stm32f429 dma 中断问题
请输入。 提问时间:2016-7-26 18:22 /
32的dma中断可以进  但是判断不了中断标志  然后就卡住了
下面是dma的配置 和中断服务函数
  1. /* DMA2 Stream0 channel2 configuration **************************************/
  2.   DMA_InitStructure.DMA_Channel = DMA_Channel_2;
  3.   DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC3_DR_ADDRESS;
  4.   DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)ADC3Value;
  5.   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  6.   DMA_InitStructure.DMA_BufferSize = 1000;
  7.   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  8.   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  9.   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
  10.   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
  11.   DMA_InitStructure.DMA_Mode =DMA_Mode_Normal;
  12.   DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  13.   DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  14.   DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  15.   DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  16.   DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  17.   DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  18.
  19.         DMA_ITConfig(DMA2_Stream0, DMA_IT_TC ,ENABLE);
  20.         DMA_Cmd(DMA2_Stream0, ENABLE);
  21.
  22.
  23.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  24.     NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
  25.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
  26.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
  27.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  28.     NVIC_Init(&NVIC_InitStructure);
  1. void DMA2_Stream0_IRQHandler()
  2. {
  3.
  4.         if (DMA_GetITStatus(DMA2_Stream0,DMA_FLAG_TCIF0))
  5.         {
  6.                 if (dma_flag == 0)
  7.                 {
  8.
  9.                         dma_flag = 1;
  10.                         arm_copy_q31(ADC3Value,ADC3Voltage,1000);
  11.                 }
  12.                 DMA_ClearITPendingBit(DMA2_Stream0,DMA_FLAG_TCIF0);
  13.         }
  14.
  15. }
求大神帮忙啊~
收藏 评论1 发布时间:2016-7-26 18:22
请输入。 回答时间:2016-7-26 19:04:42
。。。找到问题了    是吧中断判断标志和读取标志弄混了
意法半导体边缘AI套件
ST - 理想汽车豪华SUV案例
ST意法半导体智能家居案例
STM32 ARM Cortex 32位微控制器
