在首次进入HALT,测试功耗是0.82ua,awu唤醒后再次进入HALT,...
ljfljfljf123 提问时间:2017-3-16 17:24 /
STM8L101在首次进入HALT,测试功耗是0.82ua,awu唤醒后再次进入HALT,测试功耗是1.35ma,这是什么情况?
void GPIO_LowPower_Config(void)
  GPIO_Init(GPIOA, GPIO_Pin_All, GPIO_Mode_Out_PP_High_Slow);
  GPIO_Init(GPIOB, GPIO_Pin_All, GPIO_Mode_Out_PP_High_Slow);
  GPIO_Init(GPIOC, GPIO_Pin_All, GPIO_Mode_Out_PP_High_Slow);
  GPIO_Init(GPIOD, GPIO_Pin_All, GPIO_Mode_Out_PP_High_Slow);
void Enter_Halt(void)
  AWU_DeInit();
  AWU_Cmd(ENABLE);
  AWU_Init(AWU_Timebase_30s);
  GPIO_LowPower_Config();
  asm("halt");
void main(void)
  asm("sim");            //关中断
  CLK_DeInit();
  CLK_MasterPrescalerConfig(CLK_MasterPrescaler_HSIDiv2);     //时钟8分频,2MHz
  CLK_PeripheralClockConfig(CLK_Peripheral_AWU, ENABLE);
  enableInterrupts();/* 开所有中断 */
  Enter_Halt();
  while (1)
    delay_ms(1);
    Enter_Halt();
INTERRUPT_HANDLER(AWU_IRQHandler,4)
    /* In order to detect unexpected events during development,
       it is recommended to set a breakpoint on the following instruction.
     AWU->CSR = AWU->CSR;
赞 收藏 2 评论3 发布时间:2017-3-16 17:24
3个回答
ljfljfljf123 回答时间:2017-3-16 17:24:32
感觉好象没有第二次没有进入HALT
无薪税绵 回答时间:2017-4-9 22:30:57
awu唤醒的标志未清零吧。
参与人数 1ST金币 +2 收起 理由
大陶 回答时间:2019-2-15 09:54:27
中断函数
#pragma vector= AWU_vector//0x03
__interrupt void AWU_IRQHandler(void)
  AWU_CSR1=AWU_CSR1;
