1 A% b7 _( \1 b( T3 f0 M1 Z- /**
' y$ ^3 G, ^0 o% G - ******************************************************************************% `4 L' I) T+ c" }. ]3 j& c( R
- * @file main.c
5 A( A/ _# R4 p/ H- P; i# P# c - * @author STMicroelectronics - System Lab - MC Team
" w' Z% k& F" w9 E4 ] - * @version 4.3.04 m% p; S- Y R' Q
- * @date 22-Sep-2016 15:29( G& K. @5 y7 c0 E
- * @brief Main program body7 w) A. a3 ^, L3 W! T6 B
- ******************************************************************************; i/ v7 j, e- J6 w/ _! y. W
- * @attention4 k* a# x. a( z4 `1 N- W
- *6 H3 ~& ~$ x4 p: ~- p6 _% P5 ]7 Z$ |8 c
- * <h2><center>© COPYRIGHT 2016 STMicroelectronics</center></h2> y( r6 b. l; ~: g$ z8 `+ t" g
3 H2 t, r0 O: w) R, k) S - * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
0 m5 P6 c" U! y" E `) W2 y - * You may not use this file except in compliance with the License.
$ V+ W* {5 t |$ i# H4 D - * You may obtain a copy of the License at:
5 y# ?$ o% r+ U. Z8 w ~1 w - *
8 J; A+ o T# { - * http://www.st.com/software_license_agreement_liberty_v2
1 k6 j5 P! H) S - *
9 z3 w& P0 Q1 Q& l9 n* s - * Unless required by applicable law or agreed to in writing, software " {' ^1 d+ _- O* D
- * distributed under the License is distributed on an "AS IS" BASIS, 3 b( u+ x7 s0 c" G2 `) o
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
8 ^9 ~9 ]2 P# Q: V - * See the License for the specific language governing permissions and. j. i+ p+ J4 f- d
- * limitations under the License.1 I6 |, k+ U: i
- *4 m, [. c* ?/ C8 F
! ?, p( r: w# R* w - */
2 _" h* M ~0 ~- u6 {9 t) _8 O - & q) U' l a( V' L8 I6 A$ S
- /* Includes ------------------------------------------------------------------*/) Y) U' S( m# F4 R5 r
- /* Pre-compiler coherency check */
1 g4 A) J v$ J6 ~3 g ~" d - #define PROJECT_CHK
# p" }% ], b+ p" E - #include "CrossCheck.h"
) E7 p3 {) `7 t: F5 z9 e& k# i - #undef PROJECT_CHK7 }8 l% r: S1 k. T: |
- 4 X2 M% P# g# V) |6 C. q
- #include "MCTuningClass.h"" M8 ^ ?3 H2 K! O2 S
- #include "MCInterfaceClass.h"+ N' l, |; P- c; u' a* D) _6 q3 g
- #include "StateMachineClass.h"- q- k) K r. ^
$ A# U8 b# r; [8 l4 s- #if defined(PFC_ENABLED)' D1 I( T7 m7 r. [( D
- #include "PFCInit.h"
2 D# h# d- d E$ I: @ - #include "PFCApplication.h"- {* q8 z* z+ l+ i y3 R
- #endif
3 n5 h$ y% E2 H+ u0 N4 g - 9 u0 A n3 D: k- W+ B
- #include "MCTasks.h"9 ~0 t9 |' I; t3 |
- #include "Parameters conversion.h". G1 F: U! ?+ E7 E) ]3 j+ u, y
- #ifdef DUALDRIVE7 F6 F% _* G( C! l8 _& V
- #include "Parameters conversion motor 2.h"* O3 w4 D: Q4 m( ~ k) k6 k" p
- #endif
& N( }' \2 Q' Z T) a1 A1 I2 y - #include "Timebase.h" F: l' x$ Y6 ?8 K
- #include "UITask.h"
3 Z3 d7 e* n, q+ i. m - #include "MCLibraryISRPriorityConf.h"
# a6 F- x/ |! s: ?6 Z
5 d6 E1 y5 {$ U% s9 w/ [$ A- #include <stdio.h>
, O+ y$ ^: k. t$ a- {5 Y - % E% O- ?. o, L
- #if (defined(USE_STM32303C_EVAL))
' b& i) a6 e6 E! B - #include "stm32303c_eval.h"
2 c* s5 n% R# U. p6 Z - #elif USE_EVAL* c5 D1 D2 [0 O7 P3 T, o
- #include "stm32_eval.h"
2 u4 ^2 z5 O7 |# E4 O2 W" R2 m9 L - #endif2 t- C; D/ U6 r$ v
- 2 ~! q! C2 ?* s
- #ifdef USE_STGAP1S
/ P( D, V7 |& C# u - #include "GAPApplication.h"
. [* X4 V' I' A H' S& C& U6 h - #endif
h8 T1 s( b( c' f* g
' ~" u, z: V3 h: {# ~- #ifdef STSPIN32F0
$ N, `( c G! t U - void STSPIN32F0_Init(void);
, ], e6 S2 x. O4 B5 Z - #endif- l1 r3 \" `9 F
- & \1 I8 i- z7 }) n; E4 @& L
- #define INTERNAL 0
5 N |: m; n* C. {) O$ _" }; Q - #define EXTERNAL 1
3 V# G' s) ]1 Z - #define STM32F3_64MHZ_INT ((CLOCK_SOURCE == INTERNAL) && defined(STM32F30X) && defined(CPU_CLK_64_MHZ))% K% T N$ D* F( |% Z
