UCOS/III如何切换到新任务?
郁工 提问时间:2016-10-11 15:04 /
UCOS/III 是在PendSV中断里切换任务的,最后BX      LR(见红色字体),LR是旧任务返回地址, 所以应该跳到旧任务继续执行,为什么会跳转到新任务了呢?希望高手能解惑。PendSV中断代码如下(摘自开发板例程):
OS_CPU_PendSVHandler
    CPSID   I                                                   ; Prevent interruption during context switch
    MRS     R0, PSP                                             ; PSP is process stack pointer
    CBZ     R0, OS_CPU_PendSVHandler_nosave                     ; Skip register save the first time
    SUBS    R0, R0, #0x20                                       ; Save remaining regs r4-11 on process stack
    STM     R0, {R4-R11}
    LDR     R1, =OSTCBCurPtr                                    ; OSTCBCurPtr->OSTCBStkPtr = SP;
    LDR     R1, [R1]
    STR     R0, [R1]                                            ; R0 is SP of process being switched out
        ; At this point, entire context of process has been saved
    PUSH    {R14}                                               ; Save LR exc_return value
    LDR     R0, =OSTaskSwHook                                   ; OSTaskSwHook();
    BLX     R0
    POP     {R14}
    LDR     R0, =OSPrioCur                                      ; OSPrioCur   = OSPrioHighRdy;
    LDR     R1, =OSPrioHighRdy
    LDRB    R2, [R1]
    STRB    R2, [R0]
    LDR     R0, =OSTCBCurPtr                                    ; OSTCBCurPtr = OSTCBHighRdyPtr;
    LDR     R1, =OSTCBHighRdyPtr
    LDR     R2, [R1]
    STR     R2, [R0]
    LDR     R0, [R2]                                            ; R0 is new process SP; SP = OSTCBHighRdyPtr->StkPtr;
    LDM     R0, {R4-R11}                                        ; Restore r4-11 from new process stack
    ADDS    R0, R0, #0x20
    MSR     PSP, R0                                             ; Load PSP with new process SP
    ORR     LR, LR, #0x04                                       ; Ensure exception return uses process stack
    CPSIE   I
   BX      LR                                                  ; Exception return will restore remaining context
    END
赞 收藏 评论2 发布时间:2016-10-11 15:04
moyanming2013 回答时间:2016-10-11 15:52:10
BX LR是切换到调用pendsv的地方了,不是任务地址。
郁工 回答时间:2016-10-12 10:41:47
没有理解cortex内核中断执行过程,就会产生这个疑问。
cortex内核产生中断时,自动将R0~R3、R12、LR、PC、XPSR这8个寄存器压入当前的堆栈,然后执行中断服务程序。进入中断服务例程后,LR中保存的不是返回地址,而是返回时所使用的芯片模式和堆栈寄存器的标示,只能是0xFFFFFFF1、0xFFFFFFF9或者是0xFFFFFFFD这3个值中的一个,因此可以ORR     LR, LR, #0x04,进行堆栈选择。
cortex内核芯片如何从中断中返回?中断执行结束后,R0~R3、R12、LR、PC、XPSR出栈,LR值赋给PC,程序正确返回。
