使用cubemx配置lwip 开启dhcp模式 static void http_server_netconn_thread(void *arg) { struct netconn *conn, *newconn; err_t err, accept_err; /* Create a new TCP connection handle */ conn = netconn_new(NETCONN_TCP); if (conn!= NULL) { /* Bind to port 80 (HTTP) with default IP address */ err = netconn_bind(conn, NULL, 80); if (err == ERR_OK) { /* Put the connection into LISTEN state */ netconn_listen(conn); while(1) { /* accept any icoming connection */ accept_err = netconn_accept(conn, &newconn); if(accept_err == ERR_OK) { /* serve connection */ http_server_serve(newconn); /* delete connection */ netconn_delete(newconn); } } } } }然而进过一次再也没进去 电脑测试设置好tcp客户端和目地地址名为i有用 求大神 |
如果获取IP成功,会进入到这里的。
建议添加打印调试输出信息的代码,方便跟踪。
