- [cpp] view plain copy
: `& Q2 U2 k0 u3 w% {) i! V - //串口初始化: 6 R+ d! W* R+ p) ~! Z3 o
0 r" L7 ~# m' ~* _ - #define EN_USART2_RX 1 . l9 u. o6 X5 Y3 L1 r; Z
5 z# m6 P4 q/ V/ _, x - void RS485_Init(u32 bound)
/ M/ k* P: F5 C* p - { ( L/ b% F) c* y
- GPIO_InitTypeDef GPIO_InitStructure;
2 b' c; H$ j' ] } - USART_InitTypeDef USART_InitStructure; ! z$ n, K6 h* f9 u
- NVIC_InitTypeDef NVIC_InitStructure;
6 p1 j, t& F: [0 q - 7 v" [3 U2 e; o" |
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOG, ENABLE);
h9 r; a" F4 } r8 ^" b6 ] - RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE); 1 K- A; X7 L) J
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); 7 l r! Y' u( l
" m" x8 `( b0 X- E( s1 W/ ?/ v5 A4 D3 K - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; // RE ' M h( J1 Y9 A# C9 J+ c+ k
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
; Q2 f8 L9 S V3 R; Q5 ` - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
. o6 X( A- l2 [' x; r9 D - GPIO_Init(GPIOG, &GPIO_InitStructure); 5 N: U& G' p" t: t2 ~8 f" k3 ~4 W0 J! C
- 8 _9 k$ ~; [- o$ g
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //PA2 TX : L$ B( c# Y/ S$ ?; H) ~ o
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
8 E. e8 W" {- }7 n$ L& W - GPIO_Init(GPIOA, &GPIO_InitStructure);
, O- _% W _* y# Z( ]# B -
3 `" V# z' L( @% { - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PA3 RX
7 u# h4 t: d/ V* i# U1 u( }# o - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; 8 r) k; j: b! W2 g& H9 U; Q
" G) l0 @( L( e0 W5 T5 U. h) G: u - 4 U: f0 s( [0 Y2 J5 u; c
- RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,ENABLE); ) B7 z# w& p$ u# J" U8 r! |5 H- i
- RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,DISABLE);//í£?1?′??
8 t8 Z4 p, z2 H3 u, F9 \ -
) u- \3 T) T& w4 E - 5 M' ^0 o2 A" A/ W* u" K3 k& l* Q
- #ifdef EN_USART2_RX // * ~" ~9 `! j3 H" m' N+ W1 z" Q
- USART_InitStructure.USART_BaudRate = 9600;//波特率9600; 5 ^; i# F( u% I% w& ^* L5 i( G
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;//8位数据位
5 [; G0 I7 I6 T" e& M - USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1位
9 R9 l3 y6 M) Q, i% ~( _, ~3 s/ Z5 J - USART_InitStructure.USART_Parity = USART_Parity_No;//奇偶校验无 + V. F8 _$ Y6 p, z) B( A6 R
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 ; Y7 w% [, ~; z
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//串口配置为收发模式
/ Y" ^$ [# @! O8 E - % E5 m+ c( ]( B+ X+ D% X7 N
- USART_Init(USART2, &USART_InitStructure); ;
, M7 H! l( K4 M -
* C6 q. A) E. L+ {+ w | - NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; //指定中断
( s# [/ [, u N6 T( r. o. a8 @ - NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3; //中断抢占优先级
