本帖最后由 Mr_Hard_Ball 于 2016-12-14 10:25 编辑 调试 LIS3DH这个3轴加速度传感器,用spi读取数据。移植官方的驱动,关键要实现 u8_t LIS3DH_ReadReg(u8_t Reg, u8_t* Data); u8_t LIS3DH_WriteReg(u8_t WriteAddr, u8_t Data); 这两个接口,我的实现如下: u8_t LIS3DH_ReadReg(u8_t Reg, u8_t* Data) { //To be completed with either I2c or SPI reading function //i.e. *Data = SPI_Mems_Read_Reg( Reg ); HAL_StatusTypeDef ret; u8_t read_set; read_set = (Reg | 0x80); /* LOW */ SPI_CS_RESET(); ret = HAL_SPI_Transmit(&hspi1, &read_set, sizeof(u8_t), 1000); if(ret != HAL_OK) { return 0; } ret = HAL_SPI_Transmit(&hspi1, 0, sizeof(u8_t), 100); ret = HAL_SPI_Receive(&hspi1, (u8_t*)Data, sizeof(u8_t), 1000); if(ret != HAL_OK) { return 0; } /* HIGH */ SPI_CS_SET(); HAL_Delay(2); return 1; } 关键在于,传感器多次中断以后,HAL_SPI_Transmit这个函数就挂掉了,一直返回 HAL_busy,具体一看是 hspi->State 这个状态不对, 打印出来发现状态值不属于这个枚举之一,是一个乱七八糟的值,每次还不一样? typedef enum { HAL_SPI_STATE_RESET = 0x00U, /*!< SPI not yet initialized or disabled */ HAL_SPI_STATE_READY = 0x01U, /*!< SPI initialized and ready for use */ HAL_SPI_STATE_BUSY = 0x02U, /*!< SPI process is ongoing */ HAL_SPI_STATE_BUSY_TX = 0x12U, /*!< Data Transmission process is ongoing */ HAL_SPI_STATE_BUSY_RX = 0x22U, /*!< Data Reception process is ongoing */ HAL_SPI_STATE_BUSY_TX_RX = 0x32U, /*!< Data Transmission and Reception process is ongoing */ HAL_SPI_STATE_ERROR = 0x03U /*!< SPI error state */ }HAL_SPI_StateTypeDef; 关键,HAL-busy 以后就再也不会ready了,因此中断再进来,也无法读取成功。。 求大神解答啊 |
