STM32的CAN slave mode与master mode的区别是什么?
奏奏奏 提问时间:2016-12-31 14:30 /
用的芯片是STM32F107
因为它有两个CAN口
做CAN的中继来用
问题是将CAN1口的接收数据用CAN2口发出是正常的
但是反过来将CAN2口的接收数据用CAN1口发出就出问题了
所以就在考虑是否关系到这个问题:CAN1口是master mode,而CAN2口是slave mode,是否CAN2口的接收中断用法与CAN1口的不一样
贴一下代码:
  1. void HAL_CAN_RxCpltCallback(CAN_HandleTypeDef* hcan)
  2. {
  3.         if(hcan == &hcan1)
  4.         {
  5.                 printf("\r\n CAN        receive ID=%x",hcan->pRxMsg->StdId);
  6.                 printf("\r\n CAN        receive length=%d        \r\n CAN        receive data:\r\n",hcan->pRxMsg->DLC);
  7.                 uint8_t j=hcan->pRxMsg->DLC;
  8.                 for(uint8_t i=0;i<j;i++)
  9.                 {
  10.                         printf(" %x        ",hcan->pRxMsg->Data);
  11.                 }
  12.                 printf("\r\n");
  13.
  14.                 //转发到CAN2端口
  15.
  16.         //
  17.                 /*##-1- Configure CAN2 Transmission Massage #####################################*/
  18.                 hcan2.pTxMsg->StdId = hcan->pRxMsg->StdId;
  19.                 hcan2.pTxMsg->RTR = CAN_RTR_DATA;
  20.                 hcan2.pTxMsg->IDE = CAN_ID_STD;
  21.                 hcan2.pTxMsg->DLC = hcan->pRxMsg->DLC;
  22.                 uint8_t j2=hcan->pRxMsg->DLC;
  23.                 for(uint8_t i=0;i<j2;i++)
  24.                 {
  25.                         hcan2.pTxMsg->Data =hcan->pRxMsg->Data;
  26.                 }
  27.                 HAL_CAN_Transmit(&hcan2, 10);
  28.         //
  29.
  30.                 __HAL_CAN_ENABLE_IT(hcan,CAN_IT_FMP0);//重新开启FIF00消息挂号中断
  31.         }
  32.         if(hcan == &hcan2)
  33.         {
  34.                 printf("\r\n CAN        receive ID=%x",hcan->pRxMsg->StdId);
  35.                 printf("\r\n CAN        receive length=%d        \r\n CAN        receive data:\r\n",hcan->pRxMsg->DLC);
  36.                 uint8_t j=hcan->pRxMsg->DLC;
  37.                 for(uint8_t i=0;i<j;i++)
  38.                 {
  39.                         printf(" %x        ",hcan->pRxMsg->Data);
  40.                 }
  41.                 printf("\r\n");
  42.
  43.                 //转发到CAN1端口
  44.
  45.         //
  46.                 /*##-1- Configure CAN2 Transmission Massage #####################################*/
  47.                 hcan1.pTxMsg->StdId = hcan->pRxMsg->StdId;
  48.                 hcan1.pTxMsg->RTR = CAN_RTR_DATA;
  49.                 hcan1.pTxMsg->IDE = CAN_ID_STD;
  50.                 hcan1.pTxMsg->DLC = hcan->pRxMsg->DLC;
  51.                 uint8_t j2=hcan->pRxMsg->DLC;
  52.                 for(uint8_t i=0;i<j2;i++)
  53.                 {
  54.                         hcan1.pTxMsg->Data =hcan->pRxMsg->Data;
  55.                 }
  56.                 HAL_CAN_Transmit_IT(&hcan1);
  57.         //
  58.
  59.                 __HAL_CAN_ENABLE_IT(hcan,CAN_IT_FMP0);//重新开启FIF00消息挂号中断
  60.         }
  61. }
赞 收藏 2 评论12 发布时间:2016-12-31 14:30
12个回答
奏奏奏 回答时间:2017-1-2 22:54:18
找到解决CAN2接收问题的办法了
上面的代码中
将
sFilterConfig.FilterNumber = 0;
修改为:
sFilterConfig.FilterNumber = 14;
就可以解决了。
参与人数 1ST金币 +2 收起 理由
zero99 + 2 结贴奖励
任风吹吹 回答时间:2016-12-31 16:24:02
CAN1口是master mode,而CAN2口是slave mode。。。。
跟这个SLAVEMODE是没有关系的,这个只是说CAN2是没有自己的过滤器,而是共享了CAN1的过滤器组,所以CAN2就叫SLAVE了。
你的问题可以这样排查:
CAN2能接收到数据吗?
