stm8低速时钟校准问题
我大龙哥哥 提问时间:2016-8-22 15:28 /
stm8低速时钟校准问题
stm8L10x标准库例程里的这个时钟校准函数一直不理解,求详解啊,一直不理解例程里的低速时钟校准
函数如下:
  * @brief  Update APR register with the measured LSI frequency.
  * @note   AWU must be disabled to avoid unwanted interrupts.
  * @note   Prescaler calculation:
  *         A is the integer part of LSIFreqkHz/4 and x the decimal part.
  *         x <= A/(1+2A) is equivalent to A >= x(1+2A)
  *         and also to 4A >= 4x(1+2A) [F1]
  *         but we know that A + x = LSIFreqkHz/4 ==> 4x = LSIFreqkHz-4A
  *         so [F1] can be written :
  *         4A >= (LSIFreqkHz-4A)(1+2A)
  * @param  LSIFreqHz Low Speed RC frequency measured by timer (in Hz).
  * @retval None
void AWU_LSICalibrationConfig(uint32_t LSIFreqHz)
  uint16_t lsifreqkhz = 0x0;
  uint16_t A = 0x0;
  /* Check parameter */
  assert_param(IS_LSI_FREQUENCY(LSIFreqHz));
  lsifreqkhz = (uint16_t)(LSIFreqHz / 1000); /* Converts value in kHz */
  /* Calculation of AWU calibration value */
  A = (uint16_t)(lsifreqkhz >> 2U); /* Division by 4, keep integer part only */
  if ((4U * A) >= ((lsifreqkhz - (4U * A)) *(1U + (2U * A))))
    AWU->APR = (uint8_t)(A - 2U);
  else
    AWU->APR = (uint8_t)(A - 1U);
收藏 1 评论3 发布时间:2016-8-22 15:28
3个回答
zcl201207 回答时间:2016-8-22 23:03:03
不用理解,直接调用就可以了。。。
我大龙哥哥 回答时间:2016-9-7 09:13:37
zcl201207 发表于 2016-8-22 23:03
不用理解,直接调用就可以了。。。
好吧~我想搞清楚
帅鹰杨 回答时间:2017-3-13 15:18:39
现在理解了?能说一下吗