- ' i& |8 M3 D: R) B, I0 g2 {
- #if STM32F3_64MHZ_INT" J; `: m/ G* F$ d
- void STM32F3_64MHz_Internal(void);
: n, A$ _7 L! o; o( ^ - #endif
+ f2 [, c% Y. u& }" E3 m - ! K$ @ e' e0 T8 f5 e, K7 S
- #define FIRMWARE_VERS "STM32 FOC SDK\0Ver.4.3.0"
0 s: b- X$ U. l# C9 C - const char s_fwVer[32] = FIRMWARE_VERS;
( \5 m$ l- t/ X. N# j `, f) } - 1 @" k$ l! c' V/ a7 D c
- #ifdef __GNUC__8 r5 H/ D; n6 L. ~3 i
- /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf) T* C7 `0 F" }& J+ B# Z/ u' t
- set to 'Yes') calls __io_putchar() */# X4 R3 y- U) E! s4 z. E$ C r
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
6 l# {. O$ F/ J: ?9 C - #else" V% _* b1 L& z$ x! `
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
* v0 V7 l) v" g: E - #endif /* __GNUC__ */5 V* s/ x7 Y1 N8 {9 D% E$ }: V
7 W8 v* ]9 E4 {- x7 f# z- #if defined(EXAMPLE_SPEEDMONITOR); e) X: J4 q/ l$ M# h- i
- void speedmonitor_start(void);
* E$ C) b" e' n- b - #endif
4 [+ y' V. f: W; A( Q - #if defined(EXAMPLE_POTENTIOMETER)
: B* V' t* N# h8 r: h- K9 P - void potentiometer_start(void);
- t0 b, o- M% f* ]" p! `1 c | - #endif * i' @5 c* h* {6 z) l/ A. U w
- #if defined(EXAMPLE_RAMP)3 `# g& b! ]4 N5 t
- void ramp_start(void);$ D }6 U' G( L: s
- #endif
; }, p1 ]2 X* u7 s/ F. o - #if defined(EXAMPLE_PI)
2 F: W; r9 V* o* w9 l, W/ s% G - void NewPIval_start(void);
+ N6 L9 y% \* X - #endif
0 s: j: V: K3 j% }; k U - #if defined(EXAMPLE_CONTROLMODE)
# e1 }0 U7 e2 o3 m' O - void TqSpeedMode_start(void);
2 I1 l# v1 R4 T5 d( s" C, A - #endif 3 p! j* L+ g+ L( ^4 y
2 h4 }+ T- U8 \* r/ ]* f - /* Private function prototypes -----------------------------------------------*/6 R) Z! s2 f) @5 F7 r) T
- / K, e# F. A$ K! j" v% a0 r1 F1 T
- void SysTick_Configuration(void);! V; j) _, B1 d! y$ I- E+ i3 L
( |: E( J8 E' C- /* Private variables ---------------------------------------------------------*/ P+ v' O. P+ |" p% ]+ ]
- + |+ V0 A" M8 f. @
- CMCI oMCI[MC_NUM];
3 c& \3 q6 X) b. s0 w - CMCT oMCT[MC_NUM];
' k' M; ~5 H# G& K
L6 h0 d4 ]% ~; Q+ b/ \% Y- uint32_t wConfig[MC_NUM] = {UI_CONFIG_M1,UI_CONFIG_M2};3 g% K5 @+ p4 z x! N4 e+ T! a# B. m
- uint16_t mytime;
5 p/ |( u' ]; \+ H( ]" H. J - uint16_t Fault_Type;
6 Q" p6 ]$ @3 h - /* Private macro -------------------------------------------------------------*/
! j2 B) Z+ B; g7 T - /* Private variables ---------------------------------------------------------*/ ! d; m8 ]# `0 @8 D* z& H$ V
! R8 P/ c" y" W' m* X- /**; ?: X4 i1 k; x; n2 @
- * @brief Main program.. |1 M* w9 j0 S: w' `+ h
- * @param None) A T. _" a% `( ]8 w# U
- * @retval None
' R2 N% A& p8 i7 K3 O$ H8 J/ x - */
6 L& X9 d2 l" ^ - int main(void)3 o! `! g1 W. M# @+ Y0 u
- { ! Z/ m( ?: U( ]( v4 `! W& | |
- /*!< At this stage the microcontroller clock setting is already configured, " @8 |$ _" t0 x2 k3 \
- this is done through SystemInit() function which is called from startup1 w( u4 U1 q" U2 f" R A: ]
- file (startup_stm32f10x_xx.s) before to branch to application main.
4 B4 w; U- v& J% N4 O& }& f - To reconfigure the default setting of SystemInit() function, refer to' V8 Y) g& k. S. y$ o
- system_stm32f10x.c file8 A5 [" z6 t l2 Z1 s" r
, |& Y( @% N d( z -
) y/ z+ a* [& d% w" }, X" z e$ t - #if !defined(STM32F0XX)
1 m: ?: g6 I( A" @ b - /*NVIC Priority group configuration.; A* K' r/ W0 f B! U
- Default option is NVIC_PriorityGroup_3.
6 H+ m$ d, H# r. ^ - */$ i/ @7 G+ W V1 W d4 G8 {" h
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);2 f* k* P3 f4 U, {& L: h/ m
- #endif E' l5 i" a. {* `. p) S1 e* l
- 5 J( n% o6 I! j0 ?