CAN2单独能发送数据吗?
参与人数 1ST金币 +2 收起 理由
奏奏奏 回答时间:2017-1-1 01:17:58
跟这个SLAVEMODE是没有关系的,这个只是说CAN2是没有 ...
好的,谢谢!我按这个思路查一遍
damiaa 回答时间:2017-1-1 10:28:20
顶起顶起
5265325 回答时间:2017-1-1 12:09:14
五哥1 回答时间:2017-1-1 14:43:16
二楼回答正确,你需要回答这两个问题
andypanfan 回答时间:2017-1-1 15:13:48
奏奏奏 回答时间:2017-1-2 20:07:41
排查过了。
CAN2不能接收到数据!问题在这里
CAN2单独发送数据正常。
附上main.c的代码:
  1. /**
  2.   ******************************************************************************
  3.   * File Name          : main.c
  4.   * Description        : Main program body
  5.   ******************************************************************************
  6.   *
  7.   * COPYRIGHT(c) 2016 STMicroelectronics
  8.   *
  9.   * Redistribution and use in source and binary forms, with or without modification,
  10.   * are permitted provided that the following conditions are met:
  11.   *   1. Redistributions of source code must retain the above copyright notice,
  12.   *      this list of conditions and the following disclaimer.
  13.   *   2. Redistributions in binary form must reproduce the above copyright notice,
  14.   *      this list of conditions and the following disclaimer in the documentation
  15.   *      and/or other materials provided with the distribution.
  16.   *   3. Neither the name of STMicroelectronics nor the names of its contributors
  17.   *      may be used to endorse or promote products derived from this software
  18.   *      without specific prior written permission.
  19.   *
  20.   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  21.   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  22.   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  23.   * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  24.   * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  25.   * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  26.   * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  27.   * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  28.   * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  29.   * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  30.   *
  31.   ******************************************************************************
  32.   */
  33. /* Includes ------------------------------------------------------------------*/
  34. #include "stm32f1xx_hal.h"
  35. #include "can.h"
  36. #include "usart.h"
  37. #include "gpio.h"
  38. /* USER CODE BEGIN Includes */
  39. /* USER CODE END Includes */
  40. /* Private variables ---------------------------------------------------------*/
  41. /* USER CODE BEGIN PV */
  42. /* Private variables ---------------------------------------------------------*/
  43. CAN_FilterConfTypeDef  sFilterConfig;
  44. static CanTxMsgTypeDef        TxMessage;
  45. static CanRxMsgTypeDef        RxMessage;
  46. /* USER CODE END PV */
  47. /* Private function prototypes -----------------------------------------------*/
  48. void SystemClock_Config(void);
  49. void Error_Handler(void);
  50. /* USER CODE BEGIN PFP */
  51. /* Private function prototypes -----------------------------------------------*/
  52. /* USER CODE END PFP */
  53. /* USER CODE BEGIN 0 */
  54. /* USER CODE END 0 */
  55. int main(void)
  56. {
  57.   /* USER CODE BEGIN 1 */
  58.   /* USER CODE END 1 */
  59.   /* MCU Configuration----------------------------------------------------------*/
  60.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  61.   HAL_Init();
  62.   /* Configure the system clock */
  63.   SystemClock_Config();
  64.   /* Initialize all configured peripherals */
  65.   MX_GPIO_Init();
  66.   MX_CAN1_Init();
  67.   MX_CAN2_Init();
  68.   MX_USART1_UART_Init();
  69.   /* USER CODE BEGIN 2 */
  70.   printf("\n\r UART Printf Example: retarget the C library printf function to the UART\n\r");
  71.
