stm32F1 利用DMA做USART接收資料問題
sappppp 提问时间:2016-3-29 11:18 /
請問我利用DMA來接收PC端輸入的數據資料,不用中斷來實現,可是卻無法得到資料。想要請問哪裡出錯呢?
謝謝
#define USART1_DR_Base  0x40013804
uint32_t SendBuff[4];
void USART_Configuration1(void)
    USART_ClockInitTypeDef  USART_ClockInitStructure;
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
    USART_InitStructure.USART_BaudRate = 4800;
    USART_InitStructure.USART_Parity = USART_Parity_No ;
    USART_Init(USART1, &USART_InitStructure);
    USART_Cmd(USART1, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
void USART_DMA_Configuration(void)
    DMA_InitTypeDef DMA_InitStructure;
    DMA_DeInit(DMA1_Channel4);
    DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_Base;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ReadBuff;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize =4;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
    DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel4, &DMA_InitStructure);
    DMA_ITConfig(DMA1_Channel4, DMA_IT_TC,ENABLE);
    USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE);
    DMA_Cmd(DMA1_Channel4, ENABLE);
接收PC端數據,此段寫再MAIN裡面
           if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
              temp = USART1->SR;
              temp = USART1->DR;
              DMA_Cmd(DMA1_Channel4,DISABLE);
              temp = UART_RX_LEN - DMA_GetCurrDataCounter(DMA1_Channel4);
              for (i=0; i<temp ; i++)
                Data_Receive_Usart = SendBuff[i];  // 讀取PC數據
              DMA_SetCurrDataCounter(DMA1_Channel4,UART_RX_LEN);
              DMA_Cmd(DMA1_Channel4,ENABLE);
赞 收藏 评论4 发布时间:2016-3-29 11:18
4个回答
power568 回答时间:2016-3-29 11:31:41
串口和DMA外设时钟均没使能...
sappppp 回答时间:2016-3-29 11:37:40
這個我再前面的程式碼已經使能過了,但是不知道為什麼還是讀取不到資料。
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
您指的應該是兩段碼吧!
xmshao 回答时间:2016-3-29 12:09:53
1\ 你确认下DMA相关通道是否配置正确;
2、你不是电脑发数据到UART_DR,再由DMA传输到readbuf吗?数据到这里查看就行。怎么看到
你在MAIN里不停读UART_DR.
sappppp 回答时间:2016-3-29 15:26:55
想請問 PC輸入為字串,如"123"時,再main裡面的接收程式到底要怎麼寫才可以完整接收到呢?
且接收到的數字怎麼可以讓其他函式使用呢?
我將我的程式改成以下接收到字元,再將字元輸出。這樣是可以接收到每個字元,但是怎麼變成一個數字和如何被其他函式所使用,就不得而知了。
           if(USART1->SR & USART_FLAG_RXNE)
              temp = USART1->SR;
              temp = USART1->DR;
              USART_SendData(USART1, temp);
              while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
