我要用stm8l152读6路AD值,所以用DMA方式,用的是例程,但发现有移位现象,就是第一个AD值会到第二 第三 第四个的现象,代码如下,求大家帮我看看什么原因 /* Enable ADC1 clock */ CLK_PeripheralClockConfig(CLK_Peripheral_ADC1, ENABLE); /* Enable DMA1 clock */ CLK_PeripheralClockConfig(CLK_Peripheral_DMA1, ENABLE); ADC_DeInit(ADC1); // DMA_GlobalDeInit(); // DMA_DeInit(DMA1_Channel0); ADC_Init(ADC1, ADC_ConversionMode_Continuous, ADC_Resolution_10Bit, ADC_Prescaler_1); ADC_SamplingTimeConfig(ADC1, ADC_Group_SlowChannels, ADC_SamplingTime_384Cycles); ADC_SamplingTimeConfig(ADC1, ADC_Group_FastChannels, ADC_SamplingTime_384Cycles); /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); /* Enable ADC1 Channels 3 */ ADC_ChannelCmd(ADC1, ADC_Channel_3, ENABLE); /* 大电流1 */ /* Enable ADC1 Channels 4 */ ADC_ChannelCmd(ADC1, ADC_Channel_4, ENABLE); /* 大电流2 */ /* Enable ADC1 Channels 5 */ ADC_ChannelCmd(ADC1, ADC_Channel_5, ENABLE); /* 2灯电流 */ /* Enable ADC1 Channels 11 */ ADC_ChannelCmd(ADC1, ADC_Channel_11, ENABLE); /* 1灯电流 */ /* Enable ADC1 Channels 12 */ ADC_ChannelCmd(ADC1, ADC_Channel_12, ENABLE); /* USB电流 */ /* Enable ADC1 Channels 13 */ ADC_ChannelCmd(ADC1, ADC_Channel_13, ENABLE); /* 电池电压 */ /* Connect ADC to DMA channel 0 */ SYSCFG_REMAPDMAChannelConfig(REMAP_DMA1Channel_ADC1ToChannel0); DMA_Init(DMA1_Channel0, AD_BUFFER_ADDRESS, ADC1_DR_ADDRESS, AD_BUFFER_SIZE, DMA_DIR_PeripheralToMemory, DMA_Mode_Circular, DMA_MemoryIncMode_Inc, DMA_Priority_High, DMA_MemoryDataSize_HalfWord); /* DMA Channel0 enable */ DMA_Cmd(DMA1_Channel0, ENABLE); /* Enable DMA1 channel0 Transfer complete interrupt */ DMA_ITConfig(DMA1_Channel0, DMA_ITx_TC, ENABLE); /* DMA enable */ DMA_GlobalCmd(ENABLE); /* Enable ADC1 DMA requests*/ ADC_DMACmd(ADC1, ENABLE); /* Start ADC1 Conversion using TIM1 TRGO*/ ADC_SoftwareStartConv(ADC1); |
/* DMA enable */
===>二者换个顺序看看
/* DMA enable */
