进不了中断,找 了一天了,求大神指点
ssyx1234 提问时间:2016-9-21 19:53 /
#include "bsp_spwm_output.h"
uint16_t  CCR1_Val ;
uint16_t  CCR2_Val = 1500 ;
uint16_t  CCR3_Val = 900;
static void TIM1_Mode_Config(void)
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    /* GPIOA clocks enable */
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    /* TIM1 clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_9 | GPIO_Pin_10;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOA,&GPIO_InitStructure);
    /* Connect TIM pins to AF6 */
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_6);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_6);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_6);
    /* Time Base configuration */
    TIM_TimeBaseStructure.TIM_Period =2999;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;    //ÉèÖÃÔ¤·ÖƵ£º²»Ô¤·ÖƵ£¬¼´Îª72MHz
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;    //ÉèÖÃʱÖÓ·ÖÆµÏµÊý£º²»·ÖƵ(ÕâÀïÓò»µ½)
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1;  //ÏòÉϼÆÊýģʽ
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /*PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;        //ÅäÖÃΪPWMģʽ1
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val;       //ÉèÖÃÌø±äÖµ£¬µ±¼ÆÊýÆ÷¼ÆÊýµ½Õâ¸öֵʱ£¬µçƽ·¢ÉúÌø±ä
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //µ±¶¨Ê±Æ÷¼ÆÊýֵСÓÚCCR1_ValʱΪ¸ßµçƽ
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
  TIM_OC2Init(TIM1, &TIM_OCInitStructure);     //ʹÄÜͨµÀ1
  TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig( TIM1,ENABLE);
  TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
  TIM_OC3Init(TIM1, &TIM_OCInitStructure);     //ʹÄÜͨµÀ4
  TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
    TIM_UpdateRequestConfig( TIM1, TIM_UpdateSource_Regular);
  TIM_ITConfig(TIM1,TIM_IT_Update | TIM_IT_Trigger,ENABLE);/* TIM3 enable counter */
  TIM_Cmd(TIM1, ENABLE);     //ʹÄܶ¨Ê±Æ÷3
    TIM_ClearFlag(TIM1, TIM_FLAG_Update);
    TIM_CtrlPWMOutputs(TIM1, ENABLE);
     void NVIC_Configuration(void)
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQn;   //TIM1ÖжÏ
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 6;
void TIM1_SPWM_Init(void)
     TIM1_Mode_Config();
     NVIC_Configuration();
赞 收藏 1 评论8 发布时间:2016-9-21 19:53
8个回答
xmshao 回答时间:2016-9-22 08:11:45
你注意到底是触发中断  还是捕捉中断;
另外 你到底是哪个STM32型号,注意启动文件的一致性;
参与人数 1ST金币 +2 收起 理由
ssyx1234 回答时间:2016-9-22 08:15:58
触发中断,我用TIM2可以,TIM1就不行,不知道哪里出问题了。。。
chenbourne 回答时间:2016-9-22 09:50:12
签到签到
高二毛 回答时间:2016-9-22 10:07:58
先用TIM1调调定时中断能进去不,先保证配置什么没有问题。
ssyx1234 回答时间:2016-9-22 10:49:09
进不去啊!
hjl2832 回答时间:2016-9-22 13:45:55
,你上面的代码不是把TIMER1配置成了PWM模式了吗?
hjl2832 回答时间:2016-9-22 13:46:58
既不是定时模式,也不是计数模式,更不是输入捕获。
ly499574529 回答时间:2016-9-22 13:54:02
看看函数名与.S的对的起不
