spi3无波形输出,已开afio,禁用jtag。
any012 提问时间:2016-8-24 16:00 /
赞 收藏 评论28 发布时间:2016-8-24 16:00
28个回答
/tiaostrike 回答时间:2016-8-25 16:27:30
void SPI3_Configuration(void)
          SPI_InitTypeDef  SPI_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
        GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
        RCC_APB1PeriphClockCmd(        RCC_APB1Periph_SPI3,  ENABLE );                                //SPI3时钟使能
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                                          //PB3/4/5复用推挽输出
        GPIO_Init(GPIOB, &GPIO_InitStructure);        //初始化GPIOB
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;                                                        //W5500_CS        PA15
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;                                                        //W5500_RST PA12
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;                                                        //W5500_INT        PA11
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_SetBits(GPIOB, GPIO_Pin_3  | GPIO_Pin_4  | GPIO_Pin_5);                          //PB3/4/5输出高电平
        GPIO_SetBits(GPIOA, GPIO_Pin_15 | GPIO_Pin_12 | GPIO_Pin_11);
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                                                //设置SPI工作模式:设置为主SPI
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                                        //设置SPI的数据大小:SPI发送接收8位帧结构
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;                                                        //串行同步时钟的空闲状态为高电平
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;                                                //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                                                        //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;        //定义波特率预分频的值:波特率预分频值为4
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                                        //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
        SPI_InitStructure.SPI_CRCPolynomial = 7;                                                        //CRC值计算的多项式
        SPI_Init(SPI3, &SPI_InitStructure);        //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
        SPI_Cmd(SPI3, ENABLE);        //使能SPI外设
uint8_t SPI3_ReadWriteByte(uint8_t Data)
        /* 当 SPI发送缓冲器非空时等待 */
        while(SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_TXE) == RESET);
        /* 通过 SPI3发送一字节数据 */
        SPI_I2S_SendData(SPI3, Data);
        /* 当SPI接收缓冲器为空时等待 */
        while(SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_RXNE) == RESET);
        /*!< Return the byte read from the SPI bus */
        return SPI_I2S_ReceiveData(SPI3);
用这个试试,我这个程序是可以用的
废鱼 回答时间:2016-8-25 16:35:12
any012 发表于 2016-8-25 15:58
SPI3不需要重定义吧?
默认的复用功能就是SPI3.
不好意思啊。我看的是103xb的手册,里面没有SPI3。
废鱼 回答时间:2016-8-25 16:44:39
测试一下波形。
any012 回答时间:2016-8-26 10:51:41
惊醒!
我这焊的就是VBT6...
废鱼 回答时间:2016-8-26 10:54:56
但是你的工程用的是VE系列的,把这个改成VB的吧。
zhangxu56726 回答时间:2016-8-26 10:55:18
问题解决了。恭喜!
any012 回答时间:2016-8-26 11:53:13
嗯,是用之前的工程模板,以为引脚相同的stm32,只有容量不一样。
貌似需要把SPI1重映射到PB3PB4PB5了。
zhangxu56726 回答时间:2016-8-26 12:05:06
貌似需要把SPI1重映射到PB3PB4PB5了。 ...
昨天就发帖问你是哪个型号的,你没回,我以为你确认过
any012 回答时间:2016-8-26 14:50:45
感谢。
焊的是VB,工程一直沿用的VE。
想当然的以为引脚一致,只是容量不一样,其他一样...
现在没问题了。
  1. void SPI1_Init(void)
  2. {
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         SPI_InitTypeDef SPI_InitStructure;
  5.
  6.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO | RCC_APB2Periph_SPI1, ENABLE);
  7. //        RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
  8.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
  9.         GPIO_PinRemapConfig(GPIO_Remap_SPI1, ENABLE);
  10.
  11.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_5;
  12.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  13.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  14.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  15.
  16.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  18.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  19.
  20.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  21.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  22.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  23.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  24.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  25.         SPI_InitStructure.SPI_NSS =SPI_NSS_Soft;
  26.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
  27.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  28.         SPI_InitStructure.SPI_CRCPolynomial = 7;
  29.         SPI_Init(SPI1, &SPI_InitStructure);
  30.         SPI_Cmd(SPI1, ENABLE);
  31. }
any012 回答时间:2016-8-26 16:18:19
高兴的早了些。
重映射SPI1到PB3PB4PB5后,发现程序不卡死了,定时器控制的灯每秒可以反转一次。于是就高兴的认为问题解决了。
然后,用示波器测量PB3波形,结果始终是高电平...
看样子SPI仍然未正常工作,只是这次,没有停在等待SPI发送数据完成这里。
废鱼 回答时间:2016-8-26 16:37:06
没有工作可以查一下IO配置,引脚重映射、时钟配置等。
any012 回答时间:2016-8-26 16:55:51
量的是PB3,对应的是SCLK,电平是2.5V左右。
PB5,对应MOSI,有波形,我是不断发0x55,看了下频率大概在140K左右。
72M/256,大概是281KHz,发送的数是01010101,所以测得波形是140K,是正常的。
好奇为什么没有SCLK波形。
硬件是这样接的,SCLK和PB5外边串电阻接高速光耦的负端,光耦正端接3.3V。
试着将PB4,PB5由推挽复用改为开漏复用,问题依旧。
any012 回答时间:2016-8-29 09:01:19
测量SCLK有波形,MOSI没波形。
换下思维,不是MOSI没波形,而是MOSI是FF。
不过我发送的是0X55,SPI模式设置错误?
any012 回答时间:2016-8-29 10:16:24
测试到管脚,有波形,是我的问题,之前测的是光耦之后的位置。
现在SPI算是正常了。
12
