| 主界面上有icon,点击icon后建立一个frame,然后这个frame上有两个控件,一个 ok button和一个multipage,multipage中有三个页面,问题是如何关闭frame回到主界面? 原本想按ok button关闭frame回到主界面?但在vs仿真执行就出现dereference free block in GUI_ALLC_h2p()错误,求解? 贴出回调函数代码,大家帮忙看看,谢谢: 这个是multipage的第一个页面的回调函数,这个页面就是一个button,想按这个button销毁frame回到主界面上,但是不行 static void _cbDialog_Page1(WM_MESSAGE * pMsg) { WM_HWIN hItem; WM_HWIN hItem2; int NCode; int Id; WM_MESSAGE msg; // USER START (Optionally insert additional variables) // USER END switch (pMsg->MsgId) { case WM_INIT_DIALOG: hItem = WM_GetDialogItem(pMsg->hWin, GUI_ID_BUTTON0); BUTTON_SetSkin(hItem, _DrawSkin_Button); // USER START (Optionally insert additional code for further widget initialization) // USER END break; case WM_NOTIFY_PARENT: Id = WM_GetId(pMsg->hWinSrc); NCode = pMsg->Data.v; switch(Id) { case GUI_ID_BUTTON0: // Notifications sent by 'Checkbox' switch(pMsg->Data.v) { case WM_NOTIFICATION_CLICKED: // USER START (Optionally insert code for reacting on notification message) // USER END break; case WM_NOTIFICATION_RELEASED: // USER START (Optionally insert code for reacting on notification message) // USER END #if 0 hItem = WM_GetParent(pMsg->hWin); hItem2 = WM_GetParent(hItem ); hItem = MULTIPAGE_GetWindow(hItem2,0); WM_DeleteWindow(hItem); hItem = MULTIPAGE_GetWindow(hItem2,1); WM_DeleteWindow(hItem); hItem = MULTIPAGE_GetWindow(hItem2,2); WM_DeleteWindow(hItem); GUI_EndDialog(hItem2, 0); #endif hItem = (WM_GetParent(WM_GetParent(pMsg->hWin))); hItem2 = WM_GetParent(hItem ); WM_DeleteWindow(hItem); //GUI_EndDialog(hItem2, 0); msg.MsgId = WM_DELETE; WM_SendMessage(hItem2,&msg); break; case WM_NOTIFICATION_VALUE_CHANGED: // USER START (Optionally insert code for reacting on notification message) // USER END break; // USER START (Optionally insert additional code for further notification handling) // USER END } break; // USER START (Optionally insert additional code for further Ids) // USER END } break; // USER START (Optionally insert additional message handling) // USER END default: WM_DefaultProc(pMsg); break; } } 这个是frame的回调函数,frame中有个button,想按这个button销毁frame回到主界面也是不行。求解啊 static void _cbDialog(WM_MESSAGE * pMsg) { WM_HWIN hItem; WM_HWIN hItem2; WM_HWIN hDialog; WM_MESSAGE msg; int NCode; int Id; // USER START (Optionally insert additional variables) // USER END switch (pMsg->MsgId) { case WM_INIT_DIALOG: // // Initialization of 'Multipage' // hItem = WM_GetDialogItem(pMsg->hWin, ID_MULTIPAGE_0); hDialog = GUI_CreateDialogBox(_aDialogCreate1, GUI_COUNTOF(_aDialogCreate1), _cbDialog_Page1, WM_UNATTACHED, 0, 0); //WM_SetCallback(hDialog, _cbDialog_Page1); MULTIPAGE_AddPage(hItem, hDialog, "setup1"); GUI_Delay(500); hDialog = GUI_CreateDialogBox(_aDialogCreate2, GUI_COUNTOF(_aDialogCreate2), NULL, WM_UNATTACHED, 0, 0); MULTIPAGE_AddPage(hItem, hDialog, "setup2"); GUI_Delay(500); hDialog = GUI_CreateDialogBox(_aDialogCreate3, GUI_COUNTOF(_aDialogCreate3), NULL, WM_UNATTACHED, 0, 0); MULTIPAGE_AddPage(hItem, hDialog, "about"); GUI_Delay(500); // // Initialization of 'OK' // hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_0); BUTTON_SetFont(hItem, GUI_FONT_16_ASCII); // USER START (Optionally insert additional code for further widget initialization) // USER END break; case WM_NOTIFY_PARENT: Id = WM_GetId(pMsg->hWinSrc); NCode = pMsg->Data.v; switch(Id) { case ID_MULTIPAGE_0: // Notifications sent by 'Multipage' switch(NCode) { case WM_NOTIFICATION_CLICKED: // USER START (Optionally insert code for reacting on notification message) // USER END break; case WM_NOTIFICATION_RELEASED: // USER START (Optionally insert code for reacting on notification message) // USER END break; case WM_NOTIFICATION_MOVED_OUT: // USER START (Optionally insert code for reacting on notification message) // USER END break; case WM_NOTIFICATION_VALUE_CHANGED: // USER START (Optionally insert code for reacting on notification message) // USER END break; // USER START (Optionally insert additional code for further notification handling) // USER END } break; case ID_BUTTON_0: // Notifications sent by 'OK' switch(NCode) { case WM_NOTIFICATION_CLICKED: // USER START (Optionally insert code for reacting on notification message) // USER END break; case WM_NOTIFICATION_RELEASED: // USER START (Optionally insert code for reacting on notification message) // USER END //hItem2 = WM_GetDialogItem(pMsg->hWin, ID_MULTIPAGE_0); //hItem = MULTIPAGE_GetWindow(hItem2,0); //WM_DeleteWindow(hItem); //hItem = MULTIPAGE_GetWindow(hItem2,1); //WM_DeleteWindow(hItem); //hItem = MULTIPAGE_GetWindow(hItem2,2); //WM_DeleteWindow(hItem); hItem = WM_GetDialogItem(pMsg->hWin, ID_MULTIPAGE_0); WM_DeleteWindow(hItem); hItem = WM_GetParent(pMsg->hWin); WM_DeleteWindow(hItem, 0); break; // USER START (Optionally insert additional code for further notification handling) // USER END } break; // USER START (Optionally insert additional code for further Ids) // USER END // USER START (Optionally insert additional code for further Ids) // USER END } break; // USER START (Optionally insert additional message handling) // USER END default: WM_DefaultProc(pMsg); break; } } |
内存有富余的就要开辟内存缓冲区,不富裕的就调用Flash上级页面;
另外有动态显示的内容,还得加动态数据窗口,显示返回值。
