关于stmf103串口DMA接收常定数组问题!!
请输入口令 提问时间:2016-1-20 09:21 /
各位大大好,打扰了,最近在写一个串口接收程序,但配置了好久也没配制出来,也参考一些前辈写的配置,然后自己配置了个串口DMA接收数据,但发现配置都设置好了,DMA却始终收不到发送的数据,显示的全部为0,哪位前辈有这方面经验的希望指导下,万分感谢!下面是的串口DMA配置程序:
  1. #include "usart_led.h"
  2. //int USART1_DATA;
  3. unsigned int buffer[64]={0};
  4. unsigned char XY_led_num;
  5. unsigned char XX=0,YY=0;
  6. unsigned char flag_IR=0;
  7. extern unsigned char tabl_R[8][8];
  8. u8 data[64];
  9. uint32_t temp = 0;
  10.
  11. void USART1_Configuration(void)
  12. {
  13.     USART_InitTypeDef      USART_InitStructure;
  14.     GPIO_InitTypeDef       GPIO_InitStructure;
  15.    DMA_InitTypeDef        DMA_InitStructure;
  16.
  17.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO,ENABLE);
  18.           RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  19.
  20.                 GPIO_InitStructure.GPIO_Pin   =  GPIO_Pin_9;
  21.                 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  22.                 GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
  23.                 GPIO_Init(GPIOA , &GPIO_InitStructure);
  24.
  25.                 GPIO_InitStructure.GPIO_Pin   =  GPIO_Pin_10;       //Rx
  26.                 GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IN_FLOATING;
  27.                 GPIO_Init(GPIOA , &GPIO_InitStructure);
  28.
  29.           DMA_DeInit(DMA1_Channel1);
  30.          DMA_InitStructure.DMA_PeripheralBaseAddr =(uint32_t)(&USART1->DR);
  31.                 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)buffer;
  32.                 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  33.                 DMA_InitStructure.DMA_BufferSize = 64;
  34.                 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  35.                 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  36.                 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  37.                 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  38.                 DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  39.                 DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  40.                 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  41.                 DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  42.
  43.                 DMA_Cmd(DMA1_Channel1, ENABLE);
  44.
  45.     USART_InitStructure.USART_BaudRate   =9600;
  46.                 USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  47.                 USART_InitStructure.USART_StopBits   = USART_StopBits_1;
  48.                 USART_InitStructure.USART_Parity     = USART_Parity_No;
  49.                 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  50.                 USART_InitStructure.USART_Mode                = USART_Mode_Tx | USART_Mode_Rx;
  51.     USART_Init(USART1, &USART_InitStructure);
  52.     USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE);     // Enable USART1 DMA TX request
  53.     USART_Cmd(USART1, ENABLE);
  54.
  55.                 USART_ITConfig(USART1,USART_IT_TC,DISABLE);
  56.     USART_ITConfig(USART1,USART_IT_RXNE,DISABLE);
  57.     USART_ITConfig(USART1,USART_IT_IDLE,ENABLE);
  58.
  59.                 USART_ClearFlag( USART1,USART_FLAG_IDLE );
  60. }
  61. void NVIC_Configuration(void)
  62. {
  63.     NVIC_InitTypeDef NVIC_InitStructure;
  64.
  65. #ifdef VECT_TAB_RAM
  66. NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
  67. #else //VECT_TAB_FLASH
  68. NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
  69. #endif
  70.
  71.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  72.
  73.
  74.                 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  75.                 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  76.                 NVIC_InitStructure.NVIC_IRQChannelSubPriority        = 2;
  77.                 NVIC_InitStructure.NVIC_IRQChannelCmd                = ENABLE;
  78.
  79.                 NVIC_Init(&NVIC_InitStructure);
  80. }
  81. void USART_INIT()
  82. {
  83.     USART1_Configuration();
  84.           NVIC_Configuration();
  85. }
  86. void USART1_SendData(uint16_t Data)
  87. {
  88.         USART_SendData(USART1,(uint16_t)Data);
  89.         while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);
  90. }
  91. void USART1_IRQHandler(void)
  92. {
  93.   if(USART_GetITStatus(USART1, USART_IT_IDLE) != RESET)
  94.   {
  95.                 flag_IR=1;
  96.                 temp = USART1->SR;
  97.                 temp = USART1->DR;
  98.   }
  99.         __nop();
  100. }
收藏 评论8 发布时间:2016-1-20 09:21
8个回答
废鱼 回答时间:2016-1-20 10:22:31
楼主,应该是先测试不用DMA下接收数据。楼主计划用查询还是中断的方式接收?
请输入口令 回答时间:2016-1-20 11:37:12
安 发表于 2016-1-20 10:22
楼主,应该是先测试不用DMA下接收数据。楼主计划用查询还是中断的方式接收? ...
我是用中断的方式接收啊!
刚才注意到串口1的DMA接收通道是通道5,然后改了过来现在能接收数据了,但接收的数据都是乱的啊,哭晕在厕所:'
废鱼 回答时间:2016-1-20 14:08:02
看一下串口通讯的波特率是否正确。
请输入口令 回答时间:2016-1-20 16:18:46
安 发表于 2016-1-20 14:08
看一下串口通讯的波特率是否正确。
我刚才又配了个不用DMA串口传输的程序,能用了,但DMA的还是没解决。。。
Paderboy 回答时间:2016-1-20 22:57:44
楼主是想用DMA IDLE 空闲中断接收串口数据吧!!
                flag_IR=1;
                temp = USART1->SR;
                temp = USART1->DR;  }
        __nop();
你参考下吧。。。你上面中断处理程序还缺进中断关闭DMA通道和获取CNDTR里数据长度。以上都处理好了。需要再给DMA CNDTR重新赋值,然后重新开启DMA接收数据。。
    uint32_t Length = 0;//数据长度
        DMA_Cmd(DMA1_Channel5,DISABLE);
        Length = USART1->SR;
        Length = USART1->DR; //清USART_IT_IDLE标志
        Length = UART_RX_LEN - DMA_GetCurrDataCounter(DMA1_Channel5); //设置传输数据长度
        DMA1_Channel5->CNDTR = UART_RX_LEN;//重装填,并让接收地址偏址从0开始
        DMA_Cmd(DMA1_Channel5, ENABLE);//处理完,重开DMA
    __nop();
请输入口令 回答时间:2016-1-21 17:16:03
这个我也配了,但也是接收错误!
Paderboy 回答时间:2016-1-22 09:04:55
可否发个你的完整的工程看看问题在哪?
请输入口令 回答时间:2016-1-22 09:38:02
Paderboy 发表于 2016-1-22 09:04
可否发个你的完整的工程看看问题在哪?
嗯好的,等下发给你!
test program.rar
5.32 MB, 下载次数: 59, 下载积分: ST金币 -1
Usart DMA
