想請教有關於DA的問題
sappppp 提问时间:2016-3-8 08:07 /
想要請問各位先進,如果我想要測試模組Reverse Park內的演算是否有錯誤,我用DA來將演算出來的數據接上示波器觀看,但是我發現我Reverse Park計算後的值和DA讀出來的數據有所不同,所以想要請問是哪裡出錯呢?我DA是為PA4, PA5兩隻Pin腳。程式中Theta從0~360度,Stat_Volt_q_d固定都給3.3V 。對於輸入電壓值,想要請問是直接給3.3還是我必須要做轉換呢?謝謝主程式如下
           Stat_Volt_q_d.qV_Component1 =3.3;
            Stat_Volt_q_d.qV_Component2 = 3.3;
           Stat_Volt_alfa_beta = ipark_calc(Stat_Volt_q_d, Theta);
            Stat_Volt_alfa_beta.qV_Component1 = Stat_Volt_alfa_beta.qV_Component1 / 32766;
            Stat_Volt_alfa_beta.qV_Component2 = Stat_Volt_alfa_beta.qV_Component2 / 32766;
            DAC_SetChannel1Data(DAC_Align_12b_R, Stat_Volt_alfa_beta.qV_Component1);
            DacX = DAC_GetDataOutputValue(DAC_Channel_1);
            DacTemp = (float) DacX * (3.3/4096);
            DAC_SetChannel2Data(DAC_Align_12b_R, Stat_Volt_alfa_beta.qV_Component2);
            DacX = DAC_GetDataOutputValue(DAC_Channel_2);
            DacTemp = (float) DacX * (3.3/409);
副程式
static void DAC_GPIO_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4 | GPIO_Pin_5;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
static void DAC_TIM_Init(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
        TIM_TimeBaseStructure.TIM_Period = 100;
        TIM_TimeBaseStructure.TIM_Prescaler = 0;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
        TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
        TIM_Cmd(TIM2, ENABLE);
static void DAC_Init(void)
        DAC_InitTypeDef DAC_InitStructure;
        DMA_InitTypeDef DMA_INIT;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
        DAC_InitStructure.DAC_Trigger = DAC_Trigger_None;
        DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
        DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_TriangleAmplitude_4095;
        DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;
        DAC_Init(DAC_Channel_1, &DAC_InitStructure);
        DAC_Init(DAC_Channel_2, &DAC_InitStructure);
        DAC_Cmd(DAC_Channel_1, ENABLE);
        DAC_Cmd(DAC_Channel_2, ENABLE);
        DAC_SetDualChannelData(DAC_Align_12b_R, 0x00, 0x00);
赞 收藏 评论0 发布时间:2016-3-8 08:07
