DMA_USART1通信收发不正常
stm32_f2 提问时间:2016-3-17 10:22 /
#include "stm32f2xx.h"
#include <stdio.h>
#define USART1_DR_ADDRESS                ((uint32_t)USART1 + 0x04)
#define DMA_Rec_Len 32
void RCC_Configuration(void);
void NVIC_Configuration(void);
void GPIO_Configuration(void);
void USART_Configuration(void);
void DMA_Configuration(void);
void USART1_SendString(uint8_t *ch);
void UART1_SendByte(uint16_t Data);
void USART1_Send(u8 *buf,u8 len);
uint8_t DMA_Rece_Buf[DMA_Rec_Len];
int16_t USART1_Rec_Cnt=0;
int main(void)
  //int16_t j;
        uint8_t i;
  RCC_Configuration();
  GPIO_Configuration();
  USART_Configuration();
        DMA_Configuration();
        NVIC_Configuration();
  while (1)
  DMA_InitTypeDef  DMA_InitStructure;
        DMA_DeInit(DMA2_Stream5);
        DMA_InitStructure.DMA_Channel = DMA_Channel_4;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
        DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_ADDRESS;
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)DMA_Rece_Buf;
        DMA_InitStructure.DMA_BufferSize = DMA_Rec_Len;
        DMA_Init(DMA2_Stream5, &DMA_InitStructure);
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE);
DMA_Cmd(DMA2_Stream5, ENABLE);
//USART1
void USART1_IRQHandler(void)
  u16 i;
        flag=1;
  if(USART_GetITStatus(USART1, USART_IT_IDLE) != RESET)////½óêÕÖD¶Ï
                DMA_Cmd(DMA2_Stream5, DISABLE);//1رÕUSART1 TX DMA1 ËùÖ¸ê¾μÄí¨μà
                if(USART_GetFlagStatus(USART2,USART_FLAG_ORE)==SET)
                        USART_ClearFlag(USART1,USART_FLAG_ORE); //Ïè¶áSR
                        USART_ReceiveData(USART1); //Ôù¶áDR
                USART1_Rec_Cnt= DMA_Rec_Len-DMA_GetCurrDataCounter(DMA2_Stream5);
                USART1_Send(DMA_Rece_Buf,USART1_Rec_Cnt);
                USART_ClearITPendingBit(USART1, USART_IT_IDLE|USART_IT_RXNE|USART_IT_TC);
          //USART_ITConfig(USART1, USART_IT_IDLE , ENABLE);
    /* Clear all DMA Streams flags */
    DMA_ClearFlag(DMA2_Stream5, DMA_FLAG_HTIF2 | DMA_FLAG_TCIF2);
                DMA_SetCurrDataCounter(DMA2_Stream5,DMA_Rec_Len);
  /*Enable DMA Interrupt
  NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream5_IRQn;
  NVIC_Init(&NVIC_InitStructure);*/
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
/*éèÖÃê±Öó*/
        RCC_DeInit();
        RCC_HSICmd(ENABLE);
        while (RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET){}
        RCC_HCLKConfig(RCC_SYSCLK_Div1);
        RCC_PCLK1Config(RCC_HCLK_Div4);
        RCC_PCLK2Config(RCC_HCLK_Div2);
        FLASH_SetLatency(FLASH_Latency_7) ;
        FLASH_PrefetchBufferCmd(ENABLE);
        RCC_PLLConfig(RCC_PLLSource_HSI, 16, 240, 2, 5);
        RCC_PLLCmd(ENABLE);
        while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET){}
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
                /*GPIOéèÖÃ*/
        GPIO_InitTypeDef  GPIO_InitStructure;
        GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_USART1);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_USART1);
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;        //íÆíìêä3ö
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;                //éÏà-êäèë
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 ;
                /*USARTéèÖÃ*/
        USART_InitStructure.USART_BaudRate = 115200;
  USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_ClearFlag(USART1, USART_FLAG_TC);
  USART_Init(USART1, &USART_InitStructure);
        //USART_ITConfig(USART1, USART_IT_RXNE , ENABLE);
  USART_Cmd(USART1, ENABLE);
        u8 t;
          for(t=0;t<len;t++)                //Ñ-»··¢Ëíêy¾Y
                while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
                USART_SendData(USART1,buf[t]);
        while(*ch!=0)
                while(!USART_GetFlagStatus(USART1, USART_FLAG_TXE));
                USART_SendData(USART1, *ch);
                ch++;
收到的数据与发送的相差太大,求大神帮帮忙啊
赞 收藏 评论3 发布时间:2016-3-17 10:22
3个回答
power568 回答时间:2016-3-17 12:30:20
  是么意思,是单次相差大,还是总数
以上大小更改为byte,
更改为Normal试试看。
另:建议不要再接收中断中立即发送数据!!!
祝你好运...
参与人数 1ST金币 +2 收起 理由
废鱼 回答时间:2016-3-17 15:13:04
如楼上所说,中断中收发数据导致数据丢失。
buainilema 回答时间:2016-3-17 17:26:05
中断收还是可以的,就是发的有问题了,,哪有,建议你把发的放在中断外进行发送
参与人数 1ST金币 +2 收起 理由
