F407 ADC定时采样后DMA自动传输错误
wamer 提问时间:2016-8-17 10:54 /
下面是程序,请论坛大神指导一下。
static void ADC2_DMA_Config(void)
  ADC_InitTypeDef       ADC_InitStructure;
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  DMA_InitTypeDef       DMA_InitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
  /* Enable ADC3, DMA2 and GPIO clocks ****************************************/
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA, ENABLE);                //DMA2 GPIOA时钟使能
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);                //ADC2时钟使能
         /* Configure ADC3 Channel13 pin as analog input ******************************/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;                        //PA6
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;                //模拟输入
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;                //无上下拉输出
        GPIO_InitStructure.GPIO_Speed = GPIO_High_Speed ;
        DMA_DeInit(DMA2_Stream2);
  /* DMA2 Stream0 channel2 configuration **************************************/
  DMA_InitStructure.DMA_Channel = DMA_Channel_2;                //通道2
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t) &(ADC2->DR);                //外设地址
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t) &ADCoverVaule;                //内存地址
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;                //DMA方向,外设到内存
  DMA_InitStructure.DMA_BufferSize = 1;                //数据量
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                //外设不递增
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                //内存递增
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;                //外设半字传输
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;                //内存半字接收
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;                //循环模式
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;                //高优先级
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;                //FIFO模式管
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;                //FIFO半工
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;                //内存BURST单次
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;                //外设BURST单次
  DMA_Init(DMA2_Stream2, &DMA_InitStructure);                //初始化DMA
  /* ADC Common Init **********************************************************/
        ADC_DeInit();                //ADC复位
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;        //独立模式
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div6;                //6分频
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;                //DMA模式
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;                //两次传送间隔5时钟周期
  ADC_CommonInit(&ADC_CommonInitStructure);                //ADC通用初始化
  /* ADC2 Init ****************************************************************/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;                //精度12位
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;                //扫描模式关闭
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;                //连续模式关闭
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;                //外设上升沿激活
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_TRGO;                //T2 TRGO激活
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;                //右对齐
  ADC_InitStructure.ADC_NbrOfConversion = 1;                //1个通道
  ADC_Init(ADC2, &ADC_InitStructure);                //初始化ADC2
  /* ADC3 regular channel13 configuration *************************************/
  ADC_RegularChannelConfig(ADC2, ADC_Channel_6, 1, ADC_SampleTime_480Cycles);                //ADC2通道6 规则排序1
/* Enable DMA request after last transfer (Single-ADC mode) */
  /* Enable ADC3 DMA */
  /* Enable ADC3 */
  DMA_Cmd(DMA2_Stream2, ENABLE);                //使能DMA
  ADC_DMARequestAfterLastTransferCmd(ADC2, ENABLE);                //转换完毕DMA自动请求
  ADC_Cmd(ADC2, ENABLE);                //ADC使能
        ADC_DMACmd(ADC2, ENABLE);                //ADC-DMA使能   这行不使能时 ADC2->DR值是刷新的,使能后就失效了
        ADC_SoftwareStartConv(ADC2);
void Tim2_Init_TRGO(u16 Period,u16 Prescaler)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
        TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Down;
        TIM_TimeBaseInitStructure.TIM_Period=Period;
        TIM_TimeBaseInitStructure.TIM_Prescaler=Prescaler;
        TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructure);
        TIM_SelectOutputTrigger(TIM2,TIM_TRGOSource_Update);
        TIM_Cmd(TIM2,ENABLE);
int main(void)
        ADC2_DMA_Config();
        Tim2_Init_TRGO(26250-1,0);
  while (1)
赞 收藏 1 评论7 发布时间:2016-8-17 10:54
7个回答
wamer 回答时间:2016-8-17 11:12:07
查出来ADC2->SR的OVR被DMA置1了,有没有大神看看解决办法
无薪税绵 回答时间:2016-8-19 12:50:36
我不懂,只能帮楼主加点人气了。
wenyangzeng 回答时间:2016-8-19 13:28:08
这里是使用ADC时钟触发ADC
这里是使用TIM2时钟触发ADC
楼主你这样触发ADC能得到正确转换结果吗?
参与人数 1ST金币 +2 收起 理由
zero99 + 2 赞一个!
wamer 回答时间:2016-8-19 15:05:37
这里是使用ADC时钟触发ADC
软件触发那个是我拿来测试的。 单通道已经调好了,现在在写交替模式9通道如何处理。
feixiang20 回答时间:2016-8-19 15:42:46
可能是停止程序的时候,DMA没有停下来
参与人数 1ST金币 +2 收起 理由
zero99 + 2 赞一个!
zero99 回答时间:2016-9-1 09:23:45
楼主问题解决了吗
wamer 回答时间:2016-9-7 11:08:45
zero99 发表于 2016-9-1 09:23
楼主问题解决了吗
解决了,通道选错了。