  72. //  hcan1.pTxMsg = &TxMessage;
  73.   hcan2.pRxMsg = &RxMessage;
  74.         __HAL_CAN_ENABLE_IT(&hcan2,CAN_IT_FMP1);//重新开启FIF00消息挂号中断
  75. //        __HAL_CAN_ENABLE_IT(&hcan2,CAN_IT_FMP0);//重新开启FIF00消息挂号中断
  76.   printf("**** This is CAN test program ****\r\n\r\n");
  77.   /*##-1- Configure CAN2 Transmission Massage #####################################*/
  78. //  hcan2.pTxMsg->StdId = 0x123;
  79. //  hcan2.pTxMsg->RTR = CAN_RTR_DATA;
  80. //  hcan2.pTxMsg->IDE = CAN_ID_STD;
  81. //  hcan2.pTxMsg->DLC = 8;
  82. //  hcan2.pTxMsg->Data[0] = 'C';
  83. //  hcan2.pTxMsg->Data[1] = 'A';
  84. //  hcan2.pTxMsg->Data[2] = 'N';
  85. //  hcan2.pTxMsg->Data[3] = ' ';
  86. //  hcan2.pTxMsg->Data[4] = 'T';
  87. //  hcan2.pTxMsg->Data[5] = 'e';
  88. //  hcan2.pTxMsg->Data[6] = 's';
  89. //  hcan2.pTxMsg->Data[7] = 't';
  90.   /*##-2- Configure the CAN1 Filter ###########################################*/
  91.   sFilterConfig.FilterNumber = 0;
  92.   sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK;
  93.   sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT;
  94.   sFilterConfig.FilterIdHigh = 0x0000;
  95.   sFilterConfig.FilterIdLow = 0x0000;
  96.   sFilterConfig.FilterMaskIdHigh = 0x0000;
  97.   sFilterConfig.FilterMaskIdLow = 0x0000;
  98.   sFilterConfig.FilterFIFOAssignment = 1;
  99.   sFilterConfig.FilterActivation = ENABLE;
  100.   sFilterConfig.BankNumber = 14;
  101.   HAL_CAN_ConfigFilter(&hcan1, &sFilterConfig);
  102.   /* USER CODE END 2 */
  103.   /* Infinite loop */
  104.   /* USER CODE BEGIN WHILE */
  105.   while (1)
  106.   {
  107.   /* USER CODE END WHILE */
  108.   /* USER CODE BEGIN 3 */
  109. //      printf("\n\r welcome to www.waveshere.com !!!\n\r");
  110.       HAL_Delay(1000);
  111.       /*##-3- Start the CAN2 Transmission process #####################################*/
  112. //      if(HAL_CAN_Transmit(&hcan2, 10) != HAL_OK)
  113. //      {
  114. //          /* Transmition Error */
  115. //          Error_Handler();
  116. //      }
  117. //                        HAL_CAN_Transmit(&hcan2, 10);
  118. //
  119. //      if(HAL_CAN_GetState(&hcan2) != HAL_CAN_STATE_READY)
  120. //      {
  121. //          Error_Handler();
  122. //
  123. //      }
  124.       /*##-4- Start the CAN1 Reception process ########################################*/
  125. //      if(HAL_CAN_Receive(&hcan1, CAN_FIFO0,10) != HAL_OK)
  126. //      {
  127. //          /* Reception Error */
  128. //          Error_Handler();
  129. //      }
  130. //                        HAL_CAN_Receive(&hcan1, CAN_FIFO0,10);
  131.
  132. //      if(HAL_CAN_GetState(&hcan1) != HAL_CAN_STATE_READY)
  133. //      {
  134. //          Error_Handler();
  135. //      }
  136. //      printf("StdId : %x\r\n",hcan1.pRxMsg->StdId);
  137. //      printf("RxMsg : %s",hcan1.pRxMsg->Data);
  138. //      printf("\r\n\r\n");
  139.