- #ifdef USE_STGAP1S9 L# A7 e" Z, A- K2 i
- GAPboot();
% Y. e- P# P3 y3 D* |/ F - #endif3 a; j! ]& D1 K. E
% c0 N5 t3 B6 ~' Q& d1 ^% d% S2 \- #if STM32F3_64MHZ_INT
* z @# L2 X" r% k3 A$ _/ G - STM32F3_64MHz_Internal();
7 T' B! M; j6 O3 M0 c - #endif
9 ] t. y; r& D& R. \1 R$ ?! z - ( E9 \7 z1 G' W* {
- #ifdef STSPIN32F0
: g- V$ R$ o; M4 f. K& I" ?! a* ] - STSPIN32F0_Init();+ p9 e ?$ ]; U# h
- #endif- n( {2 t5 n* S3 [
e4 O# B* F; K, r9 k - /*MCInterface and MCTuning boot*/
$ {3 l) b7 L5 g( P, g7 x - MCboot(oMCI,oMCT);
1 q2 u, A: S4 ^# m -
4 W: Z3 u) o8 B6 i - #if defined(PFC_ENABLED)
+ k4 L6 H# o/ K4 O - PFC_Boot(oMCT[0],(CMCT)MC_NULL, (int16_t *)MC_NULL);7 ^1 H% ~) r- u/ {( T5 Z% _2 @" }
- #endif- p$ Y: U. S: g' o3 R9 ^
) f% E9 W2 K" v - /*Systick configuration.*/
) m6 {! y4 t7 @! e9 E* O - SysTick_Configuration();
6 e6 o0 D% u' s -
) z1 _) t7 u# ^) f, ?: E% E+ V5 H - /* Start here ***************************************************************/
+ V# R5 c, q6 E1 A' A - /* GUI, this section is present only if LCD, DAC or serial communication is */2 s' f' z, z- t% C# |
- /* enabled. */, w3 Z) p; b: o8 ^# m6 [! \
- #if (defined(LCD_FUNCTIONALITY) | defined(DAC_FUNCTIONALITY) | defined(SERIAL_COMMUNICATION))4 G7 X+ z1 W* h4 y/ Y
- UI_TaskInit(UI_INIT_CFG,wConfig,MC_NUM,oMCI,oMCT,s_fwVer);
: k, i/ i+ x9 w8 G& D k: l2 l - #endif
' K0 G0 u8 _2 U& n - 8 p8 U4 B8 C, b% ]2 l/ @$ `
- #ifdef ENABLE_START_STOP_BUTTON( Y% z; J. N$ x" o1 W
- /* Init Key input (Start/Stop button) */
6 l) O" a' x( o# R - {8 x1 |: @/ d. Q7 D# Q- P
- GPIO_InitTypeDef GPIO_InitStructure;8 i5 g# L% c- [4 t# {1 J6 l9 W8 _: p
- GPIO_StructInit(&GPIO_InitStructure);- K4 I5 x! ~7 V u- [/ L( |/ H
- GPIO_InitStructure.GPIO_Pin = START_STOP_GPIO_PIN;' {9 R/ C- y' l* a
- GPIO_Init(START_STOP_GPIO_PORT, &GPIO_InitStructure);) r) Y9 G e3 S+ c
/ \+ m1 w5 [ m) R# I+ I - #endif
! p, P# S' {! F% [ - //TASK2ÐÞ¸ÄPI²ÎÊý
8 i5 A! p8 w" }) m ?- M( M1 t - /*
9 J4 g+ Y, Q, m8 L# D0 \( }3 H; } - static int16_t Speed_Kp,Speed_Ki;
e X: H/ K( o }5 F% h E - static CPI oPItuning;
" W& Z0 N5 ^# p* b - oPItuning = MCT_GetSpeedLoopPID(oMCT[0]); // ????PID???
3 R3 G$ U" `$ B" d. F - Speed_Kp = PI_GetKP(oPItuning); // ????PID??
/ S& N9 M$ k' k/ k, t - Speed_Ki = PI_GetKI(oPItuning);
" w$ D# @5 L4 X, h4 K - PI_SetKP(oPItuning,Speed_Kp*2.9-300); // ??PID??
& T3 _# E y) M6 H$ W2 y1 _- b - PI_SetKI(oPItuning,Speed_Ki*2.9); 5 r% a: K- w0 X/ ]0 S
- */ </font>3 v0 @+ d. k+ |+ ~! L: i
- /* End here******************************************************************/ }) L6 O4 ^. y+ I2 [% M
- /* TASK3Õý·´×ª¹ÊÕÏ
- h+ @! H0 {- n - MCI_ExecSpeedRamp(oMCI[0],3000/6,1000);$ N8 ]/ m+ P1 O
- MCI_StartMotor(oMCI[0]);& G) R) ?8 ?& z8 D) v1 T
- MCI_ExecSpeedRamp(oMCI[0],-3000/6,1000);& s9 {% E0 u5 S. l
- CSTM oSTM = MCT_GetStateMachine(oMCT[0]);$ u# F5 K$ g; x! b3 z
- //STM_NextState(oSTM,STOP_IDLE);
/ y- J# ]" [* I1 i1 J4 f4 I6 t - STM_FaultProcessing(oSTM, MC_SPEED_FDBK, STOP_IDLE );</font>: `: N+ E0 \$ S# ?
- */ 6 J" K, A9 b- `3 T& k5 i3 ~* G! m
- while(1)
* d' _9 V+ a' U% _& [( w - {% b+ B7 j+ y* H( j6 S
- 5 b+ S* p0 y+ J" ?, L& @- \
- /*TASK3' z5 M- m# U) T
- Fault_Type = (uint16_t)STM_GetFaultState(oSTM);
8 e. \' h6 K) ~% u- _$ P - if(Fault_Type == MC_SPEED_FDBK)
: m+ E" i @; X: w$ b! D - {
2 S% K W' `! A8 |5 `* e9 E+ a1 a - MCI_FaultAcknowledged(oMCI[0]);
' {* G- q8 L5 t! O" X6 c, M7 G g& m - MCI_ExecSpeedRamp(oMCI[0],MCI_GetLastRampFinalSpeed(oMCI[0]), 1000);
; r; P5 W6 [- b! @$ ^ - MCI_StartMotor(oMCI[0]);" R0 K9 g8 S& H# J
" Q0 A. J8 e q% g. H2 Y - */</font>' s1 z B8 p0 W
! P1 b9 R& k$ d - , r8 a2 u& j8 w9 O
- /*TASK1% E ]4 A+ L, z$ A9 i9 Y
- if(mytime==0)
, U) x; ]0 h$ Y9 e! c; |0 Z( m5 Z - {9 n# b. x5 I: ^7 A9 O- `( u
- MCI_ExecSpeedRamp(oMCI[0],3000/6,1000);7 r$ O$ h/ t w8 y
& v( U" @: t8 I/ ^9 f - }
7 b: `) l; K; A, T% n a - if(mytime==10000)
6 R5 s3 }9 s% {4 ^) U. N5 ` - {$ {1 v$ o% O/ `
- MCI_StopMotor(oMCI[0]);
* L2 I# w9 k& n) F+ ?% Z I ?9 a/ w - }
l: n5 t5 D& x5 p - */</font>
0 o5 N8 @1 J* X4 n+ L$ j, e( l! Y - #ifdef SERIAL_COMMUNICATION
3 J. d3 u i+ W8 O. ~: T - /* Start here ***********************************************************/
2 v8 [- @9 d7 c' e' R( |7 T7 W$ ~! v - /* GUI, this section is present only if serial communication is enabled.*/
+ F' W# ]" U7 _7 Y - if (UI_SerialCommunicationTimeOutHasElapsed()); I; a2 ~ Z' h
