STM32点亮LED
在路上11111111 发布时间:2016-10-27 20:05
#define _IO volatile: }; [# U# }) z' K2 c( r
typedef unsigned int uint32_t;# \7 x7 E" F6 G7 U: r% }3 M
typedef _IO uint32_t vu32;" _7 @+ W; g6 [5 u9 H: X: c% `
typedef unsigned short int uint16_t;7 }/ l& D5 i: X: s5 d
2 k3 s$ w% M6 |2 r3 j1 F' {
4 C4 d& c- E5 a+ d9 l# d% M#define GPIO_Pin_0   ((uint16_t)0x0001)//0000000000000001第一引脚置1(对应的是BSRR和BRR寄存器的16位)
0 ~2 K5 K/ t( w/ ~6 q% w' A+ w1 G& g4 \#define GPIO_Pin_1   ((uint16_t)0x0002)//0000000000000010第二引脚置1(对应的是BSRR和BRR寄存器的16位)
" d6 _2 A) S0 e#define GPIO_Pin_2   ((uint16_t)0x0004)//0000000000000100第三引脚置1(对应的是BSRR和BRR寄存器的16位)8 }# |# h, X2 X# G1 k" i! ~9 B" I* a
#define GPIO_Pin_3   ((uint16_t)0x0008)//0000000000001000第四引脚置1(对应的是BSRR和BRR寄存器的16位)# U+ }- b) h. O6 S. }
#define GPIO_Pin_4   ((uint16_t)0x0010)//0000000000010000第五引脚置1(对应的是BSRR和BRR寄存器的16位)
8 G0 e4 q5 d4 D#define GPIO_Pin_5   ((uint16_t)0x0020)//0000000000100000第六引脚置1(对应的是BSRR和BRR寄存器的16位)4 l% ]# N4 T# X0 E/ V! W
#define GPIO_Pin_6   ((uint16_t)0x0040)//0000000001000000第七引脚置1(对应的是BSRR和BRR寄存器的16位)$ w+ f" M- W1 c6 i* @2 @- @2 D# |+ t
#define GPIO_Pin_7   ((uint16_t)0x0080)//0000000010000000第八引脚置1(对应的是BSRR和BRR寄存器的16位)
9 f4 q! m6 W- v) u0 f+ N4 j' I#define GPIO_Pin_8   ((uint16_t)0x0100)//0000000100000000第九引脚置1(对应的是BSRR和BRR寄存器的16位)
# G: a' H. m! x( @4 f$ j0 ^- _2 ~+ x#define GPIO_Pin_9   ((uint16_t)0x0200)//0000001000000000第十引脚置1(对应的是BSRR和BRR寄存器的16位)6 E! d) Z$ A3 |7 ^* `3 U/ v
#define GPIO_Pin_10  ((uint16_t)0x0400)//0000010000000000第11引脚置1(对应的是BSRR和BRR寄存器的16位)
) h( m/ P, p6 X5 }# O#define GPIO_Pin_11  ((uint16_t)0x0800)//0000100000000000第12引脚置1(对应的是BSRR和BRR寄存器的16位)
8 X; H/ v5 u% V! d# G' s" \# {#define GPIO_Pin_12  ((uint16_t)0x1000)//0001000000000000第13引脚置1(对应的是BSRR和BRR寄存器的16位)
* J: g* w, p% x; K( L- o! b) V6 I#define GPIO_Pin_13  ((uint16_t)0x2000)//0010000000000000第14引脚置1(对应的是BSRR和BRR寄存器的16位)
- J& ]6 W: u0 [( W& N6 ?#define GPIO_Pin_14  ((uint16_t)0x4000)//0100000000000000第15引脚置1(对应的是BSRR和BRR寄存器的16位)
' b2 h, h2 r: r  z  @#define GPIO_Pin_15  ((uint16_t)0x8000)//1000000000000000第16引脚置1(对应的是BSRR和BRR寄存器的16位)4 o; j2 R# |, m  C" S% g) [) n0 r
#define GPIO_Pin_All ((uint16_t)0xFFFF)//11111111111111118 E" v* k9 P" y. ?
