stm32f303 串口不能正常工作
wujiazier 提问时间:2015-9-4 12:19 /
不能正确接收数据(RDR里面能接收数据,但不正确),我PC端发送3,RDR显示是0x0FE,波特率都是115200啊;发送的时候,TDR里能够显示正确的发送数据,但是IO口那收不到任何数据,IO口配置应该没什么问题啊,要不然怎么能够对PC端发送的数据有反映呢,请大家帮忙,谢谢了!
void tiaoshi(void)
    NVIC_InitTypeDef NVIC_InitStruct;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_6 | GPIO_Pin_7);   //USART2对应的RX,TX引脚
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;             //复用模式
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;         //推挽输出
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    //配置复用功能
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_7);
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_7);
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    NVIC_InitStruct.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStruct);
    USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_DeInit(USART1);
    USART_Init(USART1, &USART_InitStructure);
    //USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);//使能中断
    USART_ClearFlag (USART1,USART_FLAG_TC);
    USART_Cmd(USART1, ENABLE);    //打开串口
    while(1)
        USART_SendData(USART1,4);
        // USART in mode Tramitter ------------------------------------------------
        if (USART_GetITStatus(USART1, USART_IT_TXE) == SET)
            USART_SendData(USART1, Receive);
            //Disable the USARTx transmit data register empty interrupt
            USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
        //* USART in mode Receiver --------------------------------------------------
        if ((USART_GetITStatus(USART1, USART_IT_RXNE) == SET)||(USART_GetITStatus(USART1, USART_IT_ORE) == SET))
            //Receive = USART_ReceiveData(USART1);
            //USART_SendData(USART1, Receive);
            USART_SendData(USART1,USART_ReceiveData(USART1));
            while (!USART_GetFlagStatus(USART1,USART_FLAG_TC));
赞 收藏 评论9 发布时间:2015-9-4 12:19
9个回答
你好我好大家好! 回答时间:2015-9-4 12:30:48
是不是硬件连接问题
wujiazier 回答时间:2015-9-4 12:40:01
C:\Users\TUOLAJI\Desktop\QQ截图20150904123725.png硬件是直接连接的,PC端用的是USB转ttl的电路
JackieLaura 回答时间:2015-9-4 15:44:08
明显的配置问题,串口的两个脚都配成了输出
wujiazier 回答时间:2015-9-4 15:55:29
这单片机是M4的,似乎IO不用特意配置成输入,而且,现在对我发的不同数据,单片机也能有不同的响应,只是不是正确的数据。
JackieLaura 回答时间:2015-9-4 15:58:43
wujiazier 发表于 2015-9-4 15:55
这单片机是M4的,似乎IO不用特意配置成输入,而且,现在对我发的不同数据,单片机也能有不同的响应,只是 ...
这个但是没有注意过,下次用303试试看。
JackieLaura 回答时间:2015-9-4 16:22:39
开启了中断怎么没有中断函数?
wujiazier 回答时间:2015-9-4 18:04:29
JackieLaura 发表于 2015-9-4 16:22
开启了中断怎么没有中断函数?
这是调试用的,中断处理函数里面就是这个while循环里的东西,我临时把中断使能关闭了
wujiazier 回答时间:2015-9-4 20:40:11
我知道什么原因了,当时库里默认是8MHZ的主频,而实际上是12M主频,需要在库函数里面更改为12MHZ才可以,因为之前波特率是根据8MHZ进行计算的
你好我好大家好! 回答时间:2015-9-5 21:44:08
那就不知道了
