ADC1+DMA 加入初始化函数后程序就死了,跑到HardFault_Handler这...
andypanfan 提问时间:2017-4-20 08:35 /
#define ADC1_DR_ADDRESS    ((uint32_t)0x4001204C)
__IO uint16_t ADC1ConvertedValue[5][4]={0};
void  Adc_Init(void)
    ADC_InitTypeDef       ADC_InitStructure;
    ADC_CommonInitTypeDef ADC_CommonInitStructure;
    DMA_InitTypeDef       DMA_InitStructure;
    GPIO_InitTypeDef      GPIO_InitStructure;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA| RCC_AHB1Periph_GPIOC, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    DMA_InitStructure.DMA_Channel = DMA_Channel_0;
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS;
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)ADC1ConvertedValue;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
    DMA_InitStructure.DMA_BufferSize = 25;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
    DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
    DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
    DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
    DMA_Init(DMA2_Stream0, &DMA_InitStructure);
    DMA_Cmd(DMA2_Stream0, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5| GPIO_Pin_6| GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
    ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
    ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles;
    ADC_CommonInit(&ADC_CommonInitStructure);
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfConversion = 4;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 1, ADC_SampleTime_84Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 2, ADC_SampleTime_84Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 3, ADC_SampleTime_84Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 4, ADC_SampleTime_84Cycles);
    ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
    ADC_DMACmd(ADC1, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
        ADC_SoftwareStartConv(ADC1);
使用ADC1  DMA2  检测PA5  PA6  PA7  PC4  脚上的电压,但是不知道怎么的,程序加了这个初始化函数后就跑到HardFault_Handler这个函数这里来了,不知道论坛里有做过的大神没有,求指导一下,谢谢!!!!!!
赞 收藏 1 评论5 发布时间:2017-4-20 08:35
5个回答
andypanfan 回答时间:2017-4-20 22:18:26
安 发表于 2017-4-20 11:08
修改后,是否还会出现这个错误。
没有了  谢谢!!
参与人数 1ST金币 +2 收起 理由
zero99 + 2 结贴奖励
废鱼 回答时间:2017-4-20 09:34:48
从代码看应该是空间溢出了。楼主定义的是__IO uint16_t ADC1ConvertedValue[5][4]={0};实际使用时用的是25。把 DMA_InitStructure.DMA_BufferSize = 25;改成20试试。
jtc_88 回答时间:2017-4-20 10:10:05
安 发表于 2017-4-20 09:34
从代码看应该是空间溢出了。楼主定义的是__IO uint16_t ADC1ConvertedValue[5][4]={0};实际使用时用的是25 ...
我看也是 数组是 5 * 4  ,DMA配置确是 25;估计是错误的根源
废鱼 回答时间:2017-4-20 11:08:25
修改后,是否还会出现这个错误。
andypanfan 回答时间:2017-4-20 22:18:50
是这里错了   谢谢你!!