/ C2 w2 I* X! O# N% H6 E3 F4 r - NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //′中断响应优先级
) y" V, E9 ~ s3 M# \ - NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; // 中断函数使能
: R$ `. _! u* b5 s; A - NVIC_Init(&NVIC_InitStructure); ! H6 D' D$ ? v3 U7 Z
: j8 u. n/ n% ~4 C - USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//接收终端使能 ' I, Q/ T! X# v# Q7 a2 X. K
- % i3 j! J% U: F* ~
- USART_Cmd(USART2, ENABLE); //串口使能
/ Y# z' }8 T7 z+ A. i3 Y( K8 O) L - # `% b& h6 ?, g( G
- #endif
1 X# t) C' S% | - 2 P: |2 Y* V1 x8 e u3 a: K( Z% K
- RS485_TX_EN=0; //默认配置为接收模式 这里可以用GPIO_ResetBits(GPIOG,GPIO_Pin_9),同样置1可用GPIO_SetBits(),
! i/ ~8 V, ]9 ]5 h$ t' E - }
9 g6 u# }" S: g" [ - 3 q2 j3 m+ d, \* ?+ O% ^
- //串口的中断函数: ) e+ ?6 b+ `- X; H
- ) B/ v- P$ B! }! ^& l
- void USART2_IRQHandler(void) * ]( q( ]- c, |3 H' K) R7 }
- { % [' m- h4 G7 L1 J
- u8 res; $ b# g! L7 t. K7 w/ V m" j$ l) d
, {/ i! I8 g/ t- t# @7 ^' {+ @ - if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET) 6 y4 @8 w9 m/ M* V6 J+ Y) p# H
9 P/ w) [/ _+ X, [% Y# c - # L4 t3 y2 ]% q0 e7 H& ?% B* X
- res =USART_ReceiveData(USART2);
) x, @. q$ Z) g- O7 ~( U+ h9 ]( w - RS485_TX_EN = 1; $ W3 d( Q/ O/ K5 Y* d* J K* j7 r
- // 此处发送数据主要是为了检验中断是否进行触发 : [ O% d5 O9 T$ l# h/ D; ~% E/ ^" D
- while(USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET); + ~6 S" p/ `- p
- USART_SendData(USART2,0xff); " O/ b- B, `1 ?* X6 i
- \5 |' A5 |+ L2 ? - RS485_TX_EN = 0;
. k) u- e9 l: B, a. u - if(RS485_RX_CNT<64) 2 p! V! ?# I% ^- [9 ^- I! L$ n
- { - c$ o: R( j. q# i7 j* B2 B
- RS485_RX_BUF[RS485_RX_CNT]=res;、 ; N# Z0 T$ E' M# ^. v7 o. \ j0 m
- RS485_RX_CNT++; . p& j/ x2 P/ N8 L9 [1 U
. m1 t( q/ I T5 G* ~9 q5 a - } . k! x5 l1 k& t; u# A, o+ b0 d$ P9 W4 F
+ I3 H8 v1 [: B5 d% Y7 Y& Y$ R' ~# L/ y- B: B$ d/ ]$ n' K/ I2 h8 |
好吧,今天又被串口虐的死去活来,最开始一直怀疑是自己的程序写的有问题,纠结串口配置是不是出问题了,最后找个demo自己找问题,发现收发数据是需要控制复位引脚,进行收发控制,我这里是复位引脚置为1,则可以进行发,为0,则表示收数据,当然如果你觉得设置好复位引脚的值就可以进行发送送数据了,呵呵,你看到的还是一片白,我的数据呢??在发送数据之前你需要写这样一条代码% S# U' f9 B1 K
8 S# |+ \4 ^% h: t( Vwhile(USART_GetFlagStatus(USARTx,USART_FLAG_TC)==RESET),这样我们就用USART_Send(USARTx,data); 发送数据了,之后我们同样还需要用while(USART_GetFlagStatus(USARTx,USART_FLAG_TC)==RESET)来处理自己发送的内容,看上去复杂吧,呵呵。
% u- |) c. h- v/ n- B* c3 Q# J, F" y0 m
下面给出具体步骤:1 [8 x& y1 J0 o D
) ], B; z: Q- f3 c0 m* i2 a8 C
1. 像配置232串口一样配置rs485的引脚,使能相应的时钟。9 x6 C5 `, P8 d+ B5 }
RX: GPIO_Mode_IN_FLOATING/GPIO_Mode_IPD: ~* F6 I3 {8 G4 _
TX: GPIO_Mode_Out_PP
| O5 g5 J5 f$ b z b RE: GPIO_Mode_Out_PP( y- ]3 J* E( \
5 G/ I5 A7 {2 z5 p. \7 ^2 j* t4 q2. 进行中断配置
! ]+ C) R/ q' c9 M/ J
9 J, ^2 c6 x2 v. W, I& O9 L5 o3. 记得使能中断和串口。
" {1 P; Q8 d% P- P8 l& E% Q, ]+ {& S9 O U; I5 M; C
具体还是看代码吧。
7 `3 Z( _& Y. S3 k$ w0 Z. d+ u4 r$ i
