stm32f030的Usart中断方式为什么始终进不了中断?
alisa123 提问时间:2016-5-29 17:59 /
我用stm32f030的Usart中断方式为什么始终进不了中断,求高手指点,谢谢!代码如下:
void USART1_Configuration(void)
    /* ʹÄÜAHBʱÖÓ */
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB |
                        RCC_AHBPeriph_GPIOC | RCC_AHBPeriph_GPIOF, ENABLE);
    /* ʹÄÜAPB2ʱÖÓ */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    /* ÍâÉèÖÐ¶Ï */
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;                  //IRQͨµÀ:´®¿Ú1
    NVIC_InitStructure.NVIC_IRQChannelPriority = 1;                    //ÓÅÏȼ¶ :1¼¶
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                    //ʹÄÜIRQͨµÀ
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_1);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_1);
    /* ¶¨ÒåUSART TX_RX Òý½ÅΪ¸´ÓÃÊä³ö */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10;            //Òý½Å
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;                       //¸´ÓÃģʽ
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                  //¸ßËÙ
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;                     //ÍÆÍêÊä³ö
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;                       //ÉÏÀ­
    USART²ÎÊý³õʼ»¯:  ²¨ÌØÂÊ     ´«ÊäλÊý   Í£Ö¹Î»Êý  Ð£ÑéλÊý
                        9600         8         1        0(NO)
    USART_InitStructure.USART_BaudRate = 9600;                         //É趨´«ÊäËÙÂÊ
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;        //É趨´«ÊäÊý¾ÝλÊý
    USART_InitStructure.USART_StopBits = USART_StopBits_1;             //É趨ֹͣλ¸öÊý
    USART_InitStructure.USART_Parity = USART_Parity_No ;               //²»ÓÃУÑéλ
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//²»ÓÃÁ÷Á¿¿ØÖÆ
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;    //ʹÓýÓÊպͷ¢Ë͹¦ÄÜ
    USART_Init(USART1, &USART_InitStructure);                          //³õʼ»¯USART1
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);                     //ʹÄÜUSART1½ÓÊÕÖжÏ
    USART_Cmd(USART1, ENABLE);
     /* Clear Transmission complete flag */
        USART_ClearFlag(USART1, USART_FLAG_TC);
void sInitMCU(void)
    USART1_Configuration();
  int main(void)
    sInitMCU();
    while(1)
void USART1_IRQHandler(void)
        if(USART_GetITStatus(USART1,USART_IT_RXNE) == SET)
        lubReceiveData = USART_ReceiveData(USART1);
        USART_ITConfig(USART1, USART_IT_TC, ENABLE);
        USART_SendData(USART1,lubReceiveData);
//       USART_ClearITPendingBit(USART1,)
    if(USART_GetITStatus(USART1,USART_IT_TC) == SET)
        USART_ITConfig(USART1, USART_IT_TC, DISABLE);
        USART_ClearITPendingBit(USART1,USART_IT_TC);
赞 收藏 1 评论6 发布时间:2016-5-29 17:59
6个回答
丹心汗青 回答时间:2016-10-25 13:42:09
楼主可调试ok了?
xhzheng 回答时间:2016-10-25 16:48:09
好像缺少启动中断的程序;
可参考HAL库的例程;
alisa123 回答时间:2016-10-26 09:15:21
调试好了,程序没问题 !
alisa123 回答时间:2016-10-26 09:16:24
xhzheng 发表于 2016-10-25 16:48
好像缺少启动中断的程序;
可参考HAL库的例程;
谢谢你的回复,程序中有启动中断的,是“USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);                     ”
alisa123 回答时间:2016-10-26 09:16:57
好像缺少启动中断的程序;
可参考HAL库的例程;
chifen 回答时间:2016-10-26 09:59:04
/* SysTick end of count event each 1ms */
  RCC_GetClocksFreq(&RCC_Clocks);
开始时钟,
SysTick_Config(RCC_Clocks.HCLK_Frequency / 100000); //内部定时器
加入试试