7 k S6 k5 P9 F- u) K; l( \# L4 B - // Send timeout message; y7 I- n& S8 y* D1 f4 a
- Exec_UI_IRQ_Handler(UI_IRQ_USART,3,0); // Flag 3 = Send timeout error*/
$ i$ i: r3 f+ u$ Z - }: ~) S4 Y% O; M% y8 n- N
- if (UI_SerialCommunicationATRTimeHasElapsed())2 W" t$ G8 T7 z* X4 {, m& t+ ]
- {# i- N' U4 E' k0 K; R
- // Send ATR message
* g' }% R5 Z' s8 M5 I) v - Exec_UI_IRQ_Handler(UI_IRQ_USART,4,0); // Flag 4 = Send ATR message*/
: _0 E$ T+ s6 W* ?) ^: M4 C1 n - }
2 g6 A6 O( ]" o* D& E8 l- f) T! O# E - /* End here**************************************************************/# y/ t& ?8 d# h( I( g2 q- A
- #endif
, b! D8 }; Q; {' F5 h0 `+ m& H
4 x; b) U+ G; I$ R, c- #if (defined(LCD_FUNCTIONALITY) || defined(ENABLE_START_STOP_BUTTON))% B; t3 C/ s- g( p0 a
- /* Start here ***********************************************************/1 S: r8 |" }4 V0 k/ x
- /* GUI, this section is present only if LCD or start/stop button is enabled. */- a) d8 c8 |" f! t
- if (UI_IdleTimeHasElapsed())
0 M5 Q; Q2 ^# k2 z' M ~$ r5 N) l - {
2 {7 k3 `/ F* V5 a7 ?4 o - UI_SetIdleTime(UI_TASK_OCCURENCE_TICKS);: }5 B4 i D5 |/ Y& F
- 3 w/ B* F6 E! J3 h$ _# N
- #ifdef LCD_FUNCTIONALITY6 Z# P0 P% _3 T0 Y5 S* o
- UI_LCDRefresh();: J; a$ [$ [) ^8 S' t5 U/ e7 f( \
- #endif
4 d2 |. r6 a- R( ^4 J! ^ - $ y. E: V4 y) c/ o$ l o/ {# d6 K- h
% c) `) t/ q9 J+ H - {" e( d' A6 o' g( Q5 Z8 J. H% {
- /* Chek status of Start/Stop button and performs debounce management */& j! H0 R9 u5 O [) e% E6 A
- static uint16_t hKeyButtonDebounceCounter = 0u;
0 Q3 @$ |& H7 w/ K @- J - if ((GPIO_ReadInputDataBit(START_STOP_GPIO_PORT, START_STOP_GPIO_PIN) == START_STOP_POLARITY) &&
* q, }3 w( `0 y7 w - (hKeyButtonDebounceCounter == 0))
. u( V1 z, j/ @" H; G! |. d5 w - {
; m9 m6 f* e4 ] q( a# b2 B1 g. J, a/ s
B; S9 u% B* v# s7 Z# A+ L# ^- #ifdef SINGLEDRIVE* I6 J, b2 P4 X, H2 X
- /* Queries the STM and a command start or stop depending on the state. */
4 \2 M! B; d5 P) ?3 m& C: o - /* It can be added to MCI functionality */; D8 b6 ~# C4 \* i$ \
- if (MCI_GetSTMState(oMCI[M1]) == IDLE)
+ J% A! f- C8 ~" g z; w - {9 P( o. u7 L; P( M) Z: e7 H
- MCI_StartMotor(oMCI[M1]);
2 X% v9 H9 h$ R$ Y1 _: d3 k( h. |) x - }
' \$ z, z7 c, a3 m" Y- k( y5 O - else! b5 r& ^% C2 k4 l
- {$ c$ C" _$ W+ v9 f, @' e+ Q
- MCI_StopMotor(oMCI[M1]);0 O/ D+ I( H" D/ X
- }. E& n! u9 H2 P2 r
- #endif
$ g8 T( B( L' \ - 6 a6 f& f a, ]) z
- #ifdef DUALDRIVE* h" X2 Z/ g# d
- /* Stop both motors */
* J( [1 p5 k% |$ s - MCI_StopMotor(oMCI[M1]);7 f" t; j6 K w2 t/ w7 N5 A
- MCI_StopMotor(oMCI[M2]);
4 A+ h$ }( F- n0 p3 t - #endif; ^' S) i: W! `4 [
1 ?7 b1 l8 x4 ?- A8 [+ \9 E- hKeyButtonDebounceCounter = 4u; /* Debounce time xx * LCD Clock */
4 d+ B- K* a/ n0 _! J' _8 l - }# w% P. q- t7 L5 h: S/ w7 K8 T# z
- if (hKeyButtonDebounceCounter > 0)
& w9 d4 `; w" I5 a2 H - {6 y2 N6 u: s# Y" ~
- hKeyButtonDebounceCounter--;- C) ]: c0 Z7 }+ ]
+ O% f: Y H2 C. `- n - }
/ O% i k' @- ]9 f3 A0 C - #endif/ @" `" d' j K5 Z' E) Q) A. ~8 L
- ! }, l6 j" v3 p8 N ]4 D1 S0 i
( v5 Z* r* F& A& h& |4 k - /* End here**************************************************************/ 7 [* W& [) e) q: h
- #endif; c( C, ?0 u. ?1 O- B' ?. V9 U
Y5 Q @7 `6 c n# O% {- /******************************** EXAMPLE AREA ******************************/
. ^3 o7 }/ b& f: o* f2 t - #if defined(EXAMPLE_POTENTIOMETER)* I( B5 l* Q4 i0 Z2 l
- potentiometer_start(); 7 N- ]1 O2 o) }. V( i$ u
- #endif 9 C2 O- [: L; d$ R8 I' h3 O0 s
7 y, m* h' X2 P ]. M - ramp_start();3 L, Y" s7 V. s% d0 u- ~2 U& L M
- #endif
3 y9 K( U5 ^( m9 G+ C - #if defined(EXAMPLE_PI)- ?. Z, E, e8 g
- NewPIval_start();
+ a1 w: y0 ]6 z3 Q# g - #endif " [1 O, d, c$ S/ E# a& a5 o% o9 v
- #if defined(EXAMPLE_CONTROLMODE)0 f4 |7 D1 m3 A, i
- TqSpeedMode_start();$ f* w0 Y8 k' r4 n" w3 E
- #endif
v, Q! A1 y0 h! r; _) t - #if defined(EXAMPLE_SPEEDMONITOR)! C& D7 i; J% G' u S
- speedmonitor_start();
/ c6 C2 Y; Z6 E6 k! o - #endif
. U [* H# D6 S, f0 e/ [' ? - /*****************************************************************************/7 L1 F$ Z7 B* Q& r
6 T( c& O& s6 H7 @6 f3 p/ t5 T - #ifdef USE_STGAP1S
5 K3 u0 [8 K6 b0 R! D7 V. @ - GAPSchedule();
7 h$ b# b; ]( w - #endif! P# J/ i. r. R/ @" F- ~. _* {( [
- 5 P3 q2 f1 a# h$ u
W/ k# X: T+ I3 u0 r4 u - }7 d" x" H& Z. @
( Z9 q$ K$ g' U4 r- ]) y+ q% X v" F' j - * @brief Configures the SysTick.
