uncleo-f030r8的usart通信
wu93111 提问时间:2015-11-12 15:27 /
赞 收藏 评论15 发布时间:2015-11-12 15:27
15个回答
wu93111 回答时间:2015-11-17 15:59:05
这个.s文件里,石油我用的那个USART2_IRQHandler的
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
; <h> Stack Configuration
;   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Stack_Size      EQU     0x00000400
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; <h> Heap Configuration
;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Heap_Size       EQU     0x00000200
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
__Vectors       DCD     __initial_sp                   ; Top of Stack
                DCD     Reset_Handler                  ; Reset Handler
                DCD     NMI_Handler                    ; NMI Handler
                DCD     HardFault_Handler              ; Hard Fault Handler
                DCD     0                              ; Reserved
                DCD     0                              ; Reserved
                DCD     0                              ; Reserved
                DCD     0                              ; Reserved
                DCD     0                              ; Reserved
                DCD     0                              ; Reserved
                DCD     0                              ; Reserved
                DCD     SVC_Handler                    ; SVCall Handler
                DCD     0                              ; Reserved
                DCD     0                              ; Reserved
                DCD     PendSV_Handler                 ; PendSV Handler
                DCD     SysTick_Handler                ; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler                ; Window Watchdog
                DCD     0                              ; Reserved
                DCD     RTC_IRQHandler                 ; RTC through EXTI Line
                DCD     FLASH_IRQHandler               ; FLASH
                DCD     RCC_IRQHandler                 ; RCC
                DCD     EXTI0_1_IRQHandler             ; EXTI Line 0 and 1
                DCD     EXTI2_3_IRQHandler             ; EXTI Line 2 and 3
                DCD     EXTI4_15_IRQHandler            ; EXTI Line 4 to 15
                DCD     0                              ; Reserved
                DCD     DMA1_Channel1_IRQHandler       ; DMA1 Channel 1
                DCD     DMA1_Channel2_3_IRQHandler     ; DMA1 Channel 2 and Channel 3
                DCD     DMA1_Channel4_5_IRQHandler     ; DMA1 Channel 4 and Channel 5
                DCD     ADC1_IRQHandler                ; ADC1
                DCD     TIM1_BRK_UP_TRG_COM_IRQHandler ; TIM1 Break, Update, Trigger and Commutation
                DCD     TIM1_CC_IRQHandler             ; TIM1 Capture Compare
                DCD     0                              ; Reserved
                DCD     TIM3_IRQHandler                ; TIM3
                DCD     0                              ; Reserved
                DCD     0                              ; Reserved
                DCD     TIM14_IRQHandler               ; TIM14
                DCD     TIM15_IRQHandler               ; TIM15
                DCD     TIM16_IRQHandler               ; TIM16
                DCD     TIM17_IRQHandler               ; TIM17
                DCD     I2C1_IRQHandler                ; I2C1
                DCD     I2C2_IRQHandler                ; I2C2
                DCD     SPI1_IRQHandler                ; SPI1
                DCD     SPI2_IRQHandler                ; SPI2
                DCD     USART1_IRQHandler              ; USART1
                DCD     USART2_IRQHandler              ; USART2
__Vectors_End
__Vectors_Size  EQU  __Vectors_End - __Vectors
                AREA    |.text|, CODE, READONLY
; Reset handler routine
Reset_Handler    PROC
                 EXPORT  Reset_Handler                 [WEAK]
        IMPORT  __main
        IMPORT  SystemInit
        LDR     R0, =__initial_sp          ; set stack pointer
        MSR     MSP, R0
;;Check if boot space corresponds to test memory
        LDR R0,=0x00000004
        LDR R1, [R0]
        LSRS R1, R1, #24
        LDR R2,=0x1F
        CMP R1, R2
        BNE ApplicationStart
;; SYSCFG clock enable
        LDR R0,=0x40021018
        LDR R1,=0x00000001
        STR R1, [R0]
;; Set CFGR1 register with flash memory remap at address 0
        LDR R0,=0x40010000
        LDR R1,=0x00000000
        STR R1, [R0]
ApplicationStart
                 LDR     R0, =SystemInit
                 BLX     R0
                 LDR     R0, =__main
                 BX      R0
                 ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler     PROC
                EXPORT  NMI_Handler                    [WEAK]
                B       .
                ENDP
HardFault_Handler\
                PROC
                EXPORT  HardFault_Handler              [WEAK]
                B       .
                ENDP
SVC_Handler     PROC
                EXPORT  SVC_Handler                    [WEAK]
                B       .
                ENDP
PendSV_Handler  PROC
                EXPORT  PendSV_Handler                 [WEAK]
                B       .
                ENDP
SysTick_Handler PROC
                EXPORT  SysTick_Handler                [WEAK]
                B       .
                ENDP
Default_Handler PROC
                EXPORT  WWDG_IRQHandler                [WEAK]
                EXPORT  RTC_IRQHandler                 [WEAK]
                EXPORT  FLASH_IRQHandler               [WEAK]
                EXPORT  RCC_IRQHandler                 [WEAK]
                EXPORT  EXTI0_1_IRQHandler             [WEAK]
                EXPORT  EXTI2_3_IRQHandler             [WEAK]
                EXPORT  EXTI4_15_IRQHandler            [WEAK]
                EXPORT  DMA1_Channel1_IRQHandler       [WEAK]
                EXPORT  DMA1_Channel2_3_IRQHandler     [WEAK]
                EXPORT  DMA1_Channel4_5_IRQHandler     [WEAK]
                EXPORT  ADC1_IRQHandler                [WEAK]
                EXPORT  TIM1_BRK_UP_TRG_COM_IRQHandler [WEAK]
                EXPORT  TIM1_CC_IRQHandler             [WEAK]
                EXPORT  TIM3_IRQHandler                [WEAK]
                EXPORT  TIM14_IRQHandler               [WEAK]
                EXPORT  TIM15_IRQHandler               [WEAK]
                EXPORT  TIM16_IRQHandler               [WEAK]
                EXPORT  TIM17_IRQHandler               [WEAK]
                EXPORT  I2C1_IRQHandler                [WEAK]
                EXPORT  I2C2_IRQHandler                [WEAK]
                EXPORT  SPI1_IRQHandler                [WEAK]
                EXPORT  SPI2_IRQHandler                [WEAK]
                EXPORT  USART1_IRQHandler              [WEAK]
                EXPORT  USART2_IRQHandler              [WEAK]
WWDG_IRQHandler
RTC_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_1_IRQHandler
EXTI2_3_IRQHandler
EXTI4_15_IRQHandler
ADC1_IRQHandler
TIM1_CC_IRQHandler
TIM3_IRQHandler
TIM14_IRQHandler
TIM15_IRQHandler
TIM16_IRQHandler
TIM17_IRQHandler
I2C1_IRQHandler
I2C2_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
                B       .
                ENDP
                ALIGN
; User Stack and Heap initialization
                 IF      EF:__MICROLIB
                 EXPORT  __initial_sp
                 EXPORT  __heap_base
                 EXPORT  __heap_limit
                 ELSE
                 IMPORT  __use_two_region_memory
                 EXPORT  __user_initial_stackheap
                 LDR     R0, =  Heap_Mem
                 LDR     R1, =(Stack_Mem + Stack_Size)
                 LDR     R2, = (Heap_Mem +  Heap_Size)
                 LDR     R3, = Stack_Mem
                 BX      LR
                 ALIGN
                 ENDIF
                 END
;************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE*****
12
