- #include "stm32f10x.h"
3 R( `4 v- [4 _8 O# K f - void STM32_TIM_GPIO_Configuration(void)
% x& f; a% b4 M) r - {
# G5 Q. V4 u) T a- v - GPIO_InitTypeDef GPIO_InitStructure;! v J/ e- K) u0 @! Y. s
- 0 f1 Y( k" x R( e
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE);
0 u- @3 `" I$ J! B8 e
) Z7 D# d J2 C+ U% w+ i- <img src="https://www.stmcu.org.cn/module/forum/forum.php?mod=image&aid=390763&size=300x300&key=ccf1e09fa4605482&nocache=yes&type=fixnone" aid="attachimg_390763" alt="" border="0">2 J' y1 c5 @3 q4 F7 a2 O% w, U2 u3 M
- <img src="https://www.stmcu.org.cn/module/forum/forum.php?mod=image&aid=390764&size=300x300&key=c2083d0c105d5af9&nocache=yes&type=fixnone" aid="attachimg_390764" alt="" border="0">
8 \- L+ [( a9 r0 M# y# x - //这里TIM3的通道1是GPIOA_Pin_6,通道2是GPIOA_Pin_7;通道3是GPIOB_Pin_0;" a1 k' |5 p) M6 n0 Q
- //这里TIM3的通道4是GPIOB_Pin_1;- O% Z# n, b2 [' q
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;, C& g2 b5 q; O0 }; ?3 \
- //使用PWM的功能需要设置成AF_PP模式
# j+ G! h" v4 O* p - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; s# d( w* v9 E! t3 ?) P5 X8 W1 S
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;2 k7 Z* w9 _0 k+ V N
- GPIO_Init(GPIOA,&GPIO_InitStructure);
1 a) V( N, S: s8 b0 l3 }# l -
/ T. u/ N1 w; Z+ m% u; X1 ~( T - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;! A- ^! g/ w! h ^/ _
- GPIO_Init(GPIOB,&GPIO_InitStructure);+ A$ C% ]1 s; _
. G! D# ^, C7 K, D" G2 a% Q( j - void NVIC_TIM3Configuration(void)//配置TIM3的优先级0 u6 K& J* B8 i. a+ K* n
- {! X$ J. S: ]- v3 O# a' K
- NVIC_InitTypeDef NVIC_InitStructure;
0 W) ] s5 u' l$ r- Y& \. J - 9 p2 [* u! t8 s( S; q: q6 O6 [
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);1 _6 u+ y1 c/ R" c( V6 e# f" B
- 3 O, U$ X/ X. R8 D
- NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
2 ?% T# V' {; R( C* [6 c: h2 a1 X - NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
b7 |, S6 S" C& G$ _ - NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;! |0 x. l3 o$ N
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;1 Z7 S. [3 {& d* ]% G
) A' O% {; `, h/ U - NVIC_Init(&NVIC_InitStructure);
) l: T1 p/ W. Z3 W# V - }
- C+ H A- Y: q7 Z- v, M7 h! t - 9 j6 R6 Y8 @3 C/ A/ Y- w
- & F$ E$ \1 p) D# N' V
- TIM3_PWM_Init(void), V6 h! Y( j/ \6 M& \) y: l3 e
- {2 ^) }; V0 O7 |8 A
- TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;//TIM定时器的配置
, p: \% z0 N0 D/ f - TIM_OCInitTypeDef TIM_OCInitStructure;//TIMPWM的 N$ K- H) p# P, w) _( o( f8 H
- . F1 V# V0 s( i/ D
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
" C! p% l, |- m2 A+ l+ E8 Z/ S! c - <img src="https://www.stmcu.org.cn/module/forum/forum.php?mod=image&aid=390765&size=300x300&key=561e9645b6d91c33&nocache=yes&type=fixnone" aid="attachimg_390765" alt="" border="0">; A, U- s$ k i: n: F4 k4 u
- //使能TIM3的时钟线;
7 L% G& {( Q6 j9 `" A# B -
, `6 ?! V3 M: d' _1 N7 } - <img src="https://www.stmcu.org.cn/module/forum/forum.php?mod=image&aid=390766&size=300x300&key=ab4502d35588f011&nocache=yes&type=fixnone" aid="attachimg_390766" alt="" border="0">0 e' X# q7 ?/ ^4 H7 |
- TIM_TimeBaseInitStructure.TIM_Prescaler = 100-1;2 W9 d0 C- D# J% \0 F1 ~
- //分频;意思就是将72MHz的频率分成多少;这里是分成72M/100 = 720KHz了;& [3 g% s3 a4 f6 E) ]
- TIM_TimeBaseInitStructure.TIM_Period = 720-1;- C+ O, ]; t8 k3 X1 R
- //这个是定时器需要计数的最大位置;就是从0计数到Period;