" P, Z- f8 s+ G - * @param None: F+ T8 o) h8 E7 |9 N% V
- * @retval None
$ i; e4 s; }; s8 S - */
& P; r9 ^ l; l% x4 I$ A - void SysTick_Configuration(void)- n0 \: _) g, e
- {9 l# j# o. P4 }. |( p* |
- /* Setup SysTick Timer for 500 usec interrupts */
3 L1 O- U% R& I" t - if (SysTick_Config((SystemCoreClock) / SYS_TICK_FREQUENCY))/ k) k. G) Y- g5 q$ f9 x
* C0 c/ y# g& w& v3 Z - /* Capture error */
. z D/ c$ i+ B: g9 L( X; ^ - while (1);
7 E" d2 e/ o2 z - }
, g- C) `1 ^* T# _* x8 } - - t8 E l" H8 B+ B
- NVIC_SetPriority(SysTick_IRQn, SYSTICK_PRIORITY);
; q% }: k; L! ~# s8 [- l: i) G - NVIC_SetPriority(PendSV_IRQn, PENDSV_PRIORITY);$ T) |. A- Y+ R h" f4 O
' J7 n8 `8 W3 S$ i8 p
$ Q& ~! b5 s; o8 @* E- #if STM32F3_64MHZ_INT
, j' [- E6 {; p# I+ i1 {" k - void STM32F3_64MHz_Internal()/ j7 ^1 e( I @; P
5 u4 _" |3 M$ m5 B1 l S$ R - #warning "Internal"
/ ?) V" q, y5 p - /* Cleaning of Source clock register */% Y, i$ W5 a$ D( ?, }& t- d/ d
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));' G- D/ s* U! e1 o* M/ T/ W! t0 a
- 3 d" j: I, N; p4 l5 X$ q
- /* Disable PLL */
( Q) k+ j' U1 C. G9 ^) o# T - RCC_PLLCmd((FunctionalState)DISABLE);' s* p8 y( N" G( a0 [7 ^' V$ U
- " v9 q8 j( ^ Z! v! b% G+ n
- /* Wait untill PLL is cleared */
0 O5 h+ ]; Y' V# | - while((RCC->CR & RCC_CR_PLLRDY) == 1)1 P, t6 d: h4 U% Z
- { [8 f/ g1 W8 r' X
- }( R. i% _$ o( } D6 @
# B6 v4 X' O8 F - /* Setting of system clock to 64 MHz */, B: ~0 {' F( h
- RCC_PLLConfig(RCC_PLLSource_HSI_Div2, RCC_PLLMul_16); //8/2*16 = 64MHz% n8 M! V3 F' J P2 N
- 2 n7 F$ B# ~5 T/ j
- /* Enable PLL */. i; K- y9 n: x5 ? @
- RCC_PLLCmd((FunctionalState)ENABLE);
6 t4 i1 f; `) k* B" q -
( C) H: q2 Y; {4 y - /* Wait till PLL is ready *// H( I2 F3 T; p4 ]+ f0 z
- while((RCC->CR & RCC_CR_PLLRDY) == 0)
2 @" M7 M1 I) Q: o5 z! A - {: T4 C3 l$ C4 Z. z2 J7 K0 _& M( C
. G3 T% F$ f) E4 ^7 X6 e7 @ s" C/ S -
]7 W: Q" o! s! C - /* Select PLL as system clock source */7 q* m- N6 h# B8 g8 o9 J# ^/ r
- RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL; " W5 q! \. K+ c9 e8 G
: Q2 a1 H- I9 W5 c - /* Wait till PLL is used as system clock source */+ k+ f4 F- `+ B& _6 b- m1 Q8 F
- while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
% `' ~: I) j" G/ H" d, G5 E - {
- P$ R% D2 b; l! P( i - }, B; O# G K, Y0 ~7 O9 M
1 c# {* _9 U, U1 `8 f5 ?* Q - /* HSE disabling */
1 K( O% y1 L3 i0 O; k1 V4 w* x - RCC_HSEConfig(RCC_HSE_OFF);8 b& Z8 f- P* O* f: k2 G) ]
- ; T" ^/ L, b7 h; x
- /* Wait the disabling of HSE */9 i8 C+ U) |6 N+ r/ {% P
- while(RCC_GetFlagStatus(RCC_FLAG_HSERDY)==1)
5 z0 s' y# z4 ~ - {% G: |% h6 J) Z7 W: G9 q4 V5 [% G
- }1 ^ R( `4 _+ e" }' i
- }. Q) w$ W. q/ b4 T9 `2 a
- #endif: q6 D' ^( q- W* D8 H
- ' |% O3 |$ ^ s
- #ifdef STSPIN32F0( o* T9 U0 g! b% ~' u3 B: u
" W1 z1 T. e" o1 n1 i - {- W8 k- a5 g' f* ^# k+ k
- /** This function is dedicated to the manual setting for STSPIN32F0. **/
& S7 e3 U9 X, R$ j8 M - , M$ z. k0 X3 s* d+ r l9 u
- /** Setting of internal clock source **/
' T5 b7 Y5 K: |$ K) v -
1 b6 x: ]6 o% P6 R' U. R2 e - /* Cleaning of Source clock register */
# |0 R9 j0 |" D3 K( u; F - RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW)); k; F! g0 D. d: Z6 y2 P5 X ?. H) U) q
4 `, L8 T- H0 b+ c2 \! R - /* Disable PLL */, z1 ]7 J6 ^: y3 X
- RCC_PLLCmd((FunctionalState)DISABLE);4 H3 K, s" d% Q. d' X
4 c! X5 H7 P/ X3 }- t, z - /* Wait untill PLL is cleared */) r8 s% n: X$ z* b
: P, X& ?) Y4 G& X+ i - {- D* w2 k1 @ W( Z0 x