) k) V% r2 u) m
' `2 a) [8 e( {8 _/ b" ]#define RCC_APB2Periph_AFIO   ((uint32_t)0x00000001)$ r  o. n, a5 o" e' Z) S
#define RCC_APB2Periph_GPIOA  ((uint32_t)0x00000004)1 o1 M( i  R3 A, T: ~" G. m- F
#define RCC_APB2Periph_GPIOB  ((uint32_t)0x00000008)
. w, |; t" Q+ F( A; ^9 U) o1 X#define RCC_APB2Periph_GPIOC  ((uint32_t)0x00000010)
6 ]: k2 P& i6 I6 P#define RCC_APB2Periph_GPIOD  ((uint32_t)0x00000020)//这个是0000000000010000   主要是为了配合时钟的16位(其中第5位是IO口D的使能时钟位)
# r1 Q5 P; O: @- y# x& v7 E# S/***************GPIOD**********/5 b7 \- ]: `6 k5 r( j% F3 Q2 }: A
typedef struct
. `1 F) ^/ i' S; L{4 Z8 W$ r% A, p7 D9 r9 p
   _IO uint32_t CRL;//端口配置低寄存器  |  Z) k5 Q6 U5 r' a
   _IO uint32_t CRH;//端口配置高寄存器
  [  d; n$ r7 _   _IO uint32_t IDR;//端口输入数据寄存器
, j+ m# m# e" M( _- {. a/ {   _IO uint32_t ODR;//端口输出数据寄存器
8 G  ^2 W( w: }   _IO uint32_t BSRR;//端口位设置/清除寄存器
& O& P! _9 w5 T7 V   _IO uint32_t BRR;//端口位清除寄存器, R+ ^5 I8 _) d, t, X
   _IO uint32_t LCKR;//端口配置锁定寄存器; p- A/ f  d6 P  U
}GPIO_TypeDef;9 X/ T. @7 i- `( t3 K7 F& ^) ^
' `2 g! |  C  R$ ~# W
typedef struct 6 Q/ c( e4 }7 d# d9 o* q
{; t4 R2 Z- Z5 X8 E( A  f
   _IO uint32_t CR;//时钟控制寄存器
9 Y1 b% u% L! I5 h   _IO uint32_t CFGR;//时钟配置寄存器5 W) A* k" v* a3 s9 m
   _IO uint32_t CIR;//时钟中断寄存器- E& R( b/ u! R; L$ w' }
   _IO uint32_t APB2RSTR;//APB2外设复位寄存器
5 `. P6 {! i5 K8 ~2 \) r1 G$ L) O   _IO uint32_t APB1RSTR;//APB1外设复位寄存器7 q" O2 R" L9 a% ]  @5 ~& x
   _IO uint32_t AHBENR;//AHB外设时钟使能寄存器
( f/ d, y0 q$ ^  `   _IO uint32_t APB2ENR;//APB2外设时钟使能寄存器
" X4 I% z( P$ [0 D' V; Y3 g: b# l   _IO uint32_t APB1ENR;//APB1外设时钟使能寄存器
" J. s9 W$ b! F: F( ~   _IO uint32_t BDCR;//备份域控制寄存器6 H, \; t1 `( I+ g4 `. i; m
   _IO uint32_t CSR;//控制/状态寄存器! D3 v0 C5 ]1 h
}RCC_TypeDef;
2 H% u2 C0 u% \5 m& D" ^; S- Z7 v6 Y0 }' Z  b: H# _& Q0 |
4 J* R# ~2 E' S: w  W% d* A" o
/***********GPIO管脚的内存地址***********/
% U# q6 |7 Y1 m. Q% A% h( n! f#define PERIPH_BASE     ((uint32_t)0x40000000), z$ |6 g9 A9 R
#define APB2PERIPH_BASE (PERIPH_BASE+0x10000)" v' `' j! r9 {, }- I  L
#define GPIOD_BASE      (APB2PERIPH_BASE+0x1400)* X: b$ u0 J. ^+ \$ p5 D% t  P
#define GPIOD           ((GPIO_TypeDef *)GPIOD_BASE)
0 `+ y0 r: v5 X- T: ]. n+ ^
0 C; J7 h1 }0 \1 }+ c+ `( S/**********RCC时钟***********************/
3 C" v$ o' a$ u+ Z/ X#define AHBPERIPH_BASE  (PERIPH_BASE+0x20000)8 t  I4 q( r2 V+ w
#define RCC_BASE        (AHBPERIPH_BASE+0x1000)
" h5 H" j* b& O0 V#define RCC             ((RCC_TypeDef *)RCC_BASE)3 G% f' [9 ]- S5 \3 Y2 D5 I
/ S; C5 ]4 P- l0 A
' J( r: Q' v) O; d- ?2 z" Yvoid Delay(uint32_t nCount)
