stm32f301使用tim15产生PWM输出无反应,求解
轩宝 提问时间:2017-9-6 14:50 /
源代码如下:
  * @brief  ÅäÖÃTIM15¸´ÓÃÊä³öPWMʱÓõ½µÄI/O
  * @param  ÎÞ
  * @retval ÎÞ
static void TIM15_GPIO_Config(void)
                /*¶¨ÒåÒ»¸öGPIO_InitTypeDefÀàÐ͵ĽṹÌå*/
                /*¿ªÆôµç»úÏà¹ØµÄGPIOÍâÉèʱÖÓ*/
                RCC_AHBPeriphClockCmd(MOTOR_TIM_GPIOA_CLK, ENABLE);
                GPIO_PinAFConfig(MOTOR_P_GPIO_PORT,MOTOR_P_PINSOURCE,MOTOR_P_AF);
                GPIO_PinAFConfig(MOTOR_N_GPIO_PORT,MOTOR_N_PINSOURCE,MOTOR_N_AF);
                /*µç»úÕý¼«*/
                GPIO_InitStructure.GPIO_Pin = MOTOR_P_PIN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
                GPIO_Init(MOTOR_P_GPIO_PORT, &GPIO_InitStructure);
    /*µç»ú¸º¼«*/
                GPIO_InitStructure.GPIO_Pin = MOTOR_N_PIN;
    GPIO_Init(MOTOR_N_GPIO_PORT, &GPIO_InitStructure);
//                GPIO_InitStructure.GPIO_Pin = MOTOR_N_PIN;
//                GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
//    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
//    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
//                GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
//                GPIO_Init(MOTOR_N_GPIO_PORT, &GPIO_InitStructure);
                GPIO_SetBits(MOTOR_P_GPIO_PORT,MOTOR_P_PIN);
                GPIO_ResetBits(MOTOR_N_GPIO_PORT,MOTOR_N_PIN);
  * @brief  ÅäÖÃMOTOR_TIMxÊä³öµÄPWMÐźŵÄģʽ£¬ÈçÖÜÆÚ¡¢¼«ÐÔ
  * @param  ÎÞ
  * @retval ÎÞ
static void TIM15_Mode_Config(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        // ¿ªÆôTIMx_CLK,x[2,3,4,5]
  MOTOR_TIM_APBxClock_FUN(MOTOR_TIM_CLK, ENABLE);
  /* ÀÛ¼Æ TIM_Period¸öºó²úÉúÒ»¸ö¸üлòÕßÖжÏ*/
  TIM_TimeBaseStructure.TIM_Period = 256-1;       //µ±¶¨Ê±Æ÷´Ó0¼ÆÊýµ½255£¬¼´Îª256´Î£¬ÎªÒ»¸ö¶¨Ê±ÖÜÆÚ
        //¶¨Ê±Æ÷ʱÖÓÔ´TIMxCLK = 2 * PCLK1
  //                                PCLK1 = HCLK / 4
  //                                => TIMxCLK = HCLK / 2 = SystemCoreClock /2
        // ¶¨Ê±Æ÷ƵÂÊΪ = TIMxCLK/(TIM_Prescaler+1) = (SystemCoreClock /2)/((SystemCoreClock/2)/1000000)*30 = 1000000/30 = 1/30MHz
        /*»ù±¾¶¨Ê±Æ÷ÅäÖÃTIM_Prescaler¸ù¾ÝЧ¹ûÀ´ÉèÖü´¿É£¬ÖжÏÖÜÆÚС µÆÉÁ˸¿ì£¬´óÔòÉÁ˸»ºÂý*/
        TIM_TimeBaseStructure.TIM_Prescaler = 1000;//((SystemCoreClock/2)/1000000)*30-1;
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV2 ;                 //ÉèÖÃʱÖÓ·ÖÆµÏµÊý£º²»·ÖƵ(ÕâÀïÓò»µ½)
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //ÏòÉϼÆÊýģʽ
        // ³õʼ»¯¶¨Ê±Æ÷TIMx, x[2,3,4,5]
        TIM_TimeBaseInit(MOTOR_TIM, &TIM_TimeBaseStructure);
        /*PWMģʽÅäÖÃ*/
        /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;                                            //ÅäÖÃΪPWMģʽ1
