STM32f103rbt6的IIc1 的问题
Better-407785 提问时间:2016-5-20 16:58 /
各位路过的大侠好!
本人第一次使用硬件IIC, 在使用的时候参考了很多例程,都无法实现。debug的时候程序总是停留在第一个检测位,有的时候会走到下一个位。
采用内部108Mhz,4分频27MHZ到 pclk1 .
本人已经闭门造车2天了,希望大侠帮我找找问题。程序如下:
#include "sys.h"
#include "usart.h"
#include "delay.h"
//#include "led.h"
//#include "beep.h"
//#include "key.h"
//#include "timer.h"
//#include "adc.h"
#include "output.h"
//#include "output.h"
//#include "ir.h"
//#include "hym8563.h"
//#include "stmflash.h"
//#include "TFT018.h"
//extern U8 bmp[];
//#include "stm32f10x_i2c.h"
#define DEVICE_IP 1
#define iic_address 0x0a
#define iic_address2 0x0b
/* I2C Events */
/* EV1 */
#define  I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED       ((u32)0x00060082) /* TRA, BUSY, TXE and ADDR flags */
#define  I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED          ((u32)0x00020002) /* BUSY and ADDR flags */
#define  I2C_EVENT_SLAVE_TRANSMITTER_SECONDADDRESS_MATCHED ((u32)0x00860080)  /* DUALF, TRA, BUSY and TXE flags */
#define  I2C_EVENT_SLAVE_RECEIVER_SECONDADDRESS_MATCHED    ((u32)0x00820000)  /* DUALF and BUSY flags */
#define  I2C_EVENT_SLAVE_GENERALCALLADDRESS_MATCHED        ((u32)0x00120000)  /* GENCALL and BUSY flags */
/* EV2 */
#define  I2C_EVENT_SLAVE_BYTE_RECEIVED                     ((u32)0x00020040)  /* BUSY and RXNE flags */
#define  EV2        I2C_EVENT_SLAVE_BYTE_RECEIVED
/* EV3 */
#define  I2C_EVENT_SLAVE_BYTE_TRANSMITTED                  ((u32)0x00060084)  /* TRA, BUSY, TXE and BTF flags */
#define  EV3         I2C_EVENT_SLAVE_BYTE_TRANSMITTED
/* EV4 */
#define  I2C_EVENT_SLAVE_STOP_DETECTED                     ((u32)0x00000010)  /* STOPF flag */
#define  EV4        I2C_EVENT_SLAVE_STOP_DETECTED
/* EV5 */
#define  I2C_EVENT_MASTER_MODE_SELECT                      ((u32)0x00030001)  /* BUSY, MSL and SB flag */
#define  EV5        I2C_EVENT_MASTER_MODE_SELECT
/* EV6 */
#define  I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED        ((u32)0x00070082)  /* BUSY, MSL, ADDR, TXE and TRA flags */
#define  I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED           ((u32)0x00030002)  /* BUSY, MSL and ADDR flags */
/* EV7 */
#define  I2C_EVENT_MASTER_BYTE_RECEIVED                    ((u32)0x00030040)  /* BUSY, MSL and RXNE flags */
#define  EV7        I2C_EVENT_MASTER_BYTE_RECEIVED
/* EV8 */
#define  I2C_EVENT_MASTER_BYTE_TRANSMITTED                 ((u32)0x00070084)  /* TRA, BUSY, MSL, TXE and BTF flags */
#define  EV8_1        I2C_EVENT_MASTER_BYTE_TRANSMITTED
/* --EV8 */
#define I2C_EVENT_MASTER_BYTE_TRANSMITTING                 ((u32)0x00070080) /* TRA, BUSY, MSL, TXE flags */
/* EV9 */
#define  I2C_EVENT_MASTER_MODE_ADDRESS10                   ((u32)0x00030008)  /* BUSY, MSL and ADD10 flags */
#define  EV9        I2C_EVENT_MASTER_MODE_ADDRESS10
/* EV3_2 */
