对WaitOnFlagUntilTimeout()这个函数名不理解
any012 提问时间:2017-7-5 16:19 /
看输出名,以为这个函数是比较参数2和参数3是否一致。
结果仔细看代码,好像是参数2和参数3不一致的话,才返回hal_ok,否则返回hal_timeout.
  1. /**
  2. * @brief  This function handles SPI Communication Timeout.
  3. * @param  hspi: pointer to a SPI_HandleTypeDef structure that contains
  4. *                the configuration information for SPI module.
  5. * @param  Flag: SPI flag to check
  6. * @param  Status: Flag status to check: RESET or set
  7. * @param  Timeout: Timeout duration
  8. * @retval HAL status
  9. */
  10. static HAL_StatusTypeDef SPI_WaitOnFlagUntilTimeout(SPI_HandleTypeDef *hspi,
  11.         uint32_t Flag, FlagStatus Status, uint32_t Timeout)
  12. {
  13.     uint32_t tickstart = 0;
  14.     /* Get tick */
  15.     tickstart = HAL_GetTick();
  16.     /* Wait until flag is set */
  17.     if (Status == RESET)
  18.     {
  19.         while (__HAL_SPI_GET_FLAG(hspi, Flag) == RESET)
  20.         {
  21.             if (Timeout != HAL_MAX_DELAY)
  22.             {
  23.                 if ((Timeout == 0) || ((HAL_GetTick() - tickstart) > Timeout))
  24.                 {
  25.                     /* Disable the SPI and reset the CRC: the CRC value should be cleared
  26.                      on both master and slave sides in order to resynchronize the master
  27.                      and slave for their respective CRC calculation */
  28.                     /* Disable TXE, RXNE and ERR interrupts for the interrupt process */
  29.                     __HAL_SPI_DISABLE_IT(hspi,
  30.                             (SPI_IT_TXE | SPI_IT_RXNE | SPI_IT_ERR));
  31.                     /* Disable SPI peripheral */
  32.                     __HAL_SPI_DISABLE(hspi);
  33.                     /* Reset CRC Calculation */
  34.                     if (hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE)
  35.                     {
  36.                         SPI_RESET_CRC(hspi);
  37.                     }
  38.                     hspi->State = HAL_SPI_STATE_READY;
  39.                     /* Process Unlocked */
  40.                     __HAL_UNLOCK(hspi);
  41.                     return HAL_TIMEOUT;
  42.                 }
  43.             }
  44.         }
  45.     }
  46.     else
  47.     {
  48.         while (__HAL_SPI_GET_FLAG(hspi, Flag) != RESET)
  49.         {
  50.             if (Timeout != HAL_MAX_DELAY)
  51.             {
  52.                 if ((Timeout == 0) || ((HAL_GetTick() - tickstart) > Timeout))
  53.                 {
  54.                     /* Disable the SPI and reset the CRC: the CRC value should be cleared
  55.                      on both master and slave sides in order to resynchronize the master
  56.                      and slave for their respective CRC calculation */
  57.                     /* Disable TXE, RXNE and ERR interrupts for the interrupt process */
  58.                     __HAL_SPI_DISABLE_IT(hspi,
  59.                             (SPI_IT_TXE | SPI_IT_RXNE | SPI_IT_ERR));
  60.                     /* Disable SPI peripheral */
  61.                     __HAL_SPI_DISABLE(hspi);
  62.                     /* Reset CRC Calculation */
  63.                     if (hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE)
  64.                     {
  65.                         SPI_RESET_CRC(hspi);
  66.                     }
  67.                     hspi->State = HAL_SPI_STATE_READY;
  68.                     /* Process Unlocked */
  69.                     __HAL_UNLOCK(hspi);
  70.                     return HAL_TIMEOUT;
  71.                 }
  72.             }
  73.         }
  74.     }
  75.     return HAL_OK;
  76. }
赞 收藏 1 评论1 发布时间:2017-7-5 16:19
琦子 回答时间:2018-3-27 09:37:45
就是一个等待超时的判断 如果等待的状态在指定的时间内到了就ok
