中断设置问题
guo8113 提问时间:2015-10-14 21:18 /
  • <p>//参考手册上代码如下</p><p>NVIC_InitTypeDef NVIC_InitStructure;
  • /* Configure the Priority Grouping with 1 bit */
  • NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  • /* Enable TIM3 global interrupt with Preemption Priority 0 and SubPriority as 2 */
  • NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQChannel;
  • NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  • NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
  • NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  • NVIC_InitStructure(&NVIC_InitStructure);
  • /* Enable USART1 global interrupt with Preemption Priority 1 and SubPriority as 5 */
  • NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
  • NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  • NVIC_InitStructure.NVIC_IRQChannelSubPriority = 5;
  • /* Enable <font color="red">RTC</font> <font color="red">global interrupt</font> with Preemption Priority 1 and SubPriority as 7 */
  • NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQChannel;
  • NVIC_InitStructure.NVIC_IRQChannelSubPriority = 7;
  • /* Enable EXTI4 interrupt with Preemption Priority 1 and SubPriority as 7 */
  • NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQChannel;
  • /* TIM3 interrupt priority is higher than USART1, RTC and EXTI4 interrupts priorities. USART1 interrupt priority is higher than RTC and EXTI4 interrupts priorities. <font color="red">RTC interrupt priority is higher than EXTI4 interrupt prioriy.</font> */
  • </p>
[color=rgb(51, 102, 153) !important]复制代码
这里最终是把RTC和TIM3都是设置成抢占优先级1,响应优先级7。
1.RTC interrupt priority is higher than EXTI4 interrupt prioriy.是不是错了?
2.global interrupt和普通中断有有什么区别吗?你是如何理解global interrupt的?
3.还有两个通道可以设置成一种优先级吗?
赞 收藏 评论2 发布时间:2015-10-14 21:18
你好我好大家好! 回答时间:2015-10-15 07:29:09
绑定
JackieLaura 回答时间:2015-10-15 09:27:29
你设置的是RTC和EXIT4优先级一样吧
