【NUCLEO-L476RG开发】1、自制的简易LED库
JackieLaura 提问时间:2015-12-1 14:06 /
     之前活动最后一天抢了一块L476的开发板,开发板早就收到了。     不过前段时间有点小忙,一直没有分享学习笔记。现在在这里献丑了,也要感谢ST给的这次体验的机会。
main.c
  1. #include "stm32l476xx.h"
  2. #include "led.h"
  3. static int disable_jtag(void);
  4. int main(void)
  5. {
  6.         disable_jtag();
  7.         GreenLED.initialize(GreenLEDGPIO);
  8.         while(1)
  9.         {
  10.                 GreenLED.set(GreenLEDGPIO, LED_ON);
  11.                 GreenLED.set(GreenLEDGPIO, LED_OFF);
  12.         }
  13. }
  14. static int
  15.         disable_jtag(void)
  16. {
  17.         RCC->AHB2ENR |= RCC_AHB2ENR_GPIOAEN | RCC_AHB2ENR_GPIOBEN;
  18.         //PA15 AF5
  19.         GPIOA->AFR[1] &= ~(0xf0000000);
  20.         GPIOA->AFR[1] |=   0x50000000 ;
  21.         //PB3 PB4 PB5 AF5
  22.         GPIOB->AFR[0] &= ~(0x00fff000);
  23.         GPIOB->AFR[0] |=   0x00555000 ;
  24.         return 0;
  25. }
led.h
  1. #ifndef _LED_H
  2. #define _LED_H
  3. #include "stm32l476xx.h"
  4. #define RCC_AHB2Periph_GPIOA               RCC_AHB2ENR_GPIOAEN
  5. #define RCC_AHB2Periph_GPIOB               RCC_AHB2ENR_GPIOBEN
  6. #define RCC_AHB2Periph_GPIOC               RCC_AHB2ENR_GPIOCEN
  7. #define RCC_AHB2Periph_GPIOD               RCC_AHB2ENR_GPIODEN
  8. #define RCC_AHB2Periph_GPIOE               RCC_AHB2ENR_GPIOEEN
  9. #define RCC_AHB2Periph_GPIOF               RCC_AHB2ENR_GPIOFEN
  10. #define RCC_AHB2Periph_GPIOG               RCC_AHB2ENR_GPIOGEN
  11. #define RCC_AHB2Periph_GPIOH               RCC_AHB2ENR_GPIOHEN
  12. typedef enum {
  13.         LED_ON = 0,
  14.         LED_OFF
  15. }LED_STATUS;
  16. typedef enum {
  17.         GPIO_Pin_0 = 0,
  18.         GPIO_Pin_1,
  19.         GPIO_Pin_2,
  20.         GPIO_Pin_3,
  21.         GPIO_Pin_4,
  22.         GPIO_Pin_5,
  23.         GPIO_Pin_6,
  24.         GPIO_Pin_7,
  25.         GPIO_Pin_8,
  26.         GPIO_Pin_9,
  27.         GPIO_Pin_10,
  28.         GPIO_Pin_11,
  29.         GPIO_Pin_12,
  30.         GPIO_Pin_13,
  31.         GPIO_Pin_14,
  32.         GPIO_Pin_15,
  33.         GPIO_Pin_All,
  34. }GPIO_PIN_E;
  35. typedef struct {
  36.         GPIO_TypeDef* GPIO_PORT;
  37.         GPIO_PIN_E GPIO_PIN;
  38.         uint32_t GPIO_CLK;
  39. }LED_GPIO_T;
  40. typedef struct {
  41.         int (* initialize)(LED_GPIO_T);
  42.         int (* set)(LED_GPIO_T, LED_STATUS);
  43.         LED_STATUS (* get)(LED_GPIO_T);
  44.         int (* toggle)(LED_GPIO_T);
  45. }LED_T;
  46. extern LED_T GreenLED;
  47. extern LED_GPIO_T GreenLEDGPIO;
  48. #endif
led.c
  1. #include "led.h"
  2. static int led_init(LED_GPIO_T);
  3. static int led_set(LED_GPIO_T, LED_STATUS);
  4. static LED_STATUS led_get(LED_GPIO_T);
  5. static int led_toggle(LED_GPIO_T);
  6. LED_GPIO_T GreenLEDGPIO = {
  7.         .GPIO_PORT = GPIOA,
  8.         .GPIO_PIN = GPIO_Pin_5,
  9.         .GPIO_CLK = RCC_AHB2Periph_GPIOA,
  10. };
  11. LED_T GreenLED = {
  12.         .initialize = led_init,
  13.         .set = led_set,
  14.         .get = led_get,
  15.         .toggle = led_toggle,
  16. };
  17. static int
  18.         led_init(LED_GPIO_T gpio)
  19. {
  20.         int pincount = gpio.GPIO_PIN;
  21.
  22.         RCC->AHB2ENR |= gpio.GPIO_CLK;
  23.