#define  I2C_EVENT_SLAVE_ACK_FAILURE                       ((u32)0x00000400)  /* AF flag */
#define  EV3_2        I2C_EVENT_SLAVE_ACK_FAILURE
ErrorStatus I2C_CheckEvent(I2C_TypeDef* I2Cx, u32 I2C_EVENT)
  u32 lastevent = 0;
  u32 flag1 = 0, flag2 = 0;
  ErrorStatus status = ERROR;
  /* Check the parameters */
  assert_param(IS_I2C_ALL_PERIPH(I2Cx));
  assert_param(IS_I2C_EVENT(I2C_EVENT));
  /* Read the I2Cx status register */
  flag1 = I2Cx->SR1;
  flag2 = I2Cx->SR2;
  flag2 = flag2 << 16;
  /* Get the last event value from I2C status register */
  lastevent = (flag1 | flag2) & 0x0000ffff;
  /* Check whether the last event is equal to I2C_EVENT */
  if (lastevent == I2C_EVENT )
    /* SUCCESS: last event is equal to I2C_EVENT */
    status = SUCCESS;
  else
    /* ERROR: last event is different from I2C_EVENT */
    status = ERROR;
  /* Return status */
  return status;
void I2C_GenerateSTART(I2C_TypeDef* I2Cx, FunctionalState NewState)
  if (NewState != DISABLE)
    /* Generate a START condition */
    I2Cx->CR1 |= 1<<8;
  else
    /* Disable the START condition generation */
    I2Cx->CR1 &= ~(1<<8);
void I2C_GenerateSTOP(I2C_TypeDef* I2Cx, FunctionalState NewState)
    /* Generate a STOP condition */
    I2Cx->CR1 |= 1<<9;
  else
    /* Disable the STOP condition generation */
    I2Cx->CR1 &= ~(1<<9);
void I2C_SendData(I2C_TypeDef* I2Cx, u8 Data)
  /* Write in the DR register the data to be sent */
  I2Cx->DR = Data;
u8 I2C_ReceiveData(I2C_TypeDef* I2Cx)
  /* Return the data in the DR register */
  return (u8)I2Cx->DR;
int main(void)
        u8 i;
        u8 x;
        u16 t;
        u16 u16_flag,u16_flag1;
        u8 dir=1;
        Stm32_Clock_Init(9);         //ϵͳʱÖÓÉèÖÃ9*12MÄÚ²¿HSI
        delay_init(108);                    //ÑÓʱ³õʼ»¯36--108
        /*LED_Init();                                   //³õʼ»¯ÓëLEDÁ¬½ÓµÄÓ²¼þ½Ó¿Ú
        //BEEP_Init();                 //³õʼ»¯·äÃùÆ÷¶Ë¿Ú
        KEY_Init();                                                //³õʼ»¯ÊäÈë¶Ë¿Ú
        Output_Init();                                //³õʼ»¯Êä³ö¿ØÖƶ˿Ú
        HYM8563_init();
        uart_init(108,115200);
        uart3_init(27,115200);
        TIM2_Int_Init(5400,0);
        printf("U16_UP\r\n");
        USART3->DR = 0x55;
        RF_init();
        Adc_Init();
        //uart2_init(27,9600);
        //printf("U16_UP\r\n");
                //³õʼ»¯i2C1  ;
                RCC->APB2ENR|=1<<3;            //ʹÄÜPORTBʱÖÓ
                RCC->APB1ENR|=1<<21;
                RCC->APB1RSTR|=1<<21;   //ADC1¸´Î»
                RCC->APB1RSTR&=~(1<<21);//¸´Î»½áÊø
                AFIO->MAPR &= ~(1<<1);//I2C1ûÓÐÖØÓ³Éä
                //AFIO->MAPR |= ((u32)0x00000000);//0x03<<24;½ûÖ¹JTAG¹¦Äܽţ¬ÉèÖÃPB3PB4ΪIO¿Ú
                GPIOB->CRL&=0X00FFFFFF;
                GPIOB->CRL|=0XFF000000;        //
                PBout(6)=1;
                PBout(7)=1;
