F411DMA方式4通道AD的C问题
me浩 提问时间:2015-7-29 10:39 /
代码如下,为什么采集回来只有两个数据而且跳变很大?求指导。
void Adc_DMA_Init(void)
//----------------------------初始化DMA----------------------------//
        ADC_InitTypeDef  ADC_InitStructure;
        ADC_CommonInitTypeDef ADC_CommonInitStructure;
        DMA_InitTypeDef  DMA_InitStructure;
        RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_DMA2 |
                                                        RCC_AHB1Periph_GPIOA|
                                                        RCC_AHB1Periph_GPIOC, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); //使能ADC1时钟
        DMA_InitStructure.DMA_Channel = DMA_Channel_0;  //通道选择
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;//(uint32_t)&ADC1->DR
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&AD;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
        DMA_InitStructure.DMA_BufferSize = 4;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址不变
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;//内存地址递增
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
        DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
        DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
        DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
        DMA_Init(DMA2_Stream0,&DMA_InitStructure);
        DMA_Cmd(DMA2_Stream0,ENABLE);
        //先初始化ADC1通道1,4 IO口
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4;//PA1 通道1,PA4 通道4
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;//模拟输入
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;//不带上下拉
        GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化
        //先初始化ADC1通道10,11 IO口
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;//PC0 通道10,PC1 通道11
        GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化
//----------------------------初始化ADC----------------------------//
        ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;//独立模式
        ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;//两个采样阶段之间的延迟5个时钟
        ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1; //DMA失能
        ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div8;//预分频4分频。ADCCLK=PCLK2/4=84/4=21Mhz,ADC时钟最好不要超过36Mhz
        ADC_CommonInit(&ADC_CommonInitStructure);//初始化
        ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;//12位模式
        ADC_InitStructure.ADC_ScanConvMode = ENABLE;//扫描模式
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//连续转换
        ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;//禁止触发检测,使用软件触发
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右对齐
        ADC_InitStructure.ADC_NbrOfConversion = 4;//1个转换在规则序列中 也就是只转换规则序列1
        ADC_Init(ADC1, &ADC_InitStructure);//ADC初始化
        ADC_RegularChannelConfig(ADC1,ADC_Channel_10,1,ADC_SampleTime_15Cycles);
        ADC_RegularChannelConfig(ADC1,ADC_Channel_11,2,ADC_SampleTime_15Cycles);
        ADC_RegularChannelConfig(ADC1,ADC_Channel_1,3,ADC_SampleTime_15Cycles);
        ADC_RegularChannelConfig(ADC1,ADC_Channel_4,4,ADC_SampleTime_15Cycles);
        ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
        ADC_DMACmd(ADC1,ENABLE);//使能ADC的DMA传输
        ADC_Cmd(ADC1, ENABLE);//开启AD转换器
        ADC_SoftwareStartConv(ADC1);        //连续转换开始,ADC通过DMA方式不断的更新RAM区。
赞 收藏 评论5 发布时间:2015-7-29 10:39
5个回答
废鱼 回答时间:2015-7-29 11:02:29
楼主能说一下如何处理采集的数据吗?最好有详细的数据对比和说明。
me浩 回答时间:2015-7-29 12:07:38
还没采回来呢,求平均就可以了吧。或者麻烦点的冒泡法,取中间的量,再求均值。
stary666 回答时间:2015-7-29 12:16:05
很少用DMA
你好我好大家好! 回答时间:2015-7-29 13:56:03
帮顶
嗅嗅匆匆 回答时间:2015-7-31 11:55:22
问下楼主F411的DMA的各通道对应的外设表在哪下载?