- } W& j- Y! J4 e& I& `3 T" g; U* F
- ' \" Q9 n- h( t& i2 _8 G
- /* Setting of system clock to 48 MHz */3 T9 y% g4 T$ q- t( g5 I! V
- RCC_PLLConfig(RCC_PLLSource_HSI_Div2, RCC_CFGR_PLLMUL12); //8/2*12 = 48MHz r# B+ V* L7 P
7 q" k, `% [# H# t& Q' `' E - /* Enable PLL */
' T5 q8 P8 T! _) Q5 B2 o - RCC_PLLCmd((FunctionalState)ENABLE);
9 N' S% E- W* Y k+ X' i- _0 p -
8 o# c1 E! w' Z( h# X7 A - /* Wait till PLL is ready */% M6 x5 S6 Y: ~* w3 R7 r( a
2 d% k6 U4 ~8 q" L- ^ - {
, f) y! ?1 |6 j8 P5 t8 ?5 E1 D) y - }
$ [' k3 L& w' }* D -
; C2 l% V C, L% |; [ - /* Select PLL as system clock source */8 i8 [0 k8 u' N" T* M: U6 l
p$ g) n! q& l - : k# p: X! U( a; y. U& ^" H6 O
& H8 _0 M4 `* x2 [9 W; r2 m" e5 D9 Z - while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
, W8 `5 S3 D" y) I - {" t" E+ S" S4 R! i/ _7 g% t
4 c, l( g8 o/ k Z, r3 A - / t4 X4 [! N* \4 S! ~# Y" B+ ~0 u4 y
- /* HSE disabling *// A( g |, Z- g# ^
' A/ V, E1 Z9 z - ' b) ]/ z, M! y/ a; ]2 b1 c
) S o+ l; X% |* X1 O2 Z - while(RCC_GetFlagStatus(RCC_FLAG_HSERDY)==1)
0 |: ]1 ^4 e8 E - {
, ]: P6 I' G- o: ] - }9 U8 C+ m9 ]" e, v |+ y
- $ _3 b. R, i8 ?+ ]: o
- /** Setting for OC protection th **/, y( h% N7 u" q: O! h1 t) L3 z
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOF,(FunctionalState) ENABLE);
/ p- J5 H- t" A - GPIO_InitTypeDef GPIO_InitStructure;+ K: N/ {& k* ^1 k8 z4 S
2 _7 t5 t: [; I+ ~! H8 y3 t: d - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;7 H, A1 j6 x; a
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;' G: k8 h8 z( r( q. ^
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;) ?' Z! n% s8 X% ?, K3 f
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
& y; n' Z) F. z1 r - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;5 B' V( ^/ k5 c2 }( M1 X
- GPIO_Init(GPIOF, &GPIO_InitStructure);; V) w# D7 r* V
- GPIOF->BSRR = GPIO_Pin_7;/ e. [+ @! B q5 ^0 a& F, \
- GPIOF->BRR = GPIO_Pin_6;' b$ f) ~; l* I& M( g$ v9 l) D
) x3 T1 S9 M, f& Q6 O, N0 |" t - #endif
# c* w8 i* A# v! ^ - ! e4 i8 Z9 o) S$ k0 Q. V
- #ifdef USE_FULL_ASSERT
6 R" d* M$ `3 k4 U( ?! q, g5 ? - /**
9 w( E, b: C2 f) b$ c* r5 T - * @brief Reports the name of the source file and the source line number
) W" i+ q6 M$ n1 @) |' A) N - * where the assert_param error has occurred.# c8 I v+ z7 v+ y
- * @param file: pointer to the source file name5 A; u' v" S* `! I
- * @param line: assert_param error line source number
4 G4 V% U7 ]! [0 ~+ R% x - * @retval None4 [$ a5 T* q. W0 x
O4 k1 F0 W/ a3 F/ c; E3 { - void assert_failed(uint8_t* file, uint32_t line)7 H7 I/ m3 ]* p# T3 V
- { . N( [7 f5 t3 S+ m# A
- /* User can add his own implementation to report the file name and line number,
7 m8 [1 ~; H% e; A! |; |! G7 t* g - ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */4 M! ~$ C6 a5 g4 C& T0 u; Z* |
- % `& y, R$ ?8 L3 l1 c% O0 U# Q
- /* Infinite loop */# i9 ~: M( w5 Y1 [& M! e! b
- while (1)
1 S: l3 `1 N( g( s: u! } - {9 N) ]6 p. l7 D
- }7 R5 U) C- x: u
1 U- q. c; k6 q% m6 A - #endif
% l/ I6 K( ?2 r! d! s/ x; R - 3 T6 c% z8 n5 u. ~' s
- /******************* (C) COPYRIGHT 2016 STMicroelectronics *****END OF FILE****/
" C/ }) J8 Q" u
复制代码- /**/ Y# U% H2 |" y( m3 z" y
# [# p0 X Y6 N# |; c8 F; q - * @file Project/STM32F30x_StdPeriph_Templates/stm32f30x_it.c
5 Y4 b( s t) T2 L) |! e+ l; Q9 Q - * @author MCD Application Team: M4 S0 b. Y! |7 |# t% E
- * @version 4.3.0- {) |" @' g+ X( U
; n" z2 S3 Y" X# Y# y1 M - * @brief Main Interrupt Service Routines.