# I' t2 b+ l% u( M9 d - //这里的预分频系数(Presecaler)和预装值(Period)的乘积 表示频率;0 b* \ J. o% m$ a$ [" K6 m
- TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
& {" m* E9 E1 z5 l" i1 f0 K - //这个是定时器计数的模式,可以向下计数,也可以向上计数;% D4 X1 Y6 }6 {, Y; `# y
- TIM_TimeBaseInitStructure.TIM_ClockDivision = 0;* w* n1 M9 K- s( Z; g5 U
- //这个是预分频系数,一般不去操作它;9 |' p& B2 ?# Q4 O# J$ A
- TIM_TimeBaseInit(TIM3,&TIM_TimeBaseInitStructure);
+ u) C6 X4 s b1 o - //初始化TIM3
! d b( f& @9 s# m- q - TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
3 ~4 p* z0 X( p) h: ` - //这个是定时器的模式;在这里使用的是PWM功能;5 ]0 N* m% y' s7 e6 V+ g
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
1 |0 y, D4 P4 o& W - //这个是比较输出使能;意思就是到底输不输出到相应的引脚;- K z) I+ B& z9 ~/ k
- TIM_OCInitStructure.TIM_Pulse = 600;9 t6 z0 u& k( U
- //这个是比较捕获的脉冲数就是在一个周期中捕获多少个1(0);这里Pulse/Period就代表的是占空比;) R, S' q( T2 V8 t9 O0 X1 c) x
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
8 Y( w1 d0 U8 \4 K - //这个是输出极性:这里选择的是输出极性高,当然你也可以设置Low;3 a5 d" T0 g8 K) X( {
- TIM_OC1Init(TIM3,&TIM_OCInitStructure);
$ ^! Y7 Y0 c3 J& w) B - //初始化通道1;9 g7 m% R7 x5 d' u
- TIM_OC2Init(TIM3,&TIM_OCInitStructure);
/ ]3 c/ {8 p" [! i* Q - //初始化通道2;* O% O, C- k; ]& w8 R
- TIM_OC3Init(TIM3,&TIM_OCInitStructure);7 q; `5 L$ F+ M- S; H
- //初始化通道3;
; O8 i* I1 {! ~9 g - TIM_OC4Init(TIM3,&TIM_OCInitStructure);0 F# O9 O: O# z: i& \6 L( A
- //初始化通道4;
; J! ~1 I: P5 t3 m - TIM_OC1PreloadConfig(TIM3,TIM_OCPreload_Enable);6 `! H, s7 @8 M: }
- //使能或者失能 TIMx 在 CCR2 上的预装载寄存器6 ^* ]% T n/ K9 Q5 U
- TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable);
6 O& H, t4 b; \4 | - //使能或者失能 TIMx 在 CCR2 上的预装载寄存器2 y- n0 C/ C! l3 l9 ^/ t m
- TIM_OC3PreloadConfig(TIM3,TIM_OCPreload_Enable);: v& [0 j' ]4 s4 S* `( h6 N
- c; A: D, c6 G: G - TIM_OC4PreloadConfig(TIM3,TIM_OCPreload_Enable);6 k9 y# `( `! t U3 N2 J
+ s4 [* V- N& D5 ~$ Q* q -
3 z6 h: z& T f3 D& \; ] - //TIM_ITConfig(TIM3,TIM_IT_CC1|TIM_IT_CC2|TIM_IT_CC3|TIM_IT_CC4,ENABLE);
9 Q5 Y, Z" T) k3 D3 s) j7 _/ _0 _ - //使能标志位CC1,CC2,CC3,CC4
+ h9 t, b1 S2 E. F - TIM_Cmd(TIM3,ENABLE);( ?% } {4 Z* A* l" c+ H2 T9 z
- //使能TIM;! e* @2 `' |8 d
- 0 K# V/ W5 r$ Z8 e/ G. I$ D
- * K' M2 ?/ y$ N
: Q; c3 K* W( b - }
9 T9 ~9 k9 C0 Q0 J% e5 @* R - // void TIM3_IRQHandler(void)
8 ^7 a3 C! v) ~ - // {* d5 A; D A" _3 e. W: Y9 ? O
- // TIM_ClearITPendingBit(TIM3,TIM_IT_CC1|TIM_IT_CC2|TIM_IT_CC3|TIM_IT_CC4);
: l( D- }0 o* j" k - // Flag = 1; G8 S0 f! ?2 }7 A0 S2 T
f! A% P/ z! h: ?* i- C
J# z" C' o) @* a2 ^: W6 ~- void Delay(uint32_t nCount)1 ]8 I6 K, n. b; M" U/ \7 u2 G
- {6 r& b9 z( E$ |
- while(--nCount);" j- u( K9 G4 I7 l$ [( l0 _
2 @2 {* S: [/ n$ n' U" X, m - , b0 m1 v. K" x' s: [* D* n- m3 ^' F
- int main(); o% r( n: |* D, y
- { & f0 `6 K, u6 ~, G t
- uint16_t i=0;4 S3 K' ` G( T- K: v3 s
- STM32_TIM_GPIO_Configuration();
+ F9 V2 c/ g) ?$ ?( G8 A - NVIC_TIM3Configuration();
- r' `/ D# u7 I) k l0 r - TIM3_PWM_Init();
9 }6 _& h% B8 R) ` M7 R - while(1)
3 x+ k" V% a- m2 d+ D - {
3 h# t( Z' N t/ S/ G. B - TIM3->CCR2 = 500;
' X# u- V. ^8 N, W - for(i=0;i<499;i++) \8 B* _ S# q# V1 @& q
1 y7 ^( Y5 r/ P4 I- {4 R& C6 W2 v - Delay(0XFFFFF);
2 h& `0 G8 O: M2 Y) ` - TIM3->CCR2-=1;
6 D' C9 x: {4 W4 I - }6 i3 n# x: C6 ]0 `' q! O
- for(i=0;i<499;i++)) R; r: l) y) D, U. B' a
- {, a. o) m0 f; W( c6 ^+ y+ d: ~
- Delay(0XFFFFF);
" n7 o3 q( C$ J7 p6 X; _ - TIM3->CCR2+=1;
7 n' B% ?/ A4 r5 U2 N$ A - }
_1 c1 i7 i; D - }
+ a& r; X1 C! Y) q - }终于调出PWM了,在这里不敢独享,分享给那些还在调试PWM的人;
复制代码 ! V% K: s- B3 T
