MDK5.24a最新版(2017.7)分享
yongjun 发布时间:2017-7-6 11:13
代码自动完成功能的Bug已经解决了,试用了一下没有出现问题了。
! S/ G4 O; R9 N$ r4 P0 `3 L" B9 c+ ~: o( w
Microcontroller Development Kit - Version 5.24a
  • [uVision updated to V5.24.2.0]( V+ ]: X: n: P- @0 V
    • Fixed: 3rd party peripheral simulation and dialog DLLs fail to load implicitly linked DLLs.
      7 U* M0 g, g, Z; l7 [
  • [ARM Compiler included]
    3 ?- {. T& D' z4 a2 n) \! m' h
  • [Software Packs included]
    " Y% J; s: X% F( y4 j8 M5 G3 R
    • ARM - CMSIS 5.0.1 same as in MDK - Version 5.23.
    • Keil - MDK Middleware 7.4.1
      . g6 A8 e' H4 ^& x4 r
      • Updated the FileSystem Component to version 6.9.8.! n/ [4 V* d: O6 ^4 Y$ D
        • Added: for memory cards connected via SPI a bus frequency adaptation algorithm is implemented.
        • Enhanced: debug messaging for Event Recorder.3 K+ ]1 C* ^3 f( X  U) Z
      • Updated the USB Component to version 6.11.0.  V) p4 {* n0 W0 Z! Z
        • Added: support for ARMCLANG compiler version 6.
        • USB Host
          * G( X8 w" C+ r1 {) K# S
          • Corrected: enumeration of USB HID devices which stall SetIdle request.
            8 l+ L/ {3 U. M% L+ K
        • USB Device
          9 A* M; F& n) M% g& K
          • Added: Mass Storage Class support for multiple Logical Units (up to 4)., @. v$ v! b5 P, ]: J) @( S
      • Updated the Network Component to version 7.5.0.5 M% A+ N0 f, G1 L9 l* I
        • Added: support for IPv4 fragmentation and reassembly.
        • Added: configurable MTU parameter at runtime." T& ~* v6 |+ a4 E; I3 @6 o  B
    • Keil - ARM Compiler Extensions 1.3.11 |0 k' ~; }$ N+ j# i4 d* r$ J: a6 H
      • Updated SCVD examples to build without warnings for use with ARMCLANG compiler.
      • Updated SCVD Event Recorder documentation.: D9 K* j- v* g+ C6 c
  • [Target debugging]$ @. P9 a. s! D
    • Updated: Nuvoton NULink debug driver to version 2.01.6592.
    • Updated: P&E Micro debug driver to version 6.42.
    • Updated: Segger J-Link debug driver to version 6.16c adding support for ARMv8-M based devices.
    • Updated: STMicroelectronics ST-LINK debug driver to version 3.0.1.0 adding support for ST-Link V3.3 t( |: ]( H! t6 o
  • [uVision updated to V5.24.1.0]
    $ g$ q+ B: `/ j1 s$ v, G
    • Updated: Feature map of the MDK Editions are reflected by the product i.e.:
      ' R  S2 ?0 |  }% _8 o4 R
      • Introduction of MDK Essential superseding MDK Cortex-M.
      • MDK Plus supporting secure mode application development and debug of Cortex-M23 and Cortex-M33 based devices.; j5 _+ C1 o* u
    • Added: Source Browse information is now available in project targets using ARM Compiler 6:! K  A3 y6 s+ y/ i- l
      • Information is generated dynamically, does not require a successful project build and is updated as the source code is edited.
      • While the source code is processed, the status bar displays: Creating Browse Information ….
        , F. K& g  u7 \9 o( C2 N5 r" m
    • Improved: Source Browser window redesign for better usability for project targets using the ARM Compiler 6.
    • Improved: Dynamic Syntax Checker for project targets using the ARM Compiler 6:1) u1 A, m% {: m9 n3 o/ k% ~, F
      • Warning level configured for the build is also considered by dynamic syntax checking.
      • Warning and Errors are now consistent with the build output window.
        ) a  a2 Y7 y/ J
    • Added: ARM Compiler 6 warning level MISRA Compatible suppressing compiler warnings contradicting MISRA rules. Warning level Moderate Warnings got renamed to AC5-like Warnings.
    • Improved: PC-Lint setup:' q2 ]& [) x7 n5 Q6 v
      • separate configuration settings for C and C++ modules.
      • the generated lint command files are stored in the output folder configured for object files.
        0 b& i0 _' e, s$ m8 i- o
    • Extended: the ARM-Compiler version selection in Options for Target dialog adds the option to select the latest installed version of ARM Compiler 5 and ARM Compiler 6.
