外部计数STM32 ETR计算频率问题
小武555 提问时间:2015-7-22 15:01 /
我用外部计数STM32 ETR计算频率,测量100K频率,用定时器2定时1S,定时器三PD2(TIM3_ETR)计数,计算公式f=n/t;测量出来的结果是9999 HZ,整整少了一位数字,这是什么原因呢,大家分析一下,谢谢,附我的程序
void Time3_Configuration()
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
  TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);  // Time base configuration
  TIM_ETRClockMode2Config(TIM3, TIM_ExtTRGPSC_OFF, TIM_ExtTRGPolarity_NonInverted, 0);
  //TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
  TIM_SetCounter(TIM3, 0);
  TIM_Cmd(TIM3, ENABLE);
        /*1S定时*/
void Tim2_Config(void)
   TIM_TimeBaseInitTypeDef   TIM2_TimeBaseStructure;
   TIM_DeInit(TIM2);
   TIM2_TimeBaseStructure.TIM_Period =999;
   TIM2_TimeBaseStructure.TIM_Prescaler = (7200-1);
   TIM2_TimeBaseStructure.TIM_ClockDivision = 0x0;//ÉèÖÃʱÖÓϵÊý ²»·ÖƵ
  TIM2_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//ÏòÉϼÆÊýģʽ
   TIM_TimeBaseInit(TIM2, &TIM2_TimeBaseStructure); // Time base configuration
   TIM_ClearFlag(TIM2,TIM_FLAG_Update);//Çå³þ¸üбê־λ
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
   TIM_Cmd(TIM2, ENABLE);
   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
最后的计算部分:
void TIM2_IRQHandler(void)
       if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
            TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
            CAPTURE1=(u32)TIM_GetCounter(TIM3);
       sum+=CAPTURE1;
       count++;
       if(count==4)
        Frequency1=sum/4;//求频率公式F=n/t;这里求了4次的计数平均值,结果是1S的频率
       sum=0;
        count=0;
       TIM_SetCounter(TIM3,0);
赞 收藏 评论18 发布时间:2015-7-22 15:01
18个回答
小武555 回答时间:2015-7-23 14:27:52
Mandelbrot_Set 发表于 2015-7-23 14:01
考虑到65536+34456 月月等于 100000 排查下是否存在溢出
对,考虑到16位定时器65536会溢出,我定时250MS,现在测试100K-130K频率误差在8HZ-12HZ,不过每次测量频率变化,测量出来的数值有些不稳定 有些波动4HZ,怎么解决这个问题呢
小武555 回答时间:2015-7-23 09:58:06
Mandelbrot_Set 发表于 2015-7-22 16:49
定时器2定时不是1S吧..
刚才是0.1S,现在是定时1S,
TIM2_TimeBaseStructure.TIM_Period =9999;
测量100K怎么是34456 HZ.大家分析一下
小武555 回答时间:2015-7-24 09:43:55
Mandelbrot_Set 发表于 2015-7-23 15:20
现在250MS测计数值,计数值的抖动为1,就意味着4Hz.(T2与波形同步下可能好些)
抖动无法避免,因为微调频率一定 ...
你说的测M个周期所用的时间.应该怎么做,我现在就是外部计数F=N/T,这么算的
废鱼 回答时间:2015-7-22 15:10:33
TIM3中断加IO输出,用示波器测试一下波形。
stary666 回答时间:2015-7-22 15:40:34
没有研究过,顶
Mandelbrot_Set 回答时间:2015-7-22 16:49:21
定时器2定时不是1S吧..
小武555 回答时间:2015-7-23 09:16:42
定时器2定时不是1S吧..
那你认为是好多
小武555 回答时间:2015-7-23 09:17:47
目的是什么,TIM3只是计数
废鱼 回答时间:2015-7-23 11:44:18
小武555 发表于 2015-7-23 09:17
目的是什么,TIM3只是计数
示波器测试TIM3的实际间隔。
埃斯提爱慕 回答时间:2015-7-23 12:55:01
Mandelbrot_Set 回答时间:2015-7-23 14:01:26
小武555 发表于 2015-7-23 09:58
刚才是0.1S,现在是定时1S,
  TIM2_TimeBaseStructure.TIM_P ...
sting 回答时间:2015-7-23 14:15:52
你回啦,我还在等他继续出这个错。
Mandelbrot_Set 回答时间:2015-7-23 14:22:47
sting 发表于 2015-7-23 14:15
你回啦,我还在等他继续出这个错。
这...
Mandelbrot_Set 回答时间:2015-7-23 15:20:46
抖动无法避免,因为微调频率一定能到达产生质变(+1)的临界点.
另外可以式式测M个周期所用的时间.
12下一页
