关于ADC+DMA的疑问
云鹤松 提问时间:2016-9-5 15:42 /
我用的是STM32F429芯片
首先贴代码:
void ADC1_CH6_DMA_Config(void)
  ADC_InitTypeDef       ADC_InitStructure;
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  DMA_InitTypeDef       DMA_InitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
//  DMA_DeInit(DMA2_Stream0);
  /* DMA2 Stream0 channe0 configuration **************************************/
  DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address; //外设地址
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC_ConvertedValue;        //内存地址
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;       //dma传输方向单向
  DMA_InitStructure.DMA_BufferSize = 2; //设置DMA在传输时缓冲区的长度 word
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;      //设置DMA的外设递增模式,一个外设
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;       //设置DMA的内存递增模式,
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;   //外设数据字长
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;   //内存数据字长
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;       //设置DMA的传输模式:连续不断的循环模式
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;   //设置DMA的优先级别
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
  /* Configure ADC1 Channel6 pin as analog input ******************************/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  /* ADC Common Init **********************************************************/
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;      //ADC工作模式:ADC1和ADC2工作在独立模式
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;   //ADC时钟为APB2的4分频->84/4=21MHZ(F407ADC在2.4-3.6V供电电压下最大速率36M,稳定速度为30M)
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
  /* ADC1 Init ****************************************************************/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;//精度为12位
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;  //扫描方式
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;    //连续转换
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;   //转换由软件而不是外部触发启动
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;        //ADC数据右对齐
  ADC_InitStructure.ADC_NbrOfConversion = 2;     //规定了顺序进行规则转换的ADC通道的数目
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channe6 configuration *************************************/
  ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 1, ADC_SampleTime_3Cycles);     //配置ADC1规则组(得出其单次采样时间为->(3+12)/21≈0.7us)
  ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 2, ADC_SampleTime_3Cycles);
/* Enable DMA request after last transfer (Single-ADC mode) */
  ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConv(ADC1);//软件启动转换
上面是我初始化ADC+DAM的代码。
下面我有3个问题。
问题1:
主函数中我是这样读取ADC值得
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ))//等待转换结束delay(1000);
    AD_value_1 = ADC_ConvertedValue[0];
    AD_value_2 = ADC_ConvertedValue[1];
    AD_value_1= (float)(AD_value_1/0xfff)*3.3;
    AD_value_2 = (float)(AD_value_2/0xfff)*3.3;
为什么我的程序老卡在  while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ))   这句上?
问题2:如何计算我的采样频率?
这点我不清楚,是2个通道每次采集用时0.7us还是每个通道都是0.7us.
还有就是,如何再提高下采集频率?
问题3:采集到的数据好多都是连着重复的,比如会有好多个0连着,还有好多2.632连着,数据根本不像正弦波。(我使用的是正弦波信号发生器,200KHZ,VPP=5V)。
赞 收藏 1 评论6 发布时间:2016-9-5 15:42
6个回答
废鱼 回答时间:2016-9-5 16:55:25
1、等待DMA完成标志位,不是ADC的
2、每次采集
3、应该是程序中处理ADC导致的。先测试DMA正常后,再看看数据。
参与人数 1ST金币 +2 收起 理由
zero99 + 2 赞一个!
xmshao 回答时间:2016-9-5 17:10:37
1、程序老卡在  while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ))   这句?
什么情况下发生的? 不要用单步验证这点。
2、根据你的配置每次每个通道的转换时间为0.7us. 提高ADC时钟和减少采样时间可以提高采样频率。
3、硬件正确的情况下,还需配置合适采样周期。
另外,ADC直接可转换的最高电压为3.6V.如果高了的话你得做前期处理。
参与人数 1ST金币 +2 收起 理由
zero99 + 2 很给力!
云鹤松 回答时间:2016-9-5 18:44:20
什么情况下发生的? 不要用单步 ...
如何提高ADC的时钟?
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;  把4分频,变成ADC_Prescaler_Div2分频?除了这一点还能不能提高自身的ADC时钟?
配置合适采样周期
是不是满足采样定理就可以了?
我把ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 1, ADC_SampleTime_3Cycles); 里的 ADC_SampleTime_3Cycles改大些,是不是精度能提高?
云鹤松 回答时间:2016-9-7 11:54:11
有人么?帮我解答下吧!!!
云鹤松 回答时间:2016-9-9 09:32:22
结贴,STM32F4的ADC采集1K的信号还行,但是频率大些的不适合。最后决定采用AD的ADC芯片。
参与人数 1ST金币 +2 收起 理由
zero99 + 2 结贴奖励
maozheng110 回答时间:2016-9-10 16:14:32
学习一下 ADC+DMA
