STM32官方免费开发环境安装包,2015年7月24日更新.
wjandsq 发布时间:2015-8-11 12:59
STM32官方免费开发环境System Workbench for STM32安装包, 2015年7月24日更新,后续会放到网盘提供下载。
9 n0 m% V" U* G! }' R
) Z' x* S8 |  J( x6 ]7 oThe installer is available for different host environments; please select the appropriate installer8 ?3 a+ I3 G/ I2 k' l2 x# Y7 o  A
depending on your host machine./ i4 Z$ k4 t; Y
5 ]5 s4 G# A, |Latest version
* U$ f: t" y( W- u8 F* x3 m
9 d1 Q: ~4 W3 L; c: D' s/ TWe advise you to always install the latest System Workbench for STM32 version, to benefit from all
: H# I! y( y2 h, b  Cenhancements and have support for all the newest STM32 chips.
5 G& \% o1 r2 o2 M% j! P9 `$ A. D- L% X$ @9 x' Q, y, P' L, l
Note this installer is only meant to be used for initial installation. To upgrade an existing System  \6 h/ ?, h$ u" u; r: r
Workbench for STM32, you should rather go to "Help >> Search for Updates..." in System Workbench
% E1 A# Y# x% y- X' {for STM32; doing this will upgrade all the components for which a new release exist, including all
' L* Q$ }/ }7 g5 Tthe Eclipse infrastructure.. b! D% U, l  \& B4 x& Q' J5 J
8 t6 C6 L2 j' F0 G0 l7 _
Windows 7/ Z; I' v- d) N; z0 x8 L
4 H3 m- Y# \9 B. _) ~! }( ]& n5 @
The Windows version is available for 32 and 64 bit systems. Note that we will need to install a device
0 ]9 X) w% z% s3 f; U5 a3 Rdriver to communicate with the ST-Link debug probe, so you must select the installer that fits your3 L* `6 @9 d* N- U) x
system. Installing the 32 bit version on a 64 bit Windows system will not work.
5 C9 u7 }/ x$ x5 O! t4 M( i) Q+ K4 ~
& W1 Y# A, ]& b. ]Latest Windows 7 64 bit installer (Version v1.3, updated on Friday, July 24, 2015 at 12:44:45 CEST):
* k- W( a3 G2 z# L1 c. ninstall_sw4stm32_win_64bits-v1.3.exe
  W! i* E5 G+ x( i' {' oThe latest installer can always be retrieved from install_sw4stm32_win_64bits-latest.exe
& t: J1 ~  [0 E8 i! c
; n0 \( y- d9 M7 H4 VLatest Windows 7 32 bit installer (Version v1.3, updated on Friday, July 24, 2015 at 12:52:28 CEST): 4 T  n: T  i- o
install_sw4stm32_win_32bits-v1.3.exe  _2 g: b) r3 ~4 ~& |7 @- I
The latest installer can always be retrieved from install_sw4stm32_win_32bits-latest.exe
' I1 q% o/ _/ u/ M+ A  ?8 c! XLinux
$ T( ?- T/ K: a' J  L6 B
3 _+ C) Z/ q2 \/ j, cTo be able to download and test System Workbench for STM32 on Linux, you should request access to
) C0 w& k4 S5 v! p: _4 u' D9 j4 n) sSystem Workbench as beta tester by sending a mail to the webmaster explaining why you would like to
" e% E5 N/ q0 [became a beta tester.0 j1 ^. P7 Q% y- b7 ^& Y1 t
4 R; V) i# E6 b( g1 R( s. U. i以下是中文备注:
2 y0 p- @% g8 F2 P" T
; l: k) H! Q7 F% |, [  hST公司提供的免费开发环境 2015年7月24日更新,基于Eclipse + GCC ARM工具链修改的:
( a% c+ d7 x, l0 ?, l% `( xhttp://www.ac6-tools.com/downloads//SW4STM32/install_sw4stm32_win_64bits-v1.3.exe
  E7 I5 y* B& c! h1 mhttp://www.ac6-tools.com/downloads//SW4STM32/install_sw4stm32_win_32bits-v1.3.exe
8 r$ n+ c* \2 M1 }% {  o6 O% B  |4 }0 L/ P& U. \
32位的软件包在64位系统下,官方的说法是不能正常工作。可以在基于开普勒版本Eclipse,自行安装插件,
% \/ t6 Q+ f, Z但可能会出现一些问题,如果不是高手可能解决不了。建议使用上面的安装包直接安装。
) A0 x7 g5 L$ `9 ~- y$ T$ |使用最新版本的Eclipse 安装插件,估计不能工作。
8 f) Q& M( M4 {- D7 }. L1 m! @6 H; m% i' E) I2 ?