' g$ V7 D& }3 S; _" G1 _ - * This file provides template for all exceptions handler and ! T* f2 p* r9 [ s1 R
- * peripherals interrupt service routine.3 E2 y$ D% N( Z: i6 [8 Z& q. z
- ******************************************************************************4 H# ]- t$ b9 e
- * @attention. ~8 T9 W* f% B6 M% K0 |$ T
3 v6 V% P8 K! P6 t - * <h2><center>© COPYRIGHT 2016 STMicroelectronics</center></h2>
. a; o# L" W/ }+ I - *
$ \- V3 J" U& g9 S- t$ H - * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
4 V) H. A( w' I3 V( u7 e7 x7 M - * You may not use this file except in compliance with the License.
3 |0 @* x x# O8 e7 H2 v/ _8 p - * You may obtain a copy of the License at:
. q3 a$ Q$ C! r) l - *4 L% V0 A# D, F" P" F& B
- * http://www.st.com/software_license_agreement_liberty_v2) D( H/ | \9 `' Z" ~
& X$ s& y! |# }+ x - * Unless required by applicable law or agreed to in writing, software
0 [) X1 Y v2 x' n! P& ] - * distributed under the License is distributed on an "AS IS" BASIS,
4 @6 g- B. A5 G - * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.+ ~2 d, ]" ~- p
7 n6 x6 u9 q( o& K7 u - * limitations under the License.8 i! _$ ?6 l: a. D& N* O" k O
2 [2 b5 R3 j2 _4 `: I* b - ******************************************************************************
7 e* R) s1 x; a5 v( [" s$ z - */$ {, M+ \, k1 |0 N; m, q n$ N6 v; \
- / o5 ~2 T& `6 S$ D& \
5 i1 k! l, o1 O0 Q4 l* A3 U - #include "stm32f30x_it.h"
' E# s) M6 v; S" U" i) p' b( i - #include "Timebase.h"
! B. a% n' v8 ~9 h. M" q/ Y - + q4 z7 O3 b" s1 h
- /** @addtogroup Template_Project! B2 _3 g. D+ Q- g# E+ j; Q5 }/ M
% E0 v/ m. {3 J+ Q - */
' P- l* `' |8 A' V9 v0 b - 3 B1 Q& n$ S/ \6 F, P
- /* Private typedef -----------------------------------------------------------*/$ U& S4 n1 G0 u: C [1 d+ G! I
- /* Private define ------------------------------------------------------------*/
* Q: s8 @9 D0 `, V! p- e - /* Private macro -------------------------------------------------------------*/
, _" A2 t+ F6 t p1 a0 J! W - /* Private variables ---------------------------------------------------------*/
6 L8 E0 e+ Y, n+ m0 U - /* Private function prototypes -----------------------------------------------*/6 m" p% k& R/ ?& w' {0 O
- /* Private functions ---------------------------------------------------------*/& W0 d4 `3 S4 k G" z1 G" r8 V
( Y" t# W8 S0 X" l: I0 K" t+ ^- /******************************************************************************/
/ a1 C5 @7 `6 _9 p* I - /* Cortex-M4 Processor Exceptions Handlers */3 R9 O% v9 ]0 S' m1 J
" l3 }$ w7 h+ J% h' H
4 E: K. w0 {7 D1 X* o- /**( h+ z- x; L& } }2 b# H
- * @brief This function handles NMI exception.
9 l+ W4 z( I) f" U' ` - * @param None
' j+ L% K: u# w# a - * @retval None" b0 F5 _* e, i$ b" B9 U9 [4 n
; D( G7 Y4 ?* Y' e - void NMI_Handler(void)0 ^% W8 l6 C. K5 N* v% D
- {8 ]$ S0 n( b+ n5 J* z
: g& O4 L, g! G- t5 b4 z% w
; X7 s: p6 I4 B' A C* a2 |$ J1 {- /**
9 O; r$ z% k% k- P) ~ - * @brief This function handles Memory Manage exception.2 w0 e& I( J% k5 Y
- * @param None
# f( s# a# R! Z9 ?( p. A1 M - * @retval None
" c0 c3 p8 \) ~' o' t. `: b6 N - */
& F# e# |. u6 @9 H - void MemManage_Handler(void)1 J5 v7 r" y7 c( J$ ~) b
# x2 R, K$ D; Z. C& ^! h - /* Go to infinite loop when Memory Manage exception occurs */
5 n- _* r; y& |2 ] - while (1)0 q$ i3 Q' ~9 M& i' a$ G8 \
& F# S7 ?1 `# u6 n& n - }7 P* w: L$ B' }7 _5 R' @. _# }# w
- }8 H( k0 j2 g/ F! o% E
; ~% ^) T! w$ q4 i+ e2 d- /**4 s7 s- j- z, i# U
- * @brief This function handles Bus Fault exception.. [( e7 D/ p; c& L
- * @param None
0 V- D6 [. f( { - * @retval None
' B7 l) I/ C y+ w3 F5 t - */
L' e2 x2 P" T8 C0 V- v9 x- ^ - void BusFault_Handler(void)
* c* g* h: ~. \! q - {
/ L4 {# t( G/ u& f7 ?. S - /* Go to infinite loop when Bus Fault exception occurs */
, N* G1 J( ]) U$ k" L, B - while (1)
9 P' {& _1 X$ C% r - {
$ t; U" U# k Z* y, F# U% @ - }/ x9 j' j9 J ^6 b* b
- }# \& A+ u* ^5 ]+ V! {; k
- 8 T0 @' q- \: T
5 x. E1 `9 T( Z; i - * @brief This function handles Usage Fault exception.7 ?& ?1 c5 F+ v2 p$ d; D- o4 Y) w
- * @param None
9 V$ }2 W6 \! V* T - * @retval None4 Y2 C& F2 `# y% p$ ]5 ^5 e
" q& o5 ]7 d1 W: u [, i! Y) F - void UsageFault_Handler(void)
6 X5 |# C# }1 Z f$ p1 \4 A- U - {
A7 D# e/ h( x. o# F! u( W - /* Go to infinite loop when Usage Fault exception occurs */8 r/ P- b) f4 R) j
- while (1)
2 s3 L5 z8 Q2 P( M - {
$ d) O9 p. j o. o3 w4 ~ - }* `2 B7 J4 w p. M3 E) J2 U1 C! d0 }6 R
- }$ S# h( k F' M
- " H. I; w( a' x" a
- #ifndef FREE_RTOS
* M" _3 o) N- h$ z% y' ? - /**
) j# x/ G' z2 y0 t - * @brief This function handles SVCall exception.; I1 t9 L" V" G+ v9 X% ?