  24.         gpio.GPIO_PORT->MODER &= \
  25.        ~(gpio.GPIO_PORT == GPIOA ? \
  26.        0x03ffffff : \
  27.        0xffffffff);        //reset values:0xabff ffff A                0xffff ffff B-G         0x0000 0000 H
  28.         gpio.GPIO_PORT->MODER |= \
  29.        (pincount == 16) ? \
  30.        (gpio.GPIO_PORT == GPIOA ? 0x01555555 : 0x55555555) : \
  31.        (1 << (pincount * 2));
  32.         gpio.GPIO_PORT->OTYPER &= \
  33.        (pincount == 16) ? \
  34.        0x0 : \
  35.        ~(1 << pincount);        //reset values:0x0000 0000
  36.         gpio.GPIO_PORT->PUPDR &= \
  37.        (pincount == 16) ? \
  38.        ((gpio.GPIO_PORT == GPIOA || gpio.GPIO_PORT == GPIOB) ? 0xfc000000 : 0x0) : \
  39.        ~(1 << (pincount * 2));                                        //reset values:0x6400 0000 A/B        0x0000 0000 others
  40.         gpio.GPIO_PORT->OSPEEDR |= \
  41.        (pincount == 16) ? \
  42.        (gpio.GPIO_PORT == GPIOA ? 0xadaaaaaa : 0xaaaaaaaa) : \
  43.        (0x02 << (pincount * 2));                                //reset values:0x0c00 0000 A                0x0000 0000 others
  44.         return 0;
  45. }
  46. static int
  47.         led_set(LED_GPIO_T gpio, LED_STATUS ledStatus)
  48. {
  49.         switch(ledStatus)
  50.         {
  51.                 case LED_ON:
  52.                         gpio.GPIO_PORT->BSRR = gpio.GPIO_PIN == 16 ? 0xffff : 1 << gpio.GPIO_PIN;
  53.                         break;
  54.                 case LED_OFF:
  55.                         gpio.GPIO_PORT->BRR  = gpio.GPIO_PIN == 16 ? 0xffff : 1 << gpio.GPIO_PIN;
  56.                         break;
  57.         }
  58.         return 0;
  59. }
  60. static LED_STATUS
  61.         led_get(LED_GPIO_T gpio)
  62. {
  63.         int input = gpio.GPIO_PORT->ODR;
  64.         input >>= gpio.GPIO_PIN;
  65.         return  input == 1 ? LED_ON : LED_OFF;
  66. }
  67. static int
  68.         led_toggle(LED_GPIO_T gpio)
  69. {
  70.         switch(led_get(gpio))
  71.         {
  72.                 case LED_ON:
  73.                         led_set(gpio, LED_OFF);
  74.                         break;
  75.                 case LED_OFF:
  76.                         led_set(gpio, LED_ON);
  77.                         break;
  78.         }
  79.         return 0;
  80. }
工程源码:
led.rar (28.55 KB, 下载次数: 7)
参与人数 1 ST金币 +20 收起 理由
沐紫 + 20
赞 收藏 1 评论17 发布时间:2015-12-1 14:06
17个回答
qianfan 回答时间:2015-12-1 16:30:51
JackieLaura 发表于 2015-12-1 15:41
标准库中的GPIOInitStructure不是每个IO占用一个?
那个是可以反复利用的。像GPIO_InitTypeDef ioIt;
ioIt.GPIO_Pin=GPIO_Pin_5;
GPIO_Init(GPIOA,&ioIt);
ioIt.GPIO_Pin=GPIO_Pin_6;
GPIO_Init(GPIOB,&ioIt);
而这个LED_GPIO_T是需要提前将所有的引脚定义,放到flash中的。不可能重复利用。一个引脚需要占用一个LED_GPIO_T的。如果你有100个引脚,需要占用100×sizeof(LED_GPIO_T),而使用GPIO_InitTypeDef只需要1×sizeof(GPIO_InitTypeDef)。
JackieLaura 回答时间:2015-12-1 15:41:23
QianFan 发表于 2015-12-1 14:47
不得不说,虽然很高大上,但是没啥用。每一个引脚占用一个LED_GPIO_T,占用了太多的资源。 ...
JackieLaura 回答时间:2015-12-2 08:47:48
作为全局变量。。。那我再改改。。。
wamcncn 回答时间:2015-12-1 14:12:46
谢谢分享,真复杂
沐紫 回答时间:2015-12-1 14:19:18
谢谢你哦
JackieLaura 回答时间:2015-12-1 14:19:47
wambob 发表于 2015-12-1 14:12
谢谢分享,真复杂
是模仿别人方式写的。。。
JackieLaura 回答时间:2015-12-1 14:20:23
谢谢沐紫的金币
qianfan 回答时间:2015-12-1 14:47:43
yanhaijian 回答时间:2015-12-1 14:56:44
呵呵,来劲的。
stary666 回答时间:2015-12-1 16:52:26
看看,,,,,,,,,,,,,,,,,
黑皮男 回答时间:2015-12-1 16:53:13
不错,学习了,比我自己整的好多了
Paderboy 回答时间:2015-12-1 17:13:29
多谢分享。。。不错。。。、、
orima 回答时间:2015-12-1 18:24:40
感谢分享。
JackieLaura 回答时间:2015-12-2 08:49:02
stary666 发表于 2015-12-1 16:52
看看,,,,,,,,,,,,,,,,,
12下一页
