调试stm32f0的Usart时出现问题,按照我的理解,如果通过PC和stm32f030的开发板串口通信时,在初始化中开启接收中断,程序全速运行,当接受到PC上的串口调试工具发下来的数据后进入接收中断的,可是不知为什么,我在PC的串口调试软件中还没有发数据,就进入接收中断了?这是为什么?求高手指点,谢谢!
void USART1_Configuration(void)
/* Enable GPIO clock */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
/* Enable USART clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
/* Connect PA9 to USART1_Tx */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_1);
/* Connect PA10 to USART1_Rx */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_1);
/* Configure USART Tx and Rx as alternate function push-pull */
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10;
/* Enable the USART1 gloabal Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 3;
/* USARTx configuration ----------------------------------------------------*/
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- one Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = 115200;
/* When using Parity the word length must be configured to 9 bits */
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_Init(USART1, &USART_InitStructure);
/* Enable USART Receive data register not empty interrupt */
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
/* Enable USART */
USART_Cmd(USART1, ENABLE);
/* Clear Transmission complete flag */
USART_ClearFlag(USART1, USART_FLAG_TC);
查看中断接收到的是什么数据?
如果是0x00,那么除了STM32编程问题外,还要考虑转换器、串口助手等因素。遇到0x00,可以先从网上下载个其它的串口助手试试。
Like this...
USART_ClearITPendingBit(USART1, USART_IT_TC);
USART_ITConfig(USART1, USART_IT_TC, ENABLE);
接收的数据始终是0
好的,谢谢你的回复
那你最后怎么解决的,请指教,谢谢!
