使用st官网的硬件 解码 jpg,只能解码一次是神马情况?
hpdell 提问时间:2017-5-20 16:41 /
使用的是st官网提供的中断模式 解码 jpg
具体如下:
uint8_t  JPEG_Display(char  *_path)
  uint32_t TimeBegin, TimeEnd;
  uint32_t xPos = 0, yPos = 0;
  FRESULT  res;
  FATFS    * _jpeg_fs = 0;
  DIR picdir;                                     //图片目录
  TimeBegin = HAL_GetTick();
  _jpeg_fs  = (FATFS *)mymalloc(SRAMIN, sizeof(FATFS));
  if( (!_jpeg_fs) )
    return 0xff;
  /*##-4- Register the file system object to the FatFs module ##############*/
  res = f_mount(_jpeg_fs, (TCHAR const*)"0:", 0); // == FR_OK)
  if(res == FR_OK )
    res = f_opendir(&picdir,(const TCHAR*)"0icture");         //打开目录
    if(res != FR_OK)
      return 3;
    /*##-5- Open the JPG file with read access #############################*/
    res = f_open(&JPEG_File, (TCHAR const*)_path, FA_READ);
    if(res == FR_OK )
      /*##-6- JPEG decoding with IT (Not Blocking ) Method ################*/
      JPEG_Decode_IT(&JPEG_Handle, &JPEG_File, JPEG_OUTPUT_DATA_BUFFER);
      /*##-7- Wait till end of JPEG decoding and perfom Input/Output Processing in BackGround  #*/
      do
        JPEG_InputHandler(&JPEG_Handle);
        JpegProcessing_End = JPEG_OutputHandler(&JPEG_Handle);
      }while(JpegProcessing_End == 0);                                                  // 程序解码第二次时,会死在这个地方 ???
      /*##-8- Get JPEG Info  ###############################################*/
      HAL_JPEG_GetInfo(&JPEG_Handle, &JPEG_Info);
      printf("JPEG_Info.ImageWidth = %d\r\n", JPEG_Info.ImageWidth);
      printf("JPEG_Info.ImageHeight = %d\r\n", JPEG_Info.ImageHeight);
      /*##-9- Copy RGB decoded Data to the display FrameBuffer  ############*/
      if(( g_LcdDirection == 0) || (g_LcdDirection == 2))  // 竖屏,竖屏180
        xPos = (BSP_LCD_GetXSize() - JPEG_Info.ImageWidth)  / 2;
        yPos = (BSP_LCD_GetYSize() - JPEG_Info.ImageHeight) / 2;
      else  // 横屏,横屏180
        xPos = (BSP_LCD_GetYSize() - JPEG_Info.ImageWidth)  / 2;
        yPos = (BSP_LCD_GetXSize() - JPEG_Info.ImageHeight) / 2;
      JPEG_DMA2D_CopyBuffer((uint32_t *)JPEG_OUTPUT_DATA_BUFFER, (uint32_t *)JPEG_LCD_FRAME_BUFFER,
                            xPos , yPos,
                            JPEG_Info.ImageWidth, JPEG_Info.ImageHeight);
      /*##-10- Close the JPG file ##########################################*/
//     f_close(&JPEG_File);
    else
      printf("JPEG_Display f_open Error \r\n");
  else
    printf("JPEG_Display f_mount Error \r\n");
  TimeEnd = HAL_GetTick();
  printf("JPEG  Display  End   ... ... %dms\r\n" ,  TimeEnd - TimeBegin);
  f_mount(NULL, (TCHAR const*)"0:", 0);
  // 显示文件名
  BSP_LTDC_DispStringAt(240, 1280/2-230, LCD_COLOR_BLUE,  // 显示的文本颜色
                      LCD_COLOR_TRANSPARENT,     // 显示的背景颜色
                      &FontAscii16x24,
                      (uint8_t *)_path);         //
  return 0;
int main(void)
  JPEG_Display("0:dfdfd.jpg");   // 第一次能够正常解码并显示
JPEG_Display("0:dfdfd.jpg");   // 第二次就死在了上面的 do while里面了  这是为何啊 ????
赞 收藏 2 评论0 发布时间:2017-5-20 16:41