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;        //ʹÄÜÊä³ö
  TIM_OCInitStructure.TIM_Pulse = 100;        //ÉèÖóõʼPWMÂö³å¿í¶ÈΪ0
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;            //µ±¶¨Ê±Æ÷¼ÆÊýֵСÓÚCCR_ValʱΪµÍµçƽ
  //ʹÄÜͨµÀ
  MOTOR_P_TIM_OCxInit(MOTOR_TIM, &TIM_OCInitStructure);
        /*ʹÄÜͨµÀÖØÔØ*/
        MOTOR_P_TIM_OCxPreloadConfig(MOTOR_TIM, TIM_OCPreload_Enable);
        /* PWM1 Mode configuration: Channel2 */
  //ʹÄÜͨµÀ
  MOTOR_N_TIM_OCxInit(MOTOR_TIM, &TIM_OCInitStructure);
        /*ʹÄÜͨµÀÖØÔØ*/
        MOTOR_N_TIM_OCxPreloadConfig(MOTOR_TIM, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(MOTOR_TIM, ENABLE);                        //ʹÄÜTIMÖØÔØ¼Ä´æÆ÷ARR
        // ʹÄܼÆÊýÆ÷
        TIM_Cmd(MOTOR_TIM, ENABLE);
/********************¶¨Ê±Æ÷ͨµÀ**************************/
#define MOTOR_TIM                                                           TIM15
#define MOTOR_TIM_CLK                                                       RCC_APB2Periph_TIM15
#define MOTOR_TIM_APBxClock_FUN        RCC_APB2PeriphResetCmd
#define MOTOR_TIM_GPIOA_CLK             RCC_AHBPeriph_GPIOA
/************Õý¼«***************/
#define MOTOR_P_PIN                          GPIO_Pin_2
#define MOTOR_P_GPIO_PORT        GPIOA
#define MOTOR_P_PINSOURCE        GPIO_PinSource2
#define MOTOR_P_AF                        GPIO_AF_9
#define  MOTOR_P_TIM_OCxInit                       TIM_OC1Init            //ͨµÀ³õʼ»¯º¯Êý
#define  MOTOR_P_TIM_OCxPreloadConfig       TIM_OC1PreloadConfig //ͨµÀÖØÔØÅäÖú¯Êý
//ͨµÀ±È½Ï¼Ä´æÆ÷£¬ÒÔTIMx->CCRx·½Ê½¿É·ÃÎʸüĴæÆ÷£¬ÉèÖÃеıȽÏÖµ£¬¿ØÖÆÕ¼¿Õ±È
//ÒÔºê·â×°ºó£¬Ê¹ÓÃÕâÖÖÐÎʽ£ºMOTOR_TIMx->MOTOR_RED_CCRx £¬¿É·ÃÎʸÃͨµÀµÄ±È½Ï¼Ä´æÆ÷
#define  MOTOR_P_CCRx                               CCR1
/************¸º¼«***************/
#define MOTOR_N_PIN                        GPIO_Pin_3
#define MOTOR_N_GPIO_PORT           GPIOA
#define MOTOR_N_PINSOURCE            GPIO_PinSource3
#define MOTOR_N_AF                            GPIO_AF_9
#define  MOTOR_N_TIM_OCxInit                      TIM_OC2Init            //ͨµÀ³õʼ»¯º¯Êý
#define  MOTOR_N_TIM_OCxPreloadConfig       TIM_OC2PreloadConfig //ͨµÀÖØÔØÅäÖú¯Êý
//ÒÔºê·â×°ºó£¬Ê¹ÓÃÕâÖÖÐÎʽ£ºMOTOR_TIMx->MOTOR_GREEN_CCRx £¬¿É·ÃÎʸÃͨµÀµÄ±È½Ï¼Ä´æÆ÷
#define  MOTOR_N_CCRx                       CCR2
配置参数检查多次,没有发现有问题,求大哥大姐们看看问题出在哪里,谢谢了
赞 收藏 2 评论2 发布时间:2017-9-6 14:50
努力的人 回答时间:2018-1-24 10:54:43
把这两句删了,试一下
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
xmshao 回答时间:2018-1-24 12:09:44
时钟配置、管脚复用配置,好好检查下。整体上配置不复杂。
TIM15 只支持通道1/2.
你可以使用STM32CUBEMX配置测试下。
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
