想用SPI从模式,总是调不成功
any012 提问时间:2016-5-12 15:52 /
悬赏5ST金币已解决
想用stm32作为spi的从设备,用的是spi2,spi2接收中断后,将接收到的数通过串口发送出来。
结果调不通,请大家帮看下是哪里设置错了?用示波器测量SCK和MOSI管脚,是有波形的。
SPI设置部分:
  1. void SPI2_Init(void)
  2. {
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         SPI_InitTypeDef SPI_InitStructure;
  5.
  6.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
  7.         RCC_APB2PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  8.
  9.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_14;                //PB12 - SPI2_CS, PB14 - SPI2_MISO
  10.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  11.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  12.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  13.
  14.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_15;                //PB13 - SPI2_SCK, PB15 - SPI2_MOSI
  15.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  16.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  17.
  18.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  19.         SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
  20.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  21.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  22.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  23.         SPI_InitStructure.SPI_NSS =SPI_NSS_Soft;
  24.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
  25.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  26.         SPI_InitStructure.SPI_CRCPolynomial = 7;
  27.         SPI_Init(SPI2, &SPI_InitStructure);
  28.
  29.         SPI_I2S_ITConfig(SPI2, SPI_I2S_IT_RXNE, ENABLE);
  30.         SPI_Cmd(SPI2, ENABLE);
  31. }
  32. void SPI2_IRQHandler(void)
  33. {
  34.         u8 spiTemp;
  35.         spiTemp = SPI_I2S_ReceiveData(SPI2);
  36.         printf("spirecive: %d", spiTemp);
  37. }
主函数部分:
  1. int main(void)
  2. {
  3.         Init();
  4.         TIM_Cmd(TIM3, ENABLE);
  5.
  6.         while(1)
  7.         {
  8.                 if(flag_1ms)
  9.                 {
  10.                         flag_1ms = 0;
  11.                         printf("\r\n1s¶¨Ê±µ½¡£");
  12.                 }
  13.         }
  14. }
  15. void Init(void)
  16. {
  17.         GPIO_Config();
  18.         SPI2_Init();
  19.         USART1_Config();
  20.         TIM3_Config(9999, 7199);
  21.         NVIC_Configuration();
  22. }
中断配置部分:
  1. void NVIC_Configuration(void)
  2. {
  3.         NVIC_InitTypeDef NVIC_InitStructure;
  4.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  5.
  6.         NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  7.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
  8.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  9.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  10.         NVIC_Init(&NVIC_InitStructure);
  11.
  12.         NVIC_InitStructure.NVIC_IRQChannel = SPI2_IRQn;
  13.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  14.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  15.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  16.         NVIC_Init(&NVIC_InitStructure);
  17.
  18.         NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
  19.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
  20.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  21.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  22.         NVIC_Init(&NVIC_InitStructure);
  23. }
最佳答案
查看完整内容
" RCC_APB2PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE); " SPI时钟开启错误,根本没开启时钟! 你打字打错了 , 请改一下 :RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
赞 收藏 评论19 发布时间:2016-5-12 15:52
19个回答
Dylan疾风闪电 回答时间:2016-5-12 15:52:51
SPI时钟开启错误,根本没开启时钟!
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
wtliu 回答时间:2016-5-13 09:59:38
看看端口有没有设置上拉。
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
sfee2002 回答时间:2016-5-13 10:20:41
看了你的问题,你SPI工作 在从模式下,SCk肯定没时钟信号。你看下你到底是要工作在主模式下还是从模式下,如果确定工作在从模式下,那就看你那个主机的设备是否发了时钟信号
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
any012 回答时间:2016-5-13 11:00:45
wtliu 发表于 2016-5-13 09:59
看看端口有没有设置上拉。
三个管脚均有10K上拉电阻。
yuazhang 回答时间:2016-5-13 11:01:03
SCk有信号应该也没错,那是主节点发出来的,不是从节点发出来的。SPI要主从配合,从节点的配置要要主节点的配置相互要匹配才行。
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
any012 回答时间:2016-5-13 11:01:56
sfee2002 发表于 2016-5-13 10:20
看了你的问题,你SPI工作 在从模式下,SCk肯定没时钟信号。你看下你到底是要工作在主模式下还是从模式下, ...
需要工作在从模式下。
主设备发送了时钟信号,因为可以在本电路的SCK和MOSI管脚上测到波形。
yuazhang 回答时间:2016-5-13 11:03:18
可以用示波器观察一下SCk和MOSI两个信号是不是符合时序啊
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
wenyangzeng 回答时间:2016-5-13 11:27:49
从模式的时钟由主模式方提供。
SPI中断里最好不要进行printf数据处理。
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
power568 回答时间:2016-5-13 14:31:49
看看你的参数配置是否一致,特别是SPI_CPOL、SPI_CPHA...
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
Dylan疾风闪电 回答时间:2016-5-13 16:57:16
key键盘的问题,是APB1的时钟,需要调用APB1的函数来使能。
时光虫子 回答时间:2016-5-13 17:01:45
复用功能开了没有
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
zcl201207 回答时间:2016-5-13 20:02:19
那就地方 回答时间:2016-5-13 21:34:21
还是用模拟的SPI好
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
ChunMan 回答时间:2016-5-15 15:23:35
莫非是时序延时跟数据手册上的不合?
参与人数 1ST金币 +2 收起 理由
沐紫 + 2
12下一页
