(p_device->p_data) = I2C_ReceiveData(p_device->iic_base);
            /* Point to the next location where the byte read will be saved */
            (p_device->p_data)++;
            /* Decrement the read bytes counter */
            data_index--;
        data_num--;
    data_index = data;
    if( data_index !=0 )
        I2C_TransferHandling(p_device->iic_base, p_device->dev_addr, (unsigned char)data_index, I2C_AutoEnd_Mode, I2C_Generate_Start_Read);
                //操作前先喂狗
                FeedIWDG();
                FeedOSWDG();
            data_index--;
    /* Wait until STOPF flag is set */
    while(I2C_GetFlagStatus(p_device->iic_base, I2C_ISR_STOPF) == RESET)
        //操作前先喂狗
        FeedIWDG();
        FeedOSWDG();
    /* Clear STOPF flag */
    I2C_ClearFlag(p_device->iic_base, I2C_ICR_STOPCF);
    /* If all operations OK */
    return I2C_OPERATE_SUCC;
songwei2030 回答时间:2015-7-22 09:10:05
RTC时钟的初始化
void InitializeTimerManage( void )
   unsigned char config1 = 0x00;
                                  /*reg_ctrl1
                                          STOP = 0;SW*/
   unsigned char config2 = 0x01;
                                        /*Reg_ctrl2
                                            AIE = 0;
                                            TIE = 1;
                                          TI/TP = 0; SW */
   unsigned char timer1 = 0x82;     /*reg_timer
                                     TE = 1
                                     tiemr source clock  = 1 hz*/
    unsigned week ;
    struct t_rtc_time time ;
    struct t_date* p_data   = ( struct t_date* )(&(time.week)) ;
    struct t_clock* p_clock = ( struct t_clock* )(&(time.sec)) ;
    WritePCF8563( PCF8563_REG_CTRL1 , 1 , &config1); //使能RTC
    ReadPCF8563( PCF8563_REG_CTRL1 , 1 , &config1);
    WritePCF8563( PCF8563_REG_CTRL2 , 1 , &config2);  //使能AIE TIEsw
    ReadPCF8563( PCF8563_REG_CTRL2 , 1 , &config2);
    WritePCF8563(PCF8563_TIME_CTRL , 1 , &timer1);
     ReadPCF8563(PCF8563_TIME_CTRL , 1 , &timer1);
    //读取成功
    if( ReadRTCTime( (unsigned char*)&time ) )
            memcpy( &time , &const_rtc_time , sizeof(struct t_rtc_time) );
        WriteRTCTime( (unsigned char*)&time );
        ReadRTCTime ( (unsigned char*)&time );
        time.week = week ;
        memcpy( &current_time , &time , sizeof( struct t_rtc_time ) ) ;
songwei2030 回答时间:2015-7-22 09:12:25
这个是我验证pcf8563时做的代码验证
bool ReadPCF8563( uint32_t offset , uint32_t len , unsigned char* p_data )
    unsigned char  reg_add ,loop  = 3;
    unsigned char  result = false;
    while( loop-- )
        //读取失败
       //if ( I2CDeviceRecv( &iic_deviece ) )
         if (I2C1_Read_NBytes(PCF8563_I2C_ADDR_READ, 0x02, 7, p_data));
            result = true;
            break;
    return result;
stary666 回答时间:2015-7-22 09:25:42
之前用过1768读写8563
songwei2030 回答时间:2015-7-22 09:43:35
stary666 发表于 2015-7-22 09:25
之前用过1768读写8563
能不能把你的代码发给我,谢谢978821301@qq.com
stary666 回答时间:2015-7-22 12:21:30
公司不能上QQ