    • Improved: the MDK-ARM installer creates a backup of the TOOLS.ini file in case an existing installation folder is used.6 v# ~/ S% N# q9 b: D/ X( Z
  • [Supported Operating Systems]1 L. V# x0 `% x1 K" W2 s% j; b
4 a# M6 F. Q) E, L0 W" W! E  Y; Z" f  r8 B: U0 `
https://pan.baidu.com/s/1miSen9I; H+ L; ?" z9 p
- \* `. A8 w2 W不能模拟仿真请参考我的帖子
1 s: {# `" a4 A% P: K, \) x完全解决了MDK模拟仿真后出现的问题; ?1 v( ^" C) u3 N2 e9 X% a+ h/ t6 |
https://www.stmcu.org.cn/module/foru ... 82229&fromuid=75642; |8 D/ V0 p5 e$ m0 N
% E' j' j! B9 q* ^3 v) J- f) a initmap.rar (167 Bytes, 下载次数: 660)
赞 1 收藏 5 评论34 发布时间:2017-7-6 11:13
34个回答
yongjun 回答时间:2017-7-14 17:17:47
本帖最后由 yon-gjun 于 2017-7-14 17:31 编辑 / X- y  S% j1 K1 L
7 i) ]5 W9 Y$ u, w2 K: I' V
在用仿真器的时候,发现如下问题,JLink v8 仿真器用不了,V9可以用,
" L1 g$ |! A2 Y1 i0 b5 e6 @+ M7 B但是在用V9的时候,JTAG这些引脚初始化(复用功能)要设置好(TCK TDI TDO TMS TRST),不要被占用了
# t9 b3 Y3 N# g正常电平如下:
# [3 d$ b) f8 ^0 l$ eTCK: 0, TDI: 1, TDO: 1, TMS: 1, TRES: 1, TRST: 1; }# [* ?0 I! y9 I
否则会出现类似下面的提示:
  S( o3 i# M( {3 H0 C* JLink Info: Could not measure total IR len. TDO is constant high.
" N! p8 }& O7 Y7 p* JLink Info: STM32 (connect): Can not attach to CPU. Trying connect under reset.
3 ]8 ~, e3 P8 J4 p/ O* JLink Info: TotalIRLen = 9, IRPrint = 0x0011
+ |6 p& f& y  K% d7 j5 V1 Y: ~$ X* JLink Info: JTAG chain detection found 2 devices:* X8 s8 T! u/ r4 e- d
) b6 f7 a- [* Q% K  z
**JLink Warning: CPU could not be halted
0 w2 W) Q- k* }***JLink Error: Can not read register 15 (R15) while CPU is running
( z5 D8 M6 N" u1 T% `& s***JLink Error: Can not read register 16 (XPSR) while CPU is running! o9 a+ d3 a! D5 P. A; e; W
***JLink Error: Can not read register 0 (R0) while CPU is running/ ^/ g; K1 t, j4 O
***JLink Error: Can not read register 1 (R1) while CPU is running" U$ K( z$ j: E" K# m* b) \
用SW的方式也是一样的,就是不要占用SW的引脚,否则也会出错。
1 k( ^9 I' b  J: H2 Q
yongjun 回答时间:2017-8-29 15:41:44
皆归尘土 发表于 2017-8-29 11:46
* n0 l, k' E: [. U9 w4 ^问下楼主win10的安装5.24A无法添加License怎么整
, L0 _0 K9 c/ r  D; _- e! L以管理员身份运行Keil uVision5软件,再添加License。记得不要直接双击运行,要右键菜单选择“以管理员身份运行”。
yongjun 回答时间:2017-8-17 08:12:07
yubinwu_3004964 发表于 2017-8-6 17:44
# `& }+ M$ |& A4 L. L3 v升级的安装而不是重新安装出现这个问题
2 c8 i4 o& ^4 h
用管理员权限运行安装试试看
MrJiu 回答时间:2017-7-6 11:44:18
哇又更新啦,更新速度真是快!!!!!!!!!!!!
zhao.zhao 回答时间:2017-7-6 12:47:46
谢谢了
zero99 回答时间:2017-7-6 13:36:26
支持一下,更新好快啊
835439256@qq.co 回答时间:2017-7-6 16:17:34
据说官方要更新KEil的编译器,编译速度会变快,就是不知道啥时候更新啊
arenas 回答时间:2017-7-6 16:38:34
支持下,什么时候编译器也更新就更好了
jcx0324 回答时间:2017-7-6 16:41:52
编译速度一直很慢
waiman 回答时间:2017-7-6 22:35:07
编译速度太慢了,还不如IAR的。所以一直用IAR。
+ _0 y6 m- M7 L* W8 j不过最近IAR也出了8.x版本,编译也很慢。
ychlucky 回答时间:2017-7-7 09:43:50
arenas 回答时间:2017-7-7 11:42:42
已经装上并使用。确实修复了之前自动补全非常难用的问题
zcl201207 回答时间:2017-7-8 14:20:59
Ian-392967 回答时间:2017-7-8 15:05:06
据说官方要更新KEil的编译器,编译速度会变快,就是不知道啥时候更新啊% n6 V+ x) ]8 P% V, `; ^, f+ b' l- F
feixiang20 回答时间:2017-7-9 21:32:33
lianglunfei 回答时间:2017-7-10 14:06:25
谢谢了~~~
wofei1314 回答时间:2017-7-11 15:44:54
感谢分享,话说Jlink不能用了
123下一页
