stm32f4串口发数,用pc接收的数据不对
jpublic2008 提问时间:2016-6-4 22:31 /
stm32F427发送,用232转usb接到电脑上,用串口调试助手接收,发送6个字节是{3F,01,03,04,00,校验和},电脑接收的6个字节是{60 7F 7E DF 71 00},求助了。
程序代码如下:
void Uart_init(void)
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
   GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_9;  //RX
   GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_8;   //TX
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_USART3);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_USART3);
  USART_InitStructure.USART_BaudRate   = 115200;
  USART_InitStructure.USART_StopBits   = USART_StopBits_1;
  USART_InitStructure.USART_Parity     = USART_Parity_No;
  USART_InitStructure.USART_Mode                = USART_Mode_Tx | USART_Mode_Rx;
  USART_Init(USART3, &USART_InitStructure);
  USART_Cmd(USART3, ENABLE);
void Usart3_SendData(USART_TypeDef* USARTx, unsigned char TempData)
    while(!(USARTx->SR&0x80));
  //while(!(USARTx->SR&0x40)){};
  //while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET){}
    USARTx->DR = (TempData & (uint16_t)0x01FF);
//while((USARTx->SR&0x40)==0);
void usart3_send_data(unsigned char Send_number,unsigned char *Send_data)
  unsigned char i;
  for(i=0;i<Send_number;i++)
  Usart3_SendData(USART3, Send_data);
  //delay_ms(2);
void Sensor_Data_Generate_Send(void)
    unsigned char i=0;
Data_Buffer[0]=0x3F;
Data_Buffer[1]=0x01;
Data_Buffer[2]=0x03;
Data_Buffer[3]=0x04;
for(i=4;i<5;i++)
Data_Buffer=0x00;
    CHK_SUM=0;
    for(i=0;i<5;i++)
        CHK_SUM+=Data_Buffer;
    Data_Buffer[5]=CHK_SUM % 255;
usart3_send_data(6, Data_Buffer);
赞 收藏 评论7 发布时间:2016-6-4 22:31
7个回答
jpublic2008 回答时间:2016-6-5 08:55:33
盼回复,多谢了,调试了好久
xmshao 回答时间:2016-6-5 15:56:35
注意波特率等配置参数一致;
另外,硬件上也确认下。
jpublic2008 回答时间:2016-6-5 20:14:13
首先多谢回复。波特率应该没有问题,硬件上看什么呢?
lzts 回答时间:2016-6-7 09:08:18
串口这玩意, 调试时端口配置时要普通模式, 复用模式换着试下. 硬件的话就是外部晶振了. 晶振的下地电容, 还是晶振损坏都会影响的
参与人数 1ST金币 +2 收起 理由
zero99 + 2 赞一个!
废鱼 回答时间:2016-6-7 11:25:33
波特率不对,楼主用示波器看一下波特率是多少。还有主频时钟的配置。
参与人数 1ST金币 +2 收起 理由
zero99 + 2 很给力!
pener 回答时间:2016-6-7 18:34:35
  我也是401的串口弄不出来,直接用103的移过来也是不行
eefishing 回答时间:2016-7-10 13:57:58
问题找到了吗?
