ST SPI DMA接收异常
zhuo1000 提问时间:2015-8-3 15:53 /
   芯片:STM32f405,  做的功能是SPI的dma传输,
      st正常接收是这样的,0xAB 0xBA 0xA0 ~~~~~~
       假如出现异常   0x0 0xAB 0xBA 0xA0~~~~~
       出现这种情况,我如何让系统SPI恢复,能正常接收。
附:
附:
void DMA2_Stream0_IRQHandler(void)
  GPIOB->BSRRH = GPIO_Pin_5;
  /* Test on DMA Stream Transfer Complete interrupt */
  //if (DMA_GetFlagStatus(SPIx_RX_DMA_STREAM,SPIx_RX_DMA_FLAG_TCIF))
  if(DMA_GetITStatus(SPIx_RX_DMA_STREAM, DMA_IT_TCIF0))
     DMA_ClearITPendingBit(SPIx_RX_DMA_STREAM, DMA_IT_TCIF0);
     DMA_ClearFlag(SPIx_RX_DMA_STREAM,SPIx_RX_DMA_FLAG_TCIF);
            ab =spi_aRxBuffer[0];
             ba =spi_aRxBuffer[1];
            spi_head_cmd =spi_aRxBuffer[2];
       if((ab ==0xAB) &&  (ba ==0xBA ))
                  spi_deal_handle(package_status);
                    ab =0;
                    ba =0;
           else  //这是异常处理,但是我发现没有恢复正常
                        dma_reinit();
函数如下:
void dma_reinit(void)
     DMA_Cmd(SPIx_RX_DMA_STREAM,DISABLE);
     DMA_ClearFlag(SPIx_RX_DMA_STREAM,DMA_FLAG_TEIF0 | DMA_FLAG_DMEIF0 | DMA_FLAG_FEIF0);
void spi_receive_data_enable(void)
  //DMA_DeInit(SPIx_TX_DMA_STREAM);
  DMA_DeInit(SPIx_RX_DMA_STREAM);
  /* Configure DMA Initialization Structure */
  DMA_InitStructure.DMA_BufferSize = SPI_BUFFERSIZE ;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable ;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull ;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_INC4;//DMA_MemoryBurst_Single ;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_PeripheralBaseAddr =(uint32_t) (&(SPIx_WIFI->DR)) ;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  /* Configure TX DMA */
//  DMA_InitStructure.DMA_Channel = SPIx_TX_DMA_CHANNEL ;
//  DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral ;
//  DMA_InitStructure.DMA_Memory0BaseAddr =(uint32_t)spi_aTxBuffer ;
//  DMA_Init(SPIx_TX_DMA_STREAM, &DMA_InitStructure);
  /* Configure RX DMA */
  DMA_InitStructure.DMA_Channel = SPIx_RX_DMA_CHANNEL ;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory ;
  DMA_InitStructure.DMA_Memory0BaseAddr =(uint32_t)spi_aRxBuffer ;
  DMA_Init(SPIx_RX_DMA_STREAM, &DMA_InitStructure);
    SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
   SPI_Init(SPIx_WIFI, &SPI_InitStructure);
            //DMA_ClearFlag(SPIx_RX_DMA_STREAM,SPIx_RX_DMA_FLAG_TCIF);
        DMA_ITConfig(SPIx_RX_DMA_STREAM, DMA_IT_TC, ENABLE); //wyz add
        DMA_Cmd(SPIx_RX_DMA_STREAM,ENABLE);
         SPI_I2S_DMACmd(SPIx_WIFI, SPI_I2S_DMAReq_Rx, ENABLE);
        SPI_Cmd(SPIx_WIFI, ENABLE);
  spi_receive_data_enable();
收藏 评论2 发布时间:2015-8-3 15:53
zhuo1000 回答时间:2015-8-3 15:55:12
我的思路是,接收异常,我清理掉错误标志,spi disable,然后重新初始化
DMA_InitStructure.DMA_Memory0BaseAddr =(uint32_t)spi_aRxBuffer ; ,再使能。但是这样做,还是没能恢复正常。
你好我好大家好! 回答时间:2015-8-3 21:49:19
帮顶
