stm32 f3 外拓AD5313R 应该如何配置和发数据
中滑好栗子 提问时间:2017-1-4 11:35 /
这是我写的代码:
SPI3_DAC :static void SPI3_Config(void)
        SPI_InitTypeDef  SPI_InitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_6);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource12, GPIO_AF_6);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;                                        //СDA_SYNC
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;                                        //SPI3_SCK
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        /* Configure SPI3 pins:  MISO and MOSI ---------------------------------*/
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11;                                        //SPI3_MISO
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_12;                                        //SPI3_MOSI
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI3, &SPI_InitStructure);
        SPI_CalculateCRC(SPI3, ENABLE);
        SPI_Cmd(SPI3, ENABLE);
        SPI_I2S_ITConfig(SPI3, SPI_I2S_IT_TXE, ENABLE);
        SPI_SendData8(SPI3, 0X00);
利用中断发送数据:
u8 TxBuffer[3] = {0x21,0xff,0x30};
void SPI3_IRQHandler(void)
        static uint32_t Tx_Idx = 0;
  GPIO_ResetBits(GPIOA, GPIO_Pin_15);
        GPIO_SetBits(GPIOC, GPIO_Pin_10);
  if (SPI_I2S_GetITStatus(SPI3, SPI_I2S_IT_TXE) == SET)
    SPI_SendData8(SPI3, TxBuffer[Tx_Idx++]);
      if (Tx_Idx ==2)
        SPI_I2S_ITConfig(SPI3, SPI_I2S_IT_TXE, DISABLE);
                                Tx_Idx = 0;
                                GPIO_SetBits(GPIOA, GPIO_Pin_15);
                                GPIO_ResetBits(GPIOC, GPIO_Pin_10);
求助 是为什么DAC_OUT无法输出电压。
赞 收藏 1 评论7 发布时间:2017-1-4 11:35
7个回答
中滑好栗子 回答时间:2017-1-4 11:36:59
各位大神 帮帮忙啦
any012 回答时间:2017-1-4 12:51:49
可以试试非中断方式。
AD的片子,很多都有官方的实例代码。对照着把通讯部分补上去就可以了。
参与人数 1ST金币 +2 收起 理由
lili0000 回答时间:2017-1-4 13:32:47
官方的可以参考下
中滑好栗子 回答时间:2017-1-4 13:44:04
any012 发表于 2017-1-4 12:51
可以试试非中断方式。
AD的片子,很多都有官方的实例代码。对照着把通讯部分补上去就可以了。 ...
我找过AD5313R的基本上都是用户手册 那么 请教官网应该是用什么搜(我也用过datasheets)
中滑好栗子 回答时间:2017-1-4 13:45:09
lili0000 发表于 2017-1-4 13:32
官方的可以参考下
嗯 请教下 应该搜索什么 我搜索过AD5313R 但是都是用户手册 没有显示官网之类的东西
any012 回答时间:2017-1-4 14:17:54
中滑好栗子 发表于 2017-1-4 13:44
我找过AD5313R的基本上都是用户手册 那么 请教官网应该是用什么搜(我也用过datasheets) ...
抱歉,我有点想当然了。
搜了下ADI官网,ADR5313R官网上找不到编程参考。
建议用示波器看下SPI相关引脚波形。
中滑好栗子 回答时间:2017-1-4 14:35:33
any012 发表于 2017-1-4 14:17
抱歉,我有点想当然了。
嗯  好的 谢谢