- * @param None8 [7 v) j: [, l$ _ E( y
- * @retval None
/ X& X8 S6 k6 |) d8 k0 u1 } - */
4 `0 w. a8 g" I) ]3 \* u - void SVC_Handler(void)
/ b: B) E5 m8 d U' \ - {
) {. r' P; d1 e6 H, y; n - }
- G) A: E, p( F" l; ~ - #endif F! E! @$ N4 N
- 6 o7 G1 m5 U9 k$ R X7 x! X
- /**# h, T; z& V, y3 ?
- * @brief This function handles Debug Monitor exception.; `) f: i2 q0 n4 N( {% [
- * @param None
; ?4 u/ Q9 e8 K j" D - * @retval None7 b; @% s. c9 A* D x( L9 X
- */1 b9 m0 o1 r9 ~; i
- void DebugMon_Handler(void)
* ^) m) |! w5 C N# D - {
5 H% ^' A9 k/ @ t - }
" T9 V9 d2 U; n' A - 1 d* ~6 w+ R! b" ~8 J5 L+ d
- #ifndef FREE_RTOS
8 l8 ?/ Q2 P3 s+ O3 N, v2 f - /**2 }' {: T% l" k0 C- v8 C$ X: O
- * @brief This function handles PendSVC exception.
3 s% A( n' x, n0 M: \ - * @param None
0 j% B: H# m4 Z+ a8 A+ f8 a - * @retval None2 D' X7 J5 P5 v6 ~7 d0 o
\4 |$ {/ @7 K4 m% F) G E - void PendSV_Handler(void)
- b& }8 K! h7 {6 h* h - {2 `& C: F0 h7 e7 ~& F
- }( n" k# u' r& Y$ [! D/ |) ~
- #endif1 Q0 D. l" \) M H" n
& P9 ]: G1 w% I1 E! p. ~# `- #ifndef FREE_RTOS% P6 B+ _7 n, x
- /**# G+ K# X& F0 X1 V5 I8 h
- * @brief This function handles SysTick Handler.
. s! y% i+ C% Y8 L - * @param None
6 {2 i$ w8 K4 {) {- C - * @retval None
+ r9 q$ Z8 |' U& L0 n9 O - */
. J7 H& V7 w u4 R2 m$ P1 V - extern uint16_t mytime;
% j7 ~7 N- O% P/ W; Q - void SysTick_Handler(void)
O/ U# t. J! e' G - {
( X4 W& S7 f5 {7 @" t& C# r - TB_Scheduler();
$ B. k& H5 |4 q; }0 T7 H - mytime++;% I6 Y, U# ^* ^9 g) Z2 X
- if(mytime == 20000)
* N& P) F6 w1 V5 D9 w# }/ Q* C0 l - {mytime=0;}
6 s, \ D; I" ~2 _' g# V - }</font>
. e4 H" R8 w! c- {, e1 S& a& m - #endif
) @7 V8 }4 l% t
( ?3 e- g8 H M1 U! a- A- /******************************************************************************/
5 w5 z8 b6 a3 E; o0 U9 j - /* STM32F30x Peripherals Interrupt Handlers */+ I, v* c8 l, ~& z9 W I
- /* Add here the Interrupt Handler for the used peripheral(s) (PPP), for the */5 Z5 ~/ d [5 a2 \! n
- /* available peripheral interrupt handler's name please refer to the startup */
' k* i' z& @* Q% n$ m - /* file (startup_stm32f30x.s). */* j3 U0 Z1 u5 I
. E5 g* q% F/ M! E. F - 0 N+ Q z% W" f0 j/ I$ j
- /**; L+ X' `- m7 M
- * @brief This function handles PPP interrupt request. ~6 Z, x- [. s- H0 P- x
- * @param None* P+ D0 j# `% v5 f2 p
- * @retval None2 }' ?* m: w o6 B) J/ E
- */. Y) F; M5 f2 Y& \0 C, O; j2 S
- /*void PPP_IRQHandler(void)
* N5 s" d/ z- e+ d - {( l# Z9 H+ y. J, n* T3 n( o
. d, `, f: Q/ J' Q3 R+ O" I5 } - 6 _" s/ A! q7 o$ i& z6 g4 C
- /**) l* a2 a+ V+ }( [0 d" |' d$ Z4 S
- * @}: C h4 r9 I, v
4 j6 r; N: r9 l
) P' P3 p/ [% | ?/ S0 Y- : R' S& G( J, F. d0 E
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/- A8 ?% Z2 v8 }* Q2 u$ O
- : y" D/ [! Z& i% Q& a4 J
4 v, L+ h {% @
复制代码 1)如果是运行任务1,请取消TASK1代码注释
, e X( ~- c( `7 P
1 E1 n/ A! J* s% M d! c1 O: B2)如果是运行任务2,请取消TASK2代码注释% d9 v2 p D C. e
. t9 ^" D! V5 N8 k" D/ {: i3)如果是运行任务3,请取消TASK3代码注释0 R+ P4 T4 p' z: e& s/ |
7 R2 |7 [, A. x
0 M% L& O8 Q/ l" m; Q9 K6 `, Z; x: ?2 Q# x+ L2 S, Z3 B
这又不是github。
详细的说明我在昨天的帖子里说了
