stm32f4 SPI DMA 通信读取数据,SPI 不发数据,DMA无法中断
东东-424146 提问时间:2015-12-24 09:47 /
这几天一直在搞SPI + DMA 通信,DMA设置成中断时,SPI无法发送数据,同时也无法产生DMA中断。具体SPI 和DMA的配置如下:
SPI2 初始化
void SPI2_PeriphInit (void)
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    //GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_SPI2);        //PB12 NSS
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_SPI2);        //PB13 SCK
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_SPI2);        //PB14 MISO
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_SPI2);        //PB15 MOSI
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    GPIO_SetBits(GPIOB, GPIO_Pin_12);
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_15;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
    SPI_InitTypeDef SPI_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
    SPI_I2S_DeInit(SPI2);
    SPI_InitStructure.SPI_Direction= SPI_Direction_2Lines_FullDuplex;
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
    SPI_InitStructure.SPI_CRCPolynomial = 7;
    SPI_Init(SPI2, &SPI_InitStructure);
    SPI_CalculateCRC(SPI2, DISABLE);
    SPI_Cmd(SPI2, ENABLE);
void SPI2_DMAInit (void)
    DMA_InitTypeDef DMA_InitStructure;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
    DMA_DeInit(DMA1_Stream3);
    DMA_DeInit(DMA1_Stream4);
    DMA_InitStructure.DMA_Channel  = DMA_Channel_0;
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&(SPI2->DR));
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)ad7657_revbuf[0];    //ad7657_revbuff 为2维数组 , 2 x 6
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
    DMA_InitStructure.DMA_BufferSize = AD7656REVDATALEN;                            //宏定义为6
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
    DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
    DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
    DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
    DMA_Init(DMA1_Stream3, &DMA_InitStructure);
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)ad7657_send;       //数组,6个字节
    DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
    DMA_InitStructure.DMA_BufferSize = AD7656SENDLEN;                               //宏定义 6
    DMA_InitStructure.DMA_Priority = DMA_Priority_Low;
    DMA_Init(DMA1_Stream4, &DMA_InitStructure);
    SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);
    SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, ENABLE);
    DMA_ITConfig(DMA1_Stream3, DMA_IT_TC | DMA_IT_TE, ENABLE);
    DMA_ITConfig(DMA1_Stream4, DMA_IT_TC | DMA_IT_TE, ENABLE);
    NVIC_InitTypeDef  NVIC_InitStructure;
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannel =ENABLE;
    DMA_Cmd(DMA1_Stream3, DISABLE);
    DMA_Cmd(DMA1_Stream4, DISABLE);
定时触发DMA 发送数据
void TIM2_IRQHandler(void)
    if (TIM_GetITStatus (TIM2, TIM_IT_Update) == SET)
        TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
        GPIO_ResetBits(GPIOB, GPIO_Pin_12);
        while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
        DMA_SetCurrDataCounter(DMA1_Stream3, 6);
        DMA_SetCurrDataCounter(DMA1_Stream4, 6);
        DMA_Cmd(DMA1_Stream4, ENABLE);
        DMA_Cmd(DMA1_Stream3, ENABLE);
DMA 产生中断
void DMA1_Stream3_IRQHandler (void)
    if (DMA_GetITStatus(DMA1_Stream3, DMA_IT_TCIF3) == SET)
        DMA_ClearFlag(DMA1_Stream3, DMA_IT_TC);
        DMA_ClearFlag(DMA1_Stream4, DMA_IT_TC);
        DMA_ClearITPendingBit(DMA1_Stream3, DMA_IT_TCIF3);
        DMA_ClearITPendingBit(DMA1_Stream4, DMA_IT_TCIF4);
        SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, DISABLE);
        SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, DISABLE);
赞 收藏 1 评论13 发布时间:2015-12-24 09:47
13个回答
东东-424146 回答时间:2015-12-24 16:00:42
又试了一天还是无果,主SPI+DMA传输无法用中断来完成,不得不用阻塞方式。如果哪位看官需要,可以留言。希望有心人看到能够交流交流
jcx0324 回答时间:2015-12-24 16:38:22
单独DMA操作SPI可以吗? 曾经这个怎么搞都没通,
东东-424146 回答时间:2015-12-24 20:41:44
dma不开中断,操作spi可以
东东-424146 回答时间:2016-1-6 14:17:25
搞定,过来结帖
菜鸟一颗 回答时间:2016-1-27 15:38:18
怎么搞好的,能把程序贴一下或者邮箱发我一下吗 125828526
东东-424146 回答时间:2016-4-26 14:34:43
NVIC_IRQChannel 通道设置错误,是要把通道使能的。不知道你问题解决没有
ychlucky 回答时间:2016-4-26 15:18:25
同求 怎么搞的啊
ivtaaa 回答时间:2016-6-26 14:47:18
NVIC ...
看着和上面的代码一样啊,能发我一份完整的代码吗 ,我在调试这个,一直有问题,谢谢  416575202@qq.com
口圭口塞口丫 回答时间:2016-11-14 18:13:58
方便留个联系方式吗 最近一直在调SPI DMA发送 一直没出来。
fang599956589 回答时间:2017-1-17 11:13:53
最近在弄STM32 SPI 发送数据用DMA方式,可是一直发送不了,求联系方式599956589@QQ.COM
graydon 回答时间:2018-6-19 20:14:51
改为
NVIC_InitStructure.NVIC_IRQChannelCmd =ENABLE;
无意中看到,楼主解决了,又不贴解决的代码!
xiaowang11 回答时间:2018-12-3 15:36:31
楼主你好,最近我也遇到类似的问题,SPI2 DMA配置好后无法接受到数据,对端的DMA正常的在发数据。你之前怎么调好的,谢谢!
xiaowang11 回答时间:2018-12-3 16:07:27
你好,我也遇到SPI2 DMA 接受不到数据,不知道哪里遇到了问题,向大神请教一下。谢谢!