  140. //      HAL_Delay(1000);
  141.   }
  142.   /* USER CODE END 3 */
  143. }
  144. /** System Clock Configuration
  145. */
  146. void SystemClock_Config(void)
  147. {
  148.   RCC_OscInitTypeDef RCC_OscInitStruct;
  149.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  150.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  151.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  152.   RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV5;
  153.   RCC_OscInitStruct.Prediv1Source = RCC_PREDIV1_SOURCE_PLL2;
  154.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  155.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  156.   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  157.   RCC_OscInitStruct.PLL2.PLL2State = RCC_PLL2_ON;
  158.   RCC_OscInitStruct.PLL2.PLL2MUL = RCC_PLL2_MUL8;
  159.   RCC_OscInitStruct.PLL2.HSEPrediv2Value = RCC_HSE_PREDIV2_DIV5;
  160.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  161.   {
  162.     Error_Handler();
  163.   }
  164.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  165.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  166.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  167.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  168.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  169.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  170.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  171.   {
  172.     Error_Handler();
  173.   }
  174.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  175.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  176.   __HAL_RCC_PLLI2S_ENABLE();
  177.   /* SysTick_IRQn interrupt configuration */
  178.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  179. }
  180. /* USER CODE BEGIN 4 */
  181. void HAL_CAN_RxCpltCallback(CAN_HandleTypeDef* hcan)
  182. {
  183.         printf("\r\n CAN        receive ID=%x",hcan->pRxMsg->StdId);
  184.         printf("\r\n CAN        receive length=%d        \r\n CAN        receive data:\r\n",hcan->pRxMsg->DLC);
  185.         uint8_t j=hcan->pRxMsg->DLC;
  186.         for(uint8_t i=0;i<j;i++)
  187.         {
  188.                 printf(" %x        ",hcan->pRxMsg->Data[i]);
  189.         }
  190.         printf("\r\n");
  191.
  192.         //转发到CAN2端口
  193.
  194. //
  195.   /*##-1- Configure CAN2 Transmission Massage #####################################*/
  196. //  hcan1.pTxMsg->StdId = hcan->pRxMsg->StdId;
  197. //  hcan1.pTxMsg->RTR = CAN_RTR_DATA;
  198. //  hcan1.pTxMsg->IDE = CAN_ID_STD;
  199. //  hcan1.pTxMsg->DLC = hcan->pRxMsg->DLC;
  200. ////  hcan2.pTxMsg->Data[0] = 'C';
  201. ////  hcan2.pTxMsg->Data[1] = 'A';
  202. ////  hcan2.pTxMsg->Data[2] = 'N';
  203. ////  hcan2.pTxMsg->Data[3] = ' ';
  204. ////  hcan2.pTxMsg->Data[4] = 'T';
  205. ////  hcan2.pTxMsg->Data[5] = 'e';
  206. ////  hcan2.pTxMsg->Data[6] = 's';
  207. ////  hcan2.pTxMsg->Data[7] = 't';
  208. //        uint8_t j2=hcan->pRxMsg->DLC;
  209. //        for(uint8_t i=0;i<j2;i++)
  210. //        {
  211. ////                printf(" %x        ",hcan->pRxMsg->Data[i]);
  212. //                hcan1.pTxMsg->Data[i] =hcan->pRxMsg->Data[i];
  213. //        }
  214. ////        printf("\r\n");
  215. //        HAL_CAN_Transmit(&hcan1, 10);
  216. //
  217.
  218. //        __HAL_CAN_ENABLE_IT(hcan,CAN_IT_FMP0);//重新开启FIF00消息挂号中断
  219.         __HAL_CAN_ENABLE_IT(hcan,CAN_IT_FMP1);//重新开启FIF00消息挂号中断
  220. }
  221. /* USER CODE END 4 */
  222. /**
  223.   * @brief  This function is executed in case of error occurrence.
  224.   * @param  None
  225.   * @retval None
  226.   */
  227. void Error_Handler(void)
  228. {
  229.   /* USER CODE BEGIN Error_Handler */
  230.   /* User can add his own implementation to report the HAL error return state */
  231.   while(1)
  232.   {
  233.   }
  234.   /* USER CODE END Error_Handler */
  235. }
  236. #ifdef USE_FULL_ASSERT
  237. /**
  238.    * @brief Reports the name of the source file and the source line number
  239.    * where the assert_param error has occurred.
  240.    * @param file: pointer to the source file name
  241.    * @param line: assert_param error line source number
  242.    * @retval None
  243.    */
  244. void assert_failed(uint8_t* file, uint32_t line)
  245. {
  246.   /* USER CODE BEGIN 6 */
  247.   /* User can add his own implementation to report the file name and line number,
  248.     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  249.   /* USER CODE END 6 */
  250. }
  251. #endif
  252. /**
  253.   * @}
  254.   */
  255. /**
  256.   * @}
  257. */
  258. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
小小超 回答时间:2017-1-3 08:40:33
学习一下!!!!
jcx0324 回答时间:2017-1-3 09:11:19
其实是一样的,只是硬件资源上的区别
参与人数 1ST金币 +2 收起 理由
Ian-392967 回答时间:2017-3-11 19:16:29
大哥猜对了!更您学的在网上分享一下资料。
zbber 回答时间:2017-3-11 23:16:53