. J/ \' F) P4 \* }1 L, ]* z2 L{' U/ Y: Z% e/ d& H# P8 E
    for(;nCount!=0;nCount--);
7 c8 c) {& g/ U' R: n# M  y& C}0 R2 }( q; ]7 H) v
int main(void)
* |6 f# V0 ^* e/ K. x{
1 \+ Q( _5 a/ h' ^   RCC->APB2ENR|=RCC_APB2Periph_GPIOD;//
9 M1 {- L! {9 q2 O) P2 K* q   //GPIOD->CRL=0xFFFF00FF;1 V( b; D9 q8 c# Z9 o5 m1 j
   GPIOD->CRL=0x30033300;//配置CRL寄存器----这个模式  通用推挽输出模式  输出模式,最大速度50MHz
# r+ ~& q' f8 {5 s2 Z   while(1)
* O; Q1 t; W& ]! Y6 Z/ P. `. y8 ^   {
5 k; z5 I* B& J       GPIOD->BRR=GPIO_Pin_2;//BRR写1置0-->使ODR(输出低电平,写0无影响)--->使LED亮了# t7 x* Z7 Y' d
           Delay(0xFFFF);. r7 G+ C' P. O! ^
           GPIOD->BRR=GPIO_Pin_3;
# E( j3 J' }; O) f1 O           Delay(0X2FFFF);; @* R  Q5 A- J3 ]" V2 B6 C6 {1 z
           GPIOD->BRR=GPIO_Pin_4;9 I" ^: w5 ^. n4 U
           Delay(0xFFFFF);
# K9 _' R. y. g5 x0 Y6 J           GPIOD->BRR=GPIO_Pin_7;  S- G& L- m! i+ \+ @9 @8 I3 {/ n
           Delay(0X2FFFFF);. I5 ]4 }( z& \- c
           GPIOD->BSRR=GPIO_Pin_2;//BSRR写1置1(前16位是BS,后16位是BR)-->使ODR(输出高电平,写0无影响)--->LED灭了., \# e+ x( R% t/ L# Q) \% {; I
           Delay(0xFFFF);
) E9 i( f9 U" F           GPIOD->BSRR=GPIO_Pin_3;
& }" w$ ]$ X5 |4 s, N5 z           Delay(0X2FFFF);* G4 l# H( `  B6 w
           GPIOD->BSRR=GPIO_Pin_4;5 B: q6 d: X: q/ o8 _- R* z# l
           Delay(0xFFFFF);7 V( k7 h# [1 g
           GPIOD->BSRR=GPIO_Pin_7;5 r% N. i+ E# t9 a5 {; V) [
           Delay(0X2FFFFF);1 F, b% |) |! B7 ^8 U/ X
   }5 S; J2 B/ |  Z9 [" u  x5 B/ H
+ y* f7 T& P, L7 L通过这个程序,我了解到各个与GPIO口有关的寄存器的功能,以及时钟的寄存器的功能。( H" U2 V2 V$ B) S
, ~- _: r3 Z7 j0 l, v
! G5 L$ N* X9 y: p  H
+ E6 ]  K2 n( l8 e8 h! i0 B
0 y1 K. n+ T/ v# \. Z' A8 @. d' E* H
. ?$ J: f% O, B+ T$ Y. n$ W2 e
参与人数 1 ST金币 +10 收起 理由
zero99 + 10
赞 收藏 1 评论13 发布时间:2016-10-27 20:05
13个回答
在路上11111111 回答时间:2016-10-27 20:05:43
不会用代码片,所以辛苦大家看这个了
aoxiangwode2008 回答时间:2016-10-27 20:31:17
好贴,从最基本的寄存器开始写,很不错的。
在路上11111111 回答时间:2016-10-27 20:41:29
谢谢,只是新手
在路上11111111 回答时间:2016-10-27 20:41:45
我还要努力
猫猫侠 回答时间:2016-10-27 20:42:50
谢谢分享  先记号下    等集齐了元件点点看
anywill 回答时间:2016-10-28 07:15:41
鼓励一下,
笑鸟007 回答时间:2016-10-28 07:40:35
不错,写的很详细!!
andypanfan 回答时间:2016-10-28 09:11:01
在路上11111111 回答时间:2016-10-28 10:03:39
我会努力坚持下去的,大家一起加油啊
zero99 回答时间:2016-10-31 09:43:11
在路上11111111 发表于 2016-10-28 10:03
' g* a& U7 ~' l# l' `+ s' T4 p/ e我会努力坚持下去的,大家一起加油啊
$ l% @. L3 j  a$ X0 k
谢谢分享
携手未来 回答时间:2016-10-31 12:57:15
高手,寄程器都知道。
在路上11111111 回答时间:2016-10-31 14:51:04
携手未来 发表于 2016-10-31 12:57
3 X6 U( H% J8 r" }1 i$ @% \高手,寄程器都知道。
# i! t$ o( t8 y$ k' N- ?我也是现学现卖
zbber 回答时间:2016-10-31 19:01:17
纯友情支持 帮顶7 D9 E  [6 `- p! i" ]
