工作中有时候用到需要对PWM波形进行频率和周期的变化,利用DMA Brust时一个比较好的选择,将ST提供的基于F3的例程改到基于F103实现,没什么难度,但是调试的时候最先使用Normal模式导致不宜观察,后改为Circular模式。代码如下: void TIM1_Init(). D2 T6 B) `6 N+ P2 W: g1 F {, s5 r. M0 r/ e8 `) @( \7 q+ |; q GPIO_InitTypeDef GPIO_InitStructure; DMA_InitTypeDef DMA_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; uint16_t SRC_Buffer[9] = {4000-1,1,800,10000-1,0,8500,4000-1,2,2000};: \! |8 W4 L7 o& g5 ^% ]* y /* TIM1 and GPIOA clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA, ENABLE);! _8 a: q+ s; d% w! F* ~ ) n- P! i0 ~% z- Z" {* S7 J5 J" j /* DMA clock enable */3 T0 b/ m% N- ~- }6 k+ z RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); ! d+ T. r V! [& Y& `$ M /* GPIOA Configuration: Channel 1 as alternate function push-pull */ j& U1 \ E% g) r- K GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); & X% s4 d$ L) X8 }$ z- S7 t3 F( _# J # |* I b4 D; C5 ~0 U6 q /* TIM1 DeInit */& N7 }+ E. Y' r% s7 |, _4 w5 _ TIM_DeInit(TIM1);3 [5 x+ ^! z) k$ H G/ C0 T6 h /* DMA1 Channel5 Config */: ?8 g' p0 t6 t7 \" ? DMA_DeInit(DMA1_Channel5);+ C7 D$ v1 i _' i% x: P DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM1_DMAR_ADDRESS; 0 i2 S( J1 ?9 p2 @# h& P4 Q DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SRC_Buffer; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; DMA_InitStructure.DMA_BufferSize = 18;8 v; T% s% ^* D3 z0 F DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;" }6 c3 \# G! y9 V& C$ k DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;# y3 g7 L" B( r1 z5 g DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High;4 @5 \: L _, h' x DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel5, &DMA_InitStructure);4 L3 @- _; h4 H9 X 2 b/ J2 C. F$ A1 ~/ h /* Time base configuration */ /* -----------------------------------------------------------------------5 m. d8 o+ c$ L; S N TIM1 Configuration: generate 1 PWM signal using the DMA burst mode:; h# r/ c( e7 ]/ E7 y. j The TIM1CLK frequency is set to SystemCoreClock (Hz), to get TIM1 counter" r M- ]5 b7 e/ B/ B* q9 O clock at 24 MHz the Prescaler is computed as following: - Prescaler = (TIM1CLK / TIM1 counter clock) - 1 SystemCoreClock is set to 72 MHz for Low-density, Medium-density, High-density and Connectivity line devices and to 24 MHz for Low-Density Value line and Medium-Density Value line devices3 G3 b% x: y+ V 4 p& u( {4 V: S5 g The TIM1 period is 5.8 KHz: TIM1 Frequency = TIM1 counter clock/(ARR + 1) = 24 MHz / 4096 = 5.8KHz KHz TIM1 Channel1 duty cycle = (TIM1_CCR1/ TIM1_ARR)* 100 = 33.33%1 i& T6 l3 X' G; c8 } ----------------------------------------------------------------------- */ 2 L1 M9 P7 X/ |' i" N" y TIM_TimeBaseStructure.TIM_Period = 0xFFFF; TIM_TimeBaseStructure.TIM_Prescaler = (uint16_t) (SystemCoreClock / 24000000) - 1; TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; 5 d- C: I9 R8 P5 O* d ^) t TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); % R, r' @! ?( M7 E6 f /* TIM Configuration in PWM Mode */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 0xFFF; TIM_OC1Init(TIM1, &TIM_OCInitStructure); /* TIM1 DMAR Base register and DMA Burst Length Config */ TIM_DMAConfig(TIM1, TIM_DMABase_ARR, TIM_DMABurstLength_6Transfers);: V& c$ n' J5 P3 | /* TIM1 DMA Update enable */ TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE); /* TIM1 enable */ TIM_Cmd(TIM1, ENABLE);7 u- I0 N- h' T( P# _8 [ " _7 Y" b% n t0 s/ t) Z- O, H8 u$ @ /* TIM1 PWM Outputs Enable */ TIM_CtrlPWMOutputs(TIM1, ENABLE);! h0 W5 Q* k2 j/ l$ ? /* DMA1 Channel5 enable */ DMA_Cmd(DMA1_Channel5, ENABLE); * ]& ^, j8 E& X% c* s0 ^! s$ ? /* Wait until DMA1 Channel5 end of Transfer */ while (!DMA_GetFlagStatus(DMA1_FLAG_TC5))9 R& |, W6 Y# z+ ], w* y8 m {* z9 a4 Y$ w6 r: o, u } } |
| 调试时遇到一个问题,在TIM1-CH1测试通过,但是改成TIM8-CH1的时候却不行,有波形输出但是频率、周期不变,求赐教。 |
| TIM8使用TIM_DMACmd(TIM8, TIM_DMA_CC1, ENABLE);测试OK。 |
| 我现在自己只会产生一个pwm波,还不会精确控制波形个数。我想问一下有没有完整的工程文件,我是初学者,想修改修改能用的。 |