                I2C1->CR1=0;
                /* Enable the selected I2C peripheral */
    I2C1->CR1 |= 1<<0;
                I2C1->CR1 |= 1<<3;//´Ó
                I2C1->CR2=0;
                I2C1->CR2 |= 27<<0;
                I2C1->OAR1=0x4000;
                I2C1->OAR1 &=~(1<<15);//7bit address
                I2C1->OAR1 |= (iic_address&0xfe);
                I2C1->OAR2=0x0000;
                I2C1->OAR2 |=(iic_address2&0xfe);
                I2C1->OAR2 |= 1<<0;//ÆßλµØÖ·Ë«µØÖ·Ä£Ê½£»
                //=======cCCR================================
                /* DisEnable the selected I2C peripheral */
    I2C1->CR1 &= ~(1<<0);
                I2C1->CCR =0;
                I2C1->CCR &=~(1<<15);// f/s ¿ìËÙģʽ  ±ê׼ģʽ
                I2C1->CCR &=~(1<<14);// DUTY ¿ìËÙģʽϵÄÕ¼¿Õ±È L/H=2
                //ÉèÖÃÖ÷ģʽÊǵķ¢ËÍʼÖÕËÙ¶È200khz
                I2C1->CCR |= (27000/100) ;
                I2C1->TRISE=(27+1);//ÉÏÉýÑØ
                //I2C1->SR1=0;
                //I2C1->SR2=0;
                //I2C1->DR=0;
                        I2C1->CR1 |= 1<<0;//ʹÄÜ
                        //while((I2C1->SR2&(1<<1)));
                while(1)
                        I2C1->CR1 |= 1<<8;//I2C_GenerateSTART(I2C1, 1);//¿ªÊ¼ÐźÅ
                        delay_us(100);
                        //EV5ʼþ
                        while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT));
                        //========address================================
                        I2C1->DR=0xa2;
                        //EV6 EV8_1£¨¸ÃʼþÅжÏͬʱÅжÏÁËEV8_1ʼþ£©
                        while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
                        I2C1->DR=0x55;
                        //EV8ʼþ        I2C_EVENT_MASTER_BYTE_TRANSMITTED
                        while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTING)) ;
                        I2C1->DR=0x02;
                        while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED));
                        //I2C1->CR1 |= 1<<9;//I2C_GenerateSTOP(I2C_TypeDef* I2Cx, FunctionalState NewState)
                        I2C_GenerateSTOP(I2C1,ENABLE);                                  /*EV8_2ʼþÖеijÌÐòдֹͣ*/
//                        printf(" I2C1->CR1:%x\r\n" ,I2C1->CR1);
                        delay_us(20000);
V00 IIC.zip
1.41 MB, 下载次数: 4, 下载积分: ST金币 -1
工程文件
赞 收藏 评论7 发布时间:2016-5-20 16:58
7个回答
Better-407785 回答时间:2016-5-20 17:00:43
本人邮件 jyqcug@163.com
有解决了的大侠可以转发我学习一下, 另外其他和我一样的新手要是有疑问的也可以问我, 本人尽力回答。
涛哥2035 回答时间:2016-5-21 10:35:19
没听说过STM32F1系列芯片的IIC有问题吗?大家都不用硬件IIC,而用模拟IIC
Better-407785 回答时间:2016-5-26 09:41:48
幻想一下,比较期待能弄出来嘛!
modu8888 回答时间:2016-5-26 10:28:53
听说F1硬件有问题,你用F0试一下?
yklstudent 回答时间:2016-5-26 20:43:49
STM32F103可以跑这么高频率?
stickvc 回答时间:2019-4-26 10:05:08
看到了不精确的延时函数,再就是用了goto
Glenxu 回答时间:2019-8-8 23:12:34
延时给用中断好些。本来就不好找问题
