本帖最后由 songshiqun2010 于 2019-6-13 13:28 编辑 uint8_t txbuf[1000]="helloworld\r\n"; uint8_t rxbuf[1000]=""; ART_HandleTypeDef huart1; HAL_UART_Receive_DMA(&huart1,rxbuf,sizeof(rxbuf)); 函数原型如下: /** * @brief Receives an amount of data in non blocking mode. * @param huart: pointer to a UART_HandleTypeDef structure that contains * the configuration information for the specified UART module. * @param pData: Pointer to data buffer * @param Size: Amount of data to be received * @note When the UART parity is enabled (PCE = 1) the data received contain the parity bit. * @retval HAL status */ HAL_StatusTypeDef HAL_UART_Receive_DMA(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size) { uint32_t *tmp; uint32_t tmp1 = 0; tmp1 = huart->State; if((tmp1 == HAL_UART_STATE_READY) || (tmp1 == HAL_UART_STATE_BUSY_TX)) { if((pData == NULL ) || (Size == 0)) { return HAL_ERROR; } /* Process Locked */ __HAL_LOCK(huart); huart->pRxBuffPtr = pData; huart->RxXferSize = Size; huart->ErrorCode = HAL_UART_ERROR_NONE; /* Check if a transmit process is ongoing or not */ if(huart->State == HAL_UART_STATE_BUSY_TX) { huart->State = HAL_UART_STATE_BUSY_TX_RX; } else { huart->State = HAL_UART_STATE_BUSY_RX; } /* Set the UART DMA transfer complete callback */ huart->hdmarx->XferCpltCallback = UART_DMAReceiveCplt; /* Set the UART DMA Half transfer complete callback */ huart->hdmarx->XferHalfCpltCallback = UART_DMARxHalfCplt; /* Set the DMA error callback */ huart->hdmarx->XferErrorCallback = UART_DMAError; /* Enable the DMA Stream */ tmp = (uint32_t*)&pData; HAL_DMA_Start_IT(huart->hdmarx, (uint32_t)&huart->Instance->DR, *(uint32_t*)tmp, Size); /* Enable the DMA transfer for the receiver request by setting the DMAR bit in the UART CR3 register */ huart->Instance->CR3 |= USART_CR3_DMAR; /* Process Unlocked */ __HAL_UNLOCK(huart); return HAL_OK; } else { return HAL_BUSY; } } 传送门 HAL UART DMA 环形缓冲接收不定长数据包 |
楼下有高见吗
用缓存存储数据,整合后发送或者处理。