使用这个开发环境,仿真目前只支持STLINKV2、STLINKV2-1,目前直接安装的测试结果:在XP SP3上安装 install_sw4stm32_win_32bits-latest.exe 测试可以正常仿真调试F407ZE,使用STLINKV2-1、标准外设驱动库1.5.1., c: v  ]: c$ D+ M1 [! ]: y
在WIN10 X64上安装 install_sw4stm32_win_64bits-latest.exe 上测试可以正常仿真调试F429Z,使用STLINKV2、标准外设驱动库1.5.1. ( O9 K) s" X3 N1 u' H6 K! K/ M
! T% z: Y( G( F: `/ N+ U0 c
& H" I6 s! B% U
以上两个安装包不支持JLINK,ULINK2仿真器,但理论上安装开普勒的Eclipse IDE后,用升级插件的办法,应该可以& l! d. Q6 W0 C; C1 e5 s
支持J-Link、ULINK2等,具体没有实验。
0 \; {. D/ m5 r  M& T2 {
+ N0 O+ k$ W1 X! }- G* Q
0 a! t! w0 y/ E: y. `. ?4 `$ ?6 A! x6 r9 k
7 S! A' b- s/ h0 O  g" e; x  x/ J% r; b! x5 v& \
赞 收藏 2 评论8 发布时间:2015-8-11 12:59
8个回答
我是熊猫大仙 回答时间:2015-8-11 13:33:23
这个就是基于Eclipse的IDE,装上插件就可以支持JLink了- n3 V+ F9 j1 A3 W9 Y/ X3 \2 n5 b; Z, s
http://gnuarmeclipse.livius.net/blog/jlink-install/
wjandsq 回答时间:2015-8-11 14:20:57
, J( R2 F7 j% d$ G; [$ U4 c+ [+ r) o9 t
原版Eclipse很早支持JLINK,但对于F4系列仅支持HAL库,不支持标准外设驱动库。
6 y1 I) B- {# ?" l- M我发过最新的链接, 大侠电子网下载站点:, C' l6 z) k; G( W2 B, u
1. eclipse-cpp-mars-R-win32-x86_64.zip
/ X# p: t1 N7 F8 {$ i2. ilg.gnuarmeclipse.repository-2.9.2-201508071246.zip
9 f7 I) E9 X* ?& N1 A# r. U3. gcc-arm-none-eabi-4_9-2015q2-20150609-win32.exe  S4 W( R- r, O7 j; d: d
4. gnuarmeclipse-build-tools-win64-2.6-201507152002-setup.exe
" ^) l( \; M$ Z3 O( ]! W5. gnuarmeclipse-openocd-win64-0.9.0-201505190955-setup.exe
! e8 ~4 V0 Q9 ]2 {' O6. gnuarmeclipse-qemu-win64-2.3.50-201508051820-dev-setup.exe
2 ?% Z2 S! o' X5 a9 b* ]/ c" F7. http://www.daxia.com/wj/www/software/GCC/Setup_JLink_V500c.zip
: U; |  _+ I% s4 }3 r8. http://www.daxia.com/wj/www/software/GCC/stsw-link009.zip7 C/ R! @# }2 r; C' m' j  u
6 Z$ Z4 ]1 z. C/ d官方下载站点:
- t7 v+ x( ]  i* X1. eclipse-cpp-mars-R-win32-x86_64.zip (Eclipse Mars (4.5) Release)& H! J1 \+ e& e8 L4 J
   http://www.eclipse.org/downloads/
. k/ k$ n+ J2 o   http://ftp.jaist.ac.jp/pub/eclip ... -R-win32-x86_64.zip8 X; m, T& d# l0 U
3 }+ v% y5 i8 S/ F" o; t   http://sourceforge.net/projects/ ... es/Eclipse/updates/
& l1 A: ^  K4 y2 m$ W; b5 X   http://nchc.dl.sourceforge.net/p ... .2-201508071246.zip
! M, {  S& X3 T; N3. gcc-arm-none-eabi-4_9-2015q2-20150609-win32.exe
* K5 K/ G! b1 R7 ]# j9 n1 z8 j   http://launchpad.net/gcc-arm-embedded/+download+ Q& r* [) W4 ^3 b
   http://launchpadlibrarian.net/2 ... -20150609-win32.exe
4 J, h" c4 x7 `$ F2 ~, ?4. gnuarmeclipse-build-tools-win64-2.6-201507152002-setup.exe
9 Q+ u  j+ C% Y% z) ]: k6 l% c4 s% p   http://sourceforge.net/projects/ ... iles/Build%20Tools/
  \9 @1 n" j' x9 v" P   http://jaist.dl.sourceforge.net/ ... 507152002-setup.exe
6 y6 l  O* B0 A   http://sourceforge.net/settings/ ... 507152002-setup.exe
. h+ p; N+ v' ~- @. e) ~5. gnuarmeclipse-openocd-win64-0.9.0-201505190955-setup.exe8 ], y/ k1 K4 e6 V- u# g/ l. C' w
   http://sourceforge.net/projects/ ... es/OpenOCD/Windows/, B. {2 O6 S( Y7 b: A8 V! t
   http://nchc.dl.sourceforge.net/p ... 505190955-setup.exe3 Z7 M9 @$ K& i: H" ~: ~
6. gnuarmeclipse-qemu-win64-2.3.50-201508051820-dev-setup.exe! o' _3 q9 w: k9 G1 D) a
   http://sourceforge.net/projects/gnuarmeclipse/files/QEMU/Windows/5 h& A' G+ k0 B" u, V
   http://jaist.dl.sourceforge.net/ ... 51820-dev-setup.exe% j  w4 v8 q& ~
yanhaijian 回答时间:2015-8-11 14:51:47
不错,以后再也不用担心版权问题了。
moyanming2013 回答时间:2015-8-11 16:00:00
你说了那么多,愣是没找到哪个是官方的网址???
你好我好大家好! 回答时间:2015-8-11 18:06:56
不知道好用否
我是熊猫大仙 回答时间:2015-8-11 18:43:02
moyanming2013 发表于 2015-8-11 16:00
% `( }% P$ ^" C' F( ~3 T你说了那么多,愣是没找到哪个是官方的网址???
3 ?. @$ ^1 i- b. C: M- Fopenstm32.org
$ S- ^1 |+ r/ ^* Z& M# w社区还可以,jlink上面有说到的帖子
jcx0324 回答时间:2015-8-21 15:35:36
不是还有个coocox嘛,也用GCC
wjandsq 回答时间:2015-8-21 16:25:42
测试在Kepler_Eclipse上安装Ac6插件,stlink调试正常,界面友好的Eclipse才是主流。
